Showing results for tags 'turned box'.
Our Patriot Turners- Things are a little slow this week. I did an Easy Wood Tools/Club Demo last Thursday evening. Showed the process for doing the John Beaver wave bowls. I don't get the club meetings as often as I should. Seems that Thursdays are always busy. One of the members- a brother of one of my former school students- snapped this so he could see how old I have gotten. What’s Coming Up- Cindy Drozda's Tool Talk will continue the Emma, Tod, Cindy collaboration piece. It's Friday, August 15. It’s coming along nicely! I’ll be sanding and finishing, and showing how I sign my work. It’s free and open to everyone. Join me for talk about tools, woodturning tips, upcoming events, and interesting Woodturning stuff. Make comments, ask questions, or say hello. Win a prize in the Raffle! Subscribe to my list, and get the links to my free events by email. Please tell all of your woodturning friends and club members! https://streamyard.com/watch/C6bayNKnBhM7 SWAT is almost here! https://www.swaturners.org/swat-registration-2025.html For The Newbies- Richard Raffan uses a lot of scrapers for both inside and outside of bowls. In this video, he shares/describes his scraper arsenal. Picked this up from Ron Brown's newsletter. Some good advice about sharp(ening) tools- Free-hand Sharpening vs. Jigs For some people, a good piece of wood is a work of art. For others, it's just a blank canvas waiting to be transformed. And for a select few, it's a constant reminder that they don’t know what they don't know. When I first started turning wood, I was a walking, talking example of that last group. I was a greenhorn with a gouge, completely unaware of my own ignorance. Fortunately, I crossed paths with a seasoned pro named Nick Cook. Now, this guy could sharpen a tool by hand with his eyes closed, so I had to ask him: Why do you bother with those fancy jigs?" His answer was a master class in common sense. He gave me three simple reasons: 1. It saves time. A lot of time. 2. It's repeatable. You get the same perfect edge every single time. 3. Your tools last longer. They just do. Those three points really stuck with me. Later, while working the woodworking show circuit, I heard a lot of complaints. People loved the idea of sharpening jigs, but hated the time it took to set them up for different grinds. So, I went to work and created setup aids for 6 of the most common HSS lathe tools; 7 if you include the 4040-grind setup block. They are: Bowl Gouges, Spindle Gouges, Skews, Scrapers, Parting Tools, and Spindle Roughing Gouges. For the last 20 years, these setup aids have helped woodturners quickly and easily get the perfect edge. Most woodturners see their tools as a one-time purchase. They're not. They're a consumable, just like a lightbulb or a roll of paper towels. Sharpening a bowl gouge by hand often takes three or four passes. A good jig can do it in a single pass, removing less material in the process. Less material removal means your tools last longer. It’s simple math. But here’s the real kicker: if sharpening is quick and easy, you’ll actually do it. Most people will tolerate a dull tool far longer than they should because the idea of sharpening it is such a hassle. A sharp tool makes a clean cut. A dull one just scrapes and tears at the wood. When it comes to turning, that difference doesn't just affect the wood; it affects the entire process. Benefits of Sharp Chisels 1. Smoother Finish: A sharp chisel produces a much cleaner cut, resulting in a smoother surface that requires less sanding. This can save a lot of time and effort in the finishing stages of a project. 2. Reduced Tear-Out: When a tool is sharp, it shears the wood fibers cleanly. A dull tool, however, can tear out the grain, creating a rough, uneven surface that is difficult to fix. 3. Increased Control and Safety: Sharp tools are easier to control. A dull tool requires more force to make a cut, increasing the risk of a "catch," which is when the tool grabs the spinning wood violently. This can be dangerous and damage the workpiece. A sharp chisel, on the other hand, allows for more precise and controlled movements. 4. Faster Material Removal: A sharp tool removes material more efficiently. This means you can get through the initial shaping of a piece of wood much faster. 5. Improved Shavings: Sharp tools produce long, continuous shavings. Dull tools produce fine dust or small chips, which are a clear sign that the tool is not cutting effectively. It's important to note that even carbide tools, which are known for their longevity, will eventually become dull and require sharpening or a new tip. Regular sharpening is an essential skill for any woodturner to maintain tool effectiveness and achieve high-quality results. You should sharpen your wood-turning chisels frequently, even several times during a single project, to maintain their edge. Expand Your Horizons- Tomislav shared a great video showing a technique called "back hollowing". For those of us who learned the traditional method of hollowing this is really different! Mike Peace makes a small, threaded keepsake box for cremains. Turning Time With Easy Wood Tools- Found this video comparing the Easy Chuck to the Nova G3 Chuck. The Influencer does a pretty good job of comparing/contrasting the two. Some Easy Wood Tools Demos coming up- Did you know Easy Wood Tools sells "unhandled tools"? Check this out- https://www.easywoodtools.com/unhandled @Jordan Martindale New Turning Items- Ron Brown's new spindle duplicator is ready to go! https://longworthchuck.com/index.php?route=product/product&path=90&product_id=589 Hope Live Star Drive is available. This is available in he USA from- https://blackforestwood.com/products/live-star-drive?_pos=1&_psq=hope+live&_ss=e&_v=1.0 Everything Else- Tim Yoder cheated death to retrieve this piece of wood. Safe turning
Looks like we might have to opportunity to help a deserving family for Christmas! Our Patriot Turners- @AndrewB updated us on his new lathe purchase. Really nice lathe stand for his new Jet. He mentioned there was some vibration as certain speed. I'm wondering if it might be a "heavy spot" in the bowl blank he was turning and creating a resonance vibration. Check out Andrew's post here: @Headhunter posted some of his Ringmaster turnings in our Ringmaster Sub-Forum He received lots of comments and some questions about the pieces. Check out his work at- @Bob Hodge posed an interesting question about an item he was asked to duplicate. After a lot of input, ideas and guesses, Bob decided to decline the request. We had some really interesting input! @RustyFN gave us an update on the beautiful winged bowl he turned. He said the picture is of the "unfinished" piece! Wish my unfinished turnings looked that good! We've had some entries on our "What's Off..." this week! @Gerald posted several of his recently completed items. Catchup with all of the images here- And, we've had entries in the "What's On..." too! @calabrese55, @Gerald and @Fred W. Hargis Jr added to the continuing post! There are a lot more images at- What’s Coming Up- Click on the images for links to more information and registration Lyle Jamieson is hosting an IRD on hollowing, December 10, 2024 Friday, November 22, 2024 at 2pm EST For The Newbies- Texturing tools can add a new dimension to your turnings. In this video, Mike Peace compares and contrasts several of the available tools. A short video from Alan Stratton on designs and where to get inspirations. Expand Your Horizons- Tim Yoder turns a HUGE piece of Osage orange JumBowl.mp4 A little late for Halloween and Thanksgiving but it gives you plenty of time for next year New Turning Items- Nothing for this week Everything Else- If you have been turning for any length of time, you will probably recognize the name Nick Agar. Nick has been diagnosed with cancer. Here is more information- The link to the Go-Fund-Me page https://www.gofundme.com/f/help-support-nick-agars-fight-against-cancer Safe turning
- 3 replies
- wednesday
- wisdom
(and 26 more)
- wednesday
- wisdom
- woodturners
- help a hero
- jet lathe
- vibration
- ringmaster
- question
- duplication
- wing bowl
- turned box
- segmente vase
- christmas tree
- lyle jamieson
- hollowing
- scott hampton
- snowmen
- gnomes
- cindy drozda
- tool talk
- texture tools
- mike peace
- design
- alan stratton
- tim yoder
- turned pumpkin
- nick agar
- go-fund-me
Well another election is in the books. I, for one, will be glad to return to commercials for Ozempic and Liberty Mutual car insurance. Our Patriot Turners- @RustyFN picked up some great looking Sycamore logs- He received lots of comments on the popularity of Sycamore for turning. Check out the comments at- Rust also made a super score at his local Woodcraft store. Our resident Ring Master turner, @Headhunter, posted some awesome bowls he has completed! Head on over to Tony's post and see more images and the comments from our gang- @Fred W. Hargis Jr was perusing some of our older topics and posted an observation about a commonly turned wood- @DAB turned a nice little bowl from a wood I had never heard of- Ohia. I found this from an Internet search- https://dlnr.hawaii.gov/forestry/plants/ohia-lehua/ He has some interesting stuff he is thinking about storing in this one! @forty_caliber has several serious hobbies along with turning. It's fantastic when you can meld them together. In this post from "What's Off Yor Lathe...", Monty turned an adapter to help build his short wave radio antenna farm. Also, in the "OFF" topic is a really nice bowl posted by @user74- The new items start here- What’s Coming Up- Click on the images for links to more information and registration For The Newbies- Safety video from Craft Supplies USA. PSA- not just for Newbies!! With Christmas coming, a gift idea from Alan Stratton @Steve Krumanaker Practice your spindle turning and a little hollowing with this item from Mike Waldt Expand Your Horizons- The "4 Ways" collaboration is back! A winged box!! A neat project for the seamstress in your life from Carl Jacobson- New Turning Items- I think we posted this before from another source. Here is Tim Yoder's assessment of the Tru-Arc tool Everything Else- Safe turning
- 10 replies
- wednesday
- wisdom
(and 25 more)
- wednesday
- wisdom
- woodturners
- sycamore
- ring master
- bowls
- adapter
- cindy drozda
- todd raines
- tool talk
- zoom sharing
- burl
- craft supplies usa
- grinder safety
- alan stratton
- honey dipper
- bud vase
- mike waldt
- 4 ways
- mike peace
- sam angelo
- richard raffan
- tomislav tomasic
- carl jacobson
- turned box
- tru-arc
- tim oder
Hope this Wednesday finds everyone doing well. Our Patriot Turners- Member @Gordon posted a question about a problem he has had during the second turning of a twice turned bowl. He has noticed the wall thickness is not consistent around the perimeter of his bowls. Please check his post and see if you can offer some suggestions. Gordon also gave us a peek and an awesome maple score he managed! More images and some suggestions from our turners, here- @Masonsailor will be sharing his turning knowledge. He is having a segmented bowl class and showed us some of his prep work- Looks like this is going to be a fun class. Hope on over to Paul's post and check out the segment work! @HandyDan got a real jump on this year's family Christmas ornaments! He made a few really nice candles/holders- In Dan's post he provided some background on the amazing colors he used- @AndrewB has been keeping us up to date with the progress of his new lathe. The new Jet is performing great as per Andrew's posts- Another great week for our "ON/OFF" your lathe post! From ON- @kreisdorph worked his magic in walnut- Catch up here- And from "OFF"- @RustyFN created a gorgeous mixed media turned box- New items and comments begin here- What’s Coming Up- Click on the images for links to registration and more information. My free Tool Talk Livestream is this Friday. October 25th, at 2pm Eastern (18:00 UTC). For The Newbies- Mike Peace discusses dust collection. Good information for turners regardless of their skill level. Expand Your Horizons- The holiday season is fast approaching. As @HandyDan has already reminded us! Here's more ideas for turning projects, From Alan Stratton- And from the pages of Popular Woodworking, another project from Jimmy Clewes- The tutorial link- https://www.popularwoodworking.com/projects/turned-scoop-with-pewter-finial/ New Turning Items- A couple of items on sale- Niles Bottle Stoppers https://nilesbottlestoppers.com/product/whiskey-sample-kit/ From World of Texas some Starbond Inlay Materials- https://woodworldtx.com/search?type=article%2Cpage%2Cproduct&q=starbond*+inlay* Everything Else- First coat of poly on the wave bowl- Safe turning
https://www.911memorial.org/ Our Patriot Turners- Member @Bob Hodge asked a question about finishing techniques. Please a take a moment to stop by his post and see if you can add to what has been said. @AndrewB got his lathe up and running. He had some banjo problems. Some more activity on our "ON/OFF" your lathe this past week- From "OFF"- @Gordon showed us a gorgeous ash bowl- Catch up with more images and comments here- And, from "ON"- @Gerald, @forty_caliber, @teesquare and @kreisdorph all added to the list of projects! See the new additions, images and comments starting here- What’s Coming Up- Click on the images for links to more information and registration- And on Friday, September 13, Cindy Drozda is having a Tool Talk- For The Newbies- Sooner or later, when folks learn you are a turner, someone will ask you to duplicate a knob, spindle or similar item. Richard Raffan demonstrates his techniques. A nice article from the AAW for turning a box- https://www.woodturner.org/Woodturner/Resources/AmericanWoodturner/2024/39-4/Turn-an-Elegant-Round-Bottom-Box.aspx?fbclid=IwY2xjawFKoZFleHRuA2FlbQIxMAABHd70o6bnhe3biMaw4eMHg0YMuogHclDn5Edy5zIkS5T_NplWyoMPlYYtOg_aem_tdq_nHfgzU8xEPiTDfDttA Expand Your Horizons- @Gerald uses paints to embellish some of his turnings. I this video, Mike Peace demonstrates using iridescent paints- Mike also posted a video for hand chasing wooden threads. He includes some good tips on wood selection. When I do turning demonstrations for Easy Wood Tools, the one product that seems to draw the most interest from new and experienced turners is the Easy Chuck. A short video on the chuck and some of its features. New Turning Items- Ron Brown has developed a new sphere turning jig. Looks like it might be a pretty nice piece of equipment. Everything Else- Safe turning
Just days left in our fund raising raffle. If you haven't picked up your tickets for some really special prizes, check out- Every little bit helps keep our site alive! Our Patriot Turners- @calabrese55 is getting rid of his extensive stash of pen making supplies. If you are looking for kits or pieces, see his post- @Gerald and @kreisdorph added some gorgeous items to our "What Finished" post. Gerald's project is for an AAW swap he participate in- And, Kent's are a couple of turned Chalices made from elm. This is where the new entries begin- What’s Coming Up- Cindy Drozda and Todd Raines will host a free Sharing Session this Friday, August 2nd, at 2:00pm Eastern (18:00 UTC). It's FREE, live, and interactive on Zoom! https://www.cindydrozda.com/html/Signup.html https://woodturningtoolstore.com/ For The Newbies- Woodworker's Journal published their monthly issue of the Woodturning Monthly. Lots of neat ideas and projects. Here's the link- https://www.woodworkersjournal.com/woodturning-monthly/?utm_medium=email Expand Your Horizons- Richard Raffan turns some "twig pots"- New Turning Items- OK, I know this is a stretch, but hey, I'm trying Sketchup is not generally thought of as software used by turners. This video demonstrates that the software is versatile enough to create elaborate shapes for the turner. For a smaller learning curve, this free software is available. Lathe Magic can create visual, 3D renderings of turning shapes. Free download is available here- https://www.shapemagic.com/lm/index.htm Everything Else- The rolling pin workshop is done. They made about 21 Celtic knot rolling pins of various shapes and designs. We started with this- This was one of the finished pins- Safe turning
Whew! Is it ever hot out side. Back porch thermometer, in the shade, reads 98°! Good thing I painted 150 feet of chain link fence yesterday when it was only 95°!! On another topic, keep watching TPW for BIG news!!! Our Patriot Turners- @Gerald posted a root ball turning he completed. Lovely colors and design! Lots of great comments on this one- @User74 added to our "Off Yor Lathe" continuing post with a lovely bowl turning- You can see more images and comments at- There have been a couple more comments added to @Fred W. Hargis Jr post for a turned box. Also, Fred's post on turning a crotch log has generated more interest. Questions and answers abound! What’s Coming Up- Click on the images for more information and registration- For The Newbies- Mike Peace recently did a club IRD on box turning. This is the complete demo so it is a little long but has lots of good information. Thinking about purchasing that first scroll chuck. I copied this from Woodturners Wonders email. It offers some good advice about choosing a chuck. No I do not have any affiliation with them! Choosing the Right Woodturning Chuck: A Guide for Enthusiasts When diving into the world of woodturning, selecting the right chuck for your lathe is crucial for both the quality of your projects and your overall experience. At WoodTurners Wonders, we understand that every turner has unique needs and preferences, which is why we proudly offer Vicmarc, Axminster and Easy Wood Tools woodturning chucks. Here are some key factors to consider when choosing a chuck, along with the advantages of these renowned brands. Key Factors to Consider When Purchasing a Chuck Compatibility with Your Lathe: Ensure the chuck fits your lathe’s spindle size and thread. Different lathes have varying spindle sizes, so double-check your lathe specifications before purchasing. Size and Weight: The size and weight of the chuck should match your lathe’s capacity. A heavy chuck on a small lathe can strain the motor and affect performance, while a lightweight chuck on a large lathe might not provide sufficient grip for larger projects. Grip and Holding Power: The chuck must securely hold your workpiece. Consider the types of projects you undertake—bowls, spindles, or intricate designs—and choose a chuck with jaws that suit those needs. Ease of Use: Look for chucks that are user-friendly. Quick and easy jaw changes, smooth operation, and robust construction can significantly enhance your turning experience. Jaw Compatibility: Some chucks offer interchangeable jaws, allowing you to adapt the chuck for different projects. Check if the chuck you’re considering has a range of compatible jaws. Vicmarc Woodturning Chucks Vicmarc chucks are known for their precision engineering and durability, making them a favorite among professional turners and hobbyists alike. Here are some standout features: Superior Build Quality: Vicmarc chucks are crafted from high-grade materials, ensuring longevity and reliable performance. Precision Engineering: The precision of Vicmarc chucks means less vibration and better stability, leading to smoother and more accurate turning. Wide Range of Jaws: Vicmarc offers a variety of jaws, making their chucks versatile and adaptable for different projects. User-Friendly Design: Many Vicmarc chucks feature a quick-change jaw system, simplifying the process of switching jaws for different tasks. Axminster Woodturning Chucks Axminster chucks are celebrated for their innovative designs and exceptional value, making them a great choice for both beginners and seasoned turners. Key benefits include: Innovative Features: Axminster chucks often incorporate unique features like woodworm screws and dovetail jaws, enhancing their functionality and versatility. Excellent Value: Despite their high quality, Axminster chucks are competitively priced, offering great value for money. Robust Construction: Built to last, Axminster chucks can withstand heavy use and demanding projects. Stainless Steel Construction: The Axminster chucks we offer are made of stainless steel, which resists rust and corrosion. This is particularly beneficial when turning wet wood, ensuring your chuck remains in top condition over time. Comprehensive Support: Axminster provides excellent customer support and a wealth of resources for turners, from instructional videos to detailed manuals. Easy Wood Tools Chucks Easy Wood Tools chucks are designed with ease of use and innovation in mind, making them a popular choice for turners of all skill levels. Here are some key advantages: Innovative Design: Easy Wood Tools chucks feature a unique quick-change jaw system that allows you to switch jaws in seconds without any tools, streamlining your workflow and saving time. User-Friendly Operation: These chucks are designed to be intuitive and easy to use, making them ideal for both beginners and experienced turners. Durable Construction: Made from high-quality materials, Easy Wood Tools chucks are built to withstand regular use and provide consistent performance. Versatility: With a range of compatible jaws and accessories, Easy Wood Tools chucks offer flexibility for a variety of turning projects. Making the Right Choice Ultimately, the best chuck for your lathe depends on your specific needs and preferences. Vicmarc, Axminster and Easy Wood Tools offer exceptional products, each with their own unique advantages. Consider the types of projects you’ll be working on, your lathe’s specifications, and your budget to make an informed decision. At WoodTurners Wonders, we are committed to helping you find the perfect tools for your craft. Whether you choose a Vicmarc, Axminster or Easy Wood chuck, you can be confident in the quality and performance of your purchase. Visit our store or website to explore our full range of woodturning chucks and accessories. Happy turning! Expand Your Horizons- Last week's post included a tip from Lyle Jamieson about making a secure glue block connection. In this video Jim Rodgers demonstrates another method of connecting to a glue block- Another scoop from Alan Stratton. This one uses offset turning and a couple of neat jigs. Also, check out Alan's method for turning spheres- WITHOUT a jig! New Turning Items- Posted the video about these last week but here's the official Niles Bottle Stopper announcement- **NEW PRODUCT ALERT** We’re excited to introduce our new Low Profile Lightweight Threaded Rings, available as a set of all three or individually in three sizes: 1.5”, 2.5”, and 3.5”. Made in the USA from bronze, these rings feature: - 1.5″ ring: Inside measurement 1″, overall height 3/8″ - 2.5″ ring: Inside measurement 2″, overall height 3/8″ - 3.5″ ring: Inside measurement 3″, overall height 1/4″ This hardware creates a secure closure for lidded boxes, urns, canisters, and other similar projects. They consist of a male and female thread, which helps create a tight seal. These rings are lighter weight and lower in profile than our original Threaded Rings. The original rings are also still available and might be better suited for urns. Installing the new rings is a little different than the original style. The new rings require a tenon on one half. Pricing and more information is here- https://nilesbottlestoppers.com/product/low-profile-lightweight-threaded-rings/ Everything Else- Just for fun Safe turning
- 4 replies
- tim yoder
- niles bottle stoppers
- (and 23 more)
Relatives gone but the remainder of the week already scheduled with appointments. Our Patriot Turners- Our turners have been busy with projects and new journeys @Gerald is learning the ins-and-outs of his new JaHo jig. He posted a couple of cool bowl images and asked our opinion on the painting scheme- His post received lots of comments. Our turners are not shy offering their opinions! Check out his post and give him your input! @keithlong asked us for some leads on mechanical pencil kits. He has been asked to turn a special type of pencil. If you have any ideas for sources for these kits, Keith would appreciate any input- @Fred W. Hargis Jr has started down the slippery slope of wood turning ! He asked our group for some ideas on turning knobs. Specifically, how is the best way to hold the knob during the urning process. A lot of us chimed in with various suggestions and information sources. Fred's setup looks like this- Check his post/questions and our responses and give him some of your ideas- Our continuing post of "What's On Your Lathe" got a couple of hits this week! @kreisdorph posted images of a beautiful cedar bowl. New entries begin here- What’s Coming Up- Cindy Drozda has a free, live tool talk on Friday April 26. Registration link is- https://streamyard.com/watch/MJdeXdGa5fNC For The Newbies- Mike Peace gives us a refresher course on the various live centers available. If you are thinking of upgrading your center, he offers some good information. Sam Angelo gives talks about how to safely use the spindle roughing gouge- Lyle Jamieson has some tips on tips on wet wood storage and wet wood turning- Expand Your Horizons- Richard Raffan turns a lovely little jewelry box from "Sheaok". I had to look that up on the web. Interesting species. Also, watch how Mr. Raffan takes setbacks in stride! Alan Stratton turns a rose bush root ball. Someone said life is too short to turn crappy wood. I'd say the results were well worth the effort. New Turning Items- Found this in the Niles Bottle Stoppers newsletter- Here's the link- https://nilesbottlestoppers.com/product/bottle-stoppers-blanks/ Everything Else- Safe turning
- 3 replies
- turned box
- richard raffan
- (and 21 more)
The old Dogwood tree, outside my window, should be in full bloom tomorrow. Hard to believe when I transplanted it, from my parents mountain property, it was a single, spindly stick. That was 56 years ago! Our Patriot Turners- @RustyFN showed us a beautiful new turned lidded box he made. He said this one is made from Maple. He certainly has perfected the flocking technique, too! Our turners gave him lots of compliments in his post- @Gerald has been creating amazing designs with his JaHo jig. His most recent refrigerator magnet is a beauty! Check out this addition to his post- More activity on our two continuing posts of "What's On/Off the Lathe" From ON: @Gerald provide a closeup look at his JaHo jig in action- You can see how this jig can create some fantastic designs. Check out Gerald's post for additional images. From OFF: @kreisdorph turned a gnarly piece of mulberry into a beautiful bowl- Kent also finished these beauties. This spalted piece caught my eye because of the shape. Years ago, an artist friend sent me a picture from a magazine. He fell in love with the shape. I think it was a hint for me to turn one. Alas, I have not done it. New projects start here- @lew was looking for some input on design and proportions for turnings. He used miniature hollow turnings to get an idea of what had pleasing shapes and asked our turners their opinions. As always, our members provided some excellent advice and suggestions. What’s Coming Up- Click on the images for links to more information and registration- This is a replay of the most resent Tool Talk from Cindy Drozda For The Newbies- Thinking of design and proportions, Lyly Jamieson's turning tip discusses the design for bowls, Pen turning is a great way to get into turning. Kits can be inexpensive and provide amazing results. Tim Yoder shows us how it's done!! Now for a little more of a challenge, Jim Rodgers turns a segmented pen- Expand Your Horizons- Last week we posted a shop tour hosted by Mike Peace. The craftspeople were making Beads Of Courage boxes. Mike takes a segmented glue up and turns his own version of a Beads of Courage box- Sometimes the most beautiful turning is not the most perfect piece. Alan Stratton explains- https://youtu.be/hx1qGGVvU-g?si=mSuL1RJNLd0YDMOu EDIT: Cannot get this video to show in published post. Link seems to work. A short video from Richard Raffan demonstrating how he utilizes as much of a turning blank as possible. Check out the unique parting tool! New Turning Items- Been really difficult to find anything new on the market. Maybe by the time the income tax return is ready there will be some new toys to spend it on. Everything Else- An excerpt from Ron Brown's newsletter on advice for the new turner My advice for a new turner or a student would include the following: Find a turning club in your area and attend some meetings. These people are a tremendous resource and are always eager to help. Start with pens. Start by watching some YouTube videos for instructions. Get setup for basic pen turning, a 7mm mandrel, some slimline pen kits, proper sanding grits, CA glue, friction finish, etc. Pens are quick to make, easy to turn, and provide an immediate sense of accomplishment. If someone wanted to sell a few pens to pay for more turning stuff, many folks earn turning money this way. Then make some spinning tops for fun and give them away. Turn a few bottle stoppers and give them as gifts to friends and relatives. As soon as you can afford it, buy an inexpensive 4 jaw scroll chuck. Add more jaws down the road or buy a chuck with a few jaws included. Quality chucks with multiple jaw sets can be very expensive. Save that for later. For now, just get a serviceable chuck for around $100. Turn small plates from a 3/4" thick piece of wood using a recessed tenon in expansion mode for practice. A family member might even wish to add decorations or paint your masterpiece. Now that you have a scroll chuck, practice making turned lidded boxes, goblets, and soup ladles for the kitchen. Try turning a few small bowls from green wood. Turn the walls to 1/4" and watch them go oval. Turn a few 1/2" thick to let them dry in a paper bag for a few months, then re-turn them to 1/4" wall thickness once they’ve dried if they didn’t crack or explode. Once you've done all that, evaluate your interest in turning and if you love it, like most of us do, prepare to spend some money (easily $500) on High-Speed Steel lathe tools, a specialty grinder, and a sharpening jig. Next, set about learning to cut with traditional turning tools and learn to keep them sharp. Note: You only need a few HSS tools. In the beginning, don't buy more than 10 total, and never buy turning tools in a set. Always purchase the tool you need for the job at hand. After that, plan to take some full-day turning classes and plan to attend some turning symposiums in your area. From there, the sky is the limit. Turning can be as much or as little as you want. You can learn to make shavings in a couple of hours. It takes a lifetime to become a “Turner”. Did play a little at the lathe this week. The largest usable piece of that wind shake cherry was dry so I put it on the lathe. The more I turned, the more defects were uncovered. Filled the cracks with CA and sanding dust. The colors are nice but I don't like the tiny splits throughout the piece. Sanded to 600 and beeswax/mineral oil finish. Safe turning
- 6 replies
- ron brown newsletter
- alan stratton
(and 24 more)
I hope everyone can enjoy a peaceful Easter accordance with your customs. Our Patriot Turners- @Smallpatch was hitting the yard sale circuit when he spied an old lathe. Not one to pass up a bargain, he took it home a refurbished it. Check out his post for more images and the back story- New member @User74 posted a question about carbide tools. We had a very informative discussion about the quality of tools and cutters. Check out the post and see if you can add to it- @Steve Krumanaker created a beautiful Beads of Courage box. Steve used a special technique to create the staves for his turning project. Head on over to his post for more images and our members' comments Another great week for our What's ON/OFF your lathe discussions. From ON the lathe, @Gerald and @User74 gave us a look at their current turnings New information starts here- And, from OFF the lathe- @RustyFN and @User74 completed some really nice turnings- New posts for this week starts here- What’s Coming Up- Click on the images for links to more information and registration- Last week, we posted a link to the Mid-Atlantic Woodturning Symposium. One of the presenters is Alan Lancer. Here's a short video of what you can expect to see from him- For The Newbies- A tip, from Lyle Jamieson, for holding small turnings without a chuck- Easy Wood Tools shared a new video on how their products are made. Easy Wood Tools are made, in America, entirely in house- even their carbide cutters! @Jordan Martindale Expand Your Horizons- Tim Yoder shows us how he makes his French rolling pin. Tim is always fun to watch! Richard Raffan is bucking the trend of large turnings. In these two videos, he creates lovely small turnings. His commentary, while turning, gives an insight into his turning techniques- The Woodworker's Journal has published the Woodturning Monthly newsletter. Nice article on how to add butterfly patches to a turning. The newsletter can be found at- https://www.woodworkersjournal.com/woodturning-monthly/?utm_medium=email New Turning Items- Got a heads-up from @Grandpadave52 about a great price on a Longworth chuck sale. Everything Else- Safe turning
- 5 replies
- peachtree
- longworth chuck
(and 29 more)
- peachtree
- longworth chuck
- woodturning monthly
- richard raffan
- rolling pin
- tim yoder
- easy wood tools
- holding pieces
- alan lancer
- pen maker symposium
- burl management
- hollow
- lyle jamieson
- vendor showcase
- sharing
- cindy drozda
- todd raines
- plywood bowl
- turned box
- fail
- end grain bowl
- trees
- tops
- beads of courage
- quality
- carbide
- question
- refurbish
- woodturners
- wisdom
- wednesday
Lots happening this past week! Our Patriot Turners- @keith long stopped by to say "Hi". He is busy with life and doing well. He had some questions about lathe parts. Check out his post and see if you can add to what has been said- Keith also had a question about what wood species would be best for making duck calls. If you make them or know what would work best, maybe you could help him out- @kreisdorph resurrected an older post about bowl drying. He added some great additional information. Check out the entire thread here- Kent also gave us a nice review on a book for identifying wood species. Thanks!!! @Gerald is recovering from knee surgery and snuck back into the shop to work on some projects. Hope he got back into his recliner before the Mrs. got home See what else he did at- Our "What's On Your Lathe" thread continues to generate awesome projects. @kreisdorph, @teesquare and @RustyFN showed us some fantastic work. Start here to catch up on all the projects- @StaticLV2 continues to work on his segmented turnings He posted this one in the "What's On Your Weekend Agenda" And, from our "OFF The Lathe and Finished' thread- @kreisdorph and @RustyFN posted some gorgeous turnings. Catch up with all these items here- What’s Coming Up- Click on the images for links to registration and more information- For The Newbies- Ask ten turners what is the best finish and you will likely get at least 15 different answers. One finish that often mentioned is shellac. This video from Kent Weakley explains why shellac is appropriate. This is the link to his article on shellac and how to mix it- https://turnawoodbowl.com/make-shellac-wood-bowl-finish/ Turned wooden boxes make nice gifts. Sam Angelo demonstrates turning one from start to finish. Looks like Sam needs to turn the heat up in his shop. I don't endorse wearing gloves, but that's just me. Craft Supplies USA has a step by step video on turning a pepper mill. Expand Your Horizons- Richard Raffan demonstrates turning one of his signature scoops. Awesome skew work and check out the shop made, lathe mounted sanding disc. Lyle Jamieson provides tip for preventing vibration when turning finials New Turning Items- Ron Brown has a new parting tool to use with his "Bowl From A Board" jig- Everything Else- This past week, in another Patriot forum, there has been a very informative discussion on liability for the stuff we make. This video, from Alan Stratton, addresses some of the regulations for a specific item. Safe turning
- 5 replies
- baby rattle
- safety regulations
(and 35 more)
- baby rattle
- alan stratton
- parting tool
- ron brown
- wednesday
- wisdom
- woodturners
- question
- lathe part
- duck call
- bowl drying
- book
- wood identification
- hollowing
- bowls
- bowling ball
- segment work
- natural edge
- square platter
- veneer
- ring box
- todd raines
- zoom sharing
- cindy drozda
- vendor showcase
- mid atlantic symposium
- shellac
- kent weakley
- sam angelo
- turned box
- pepper mill
- richard raffan
- scoop
- lyle jamieson
- vibration
Thanks, Mike, for reminding us of how we have the freedoms we enjoy today- Our Patriot Turners- @Roy gave us an update on how his sphere jig is working. In his post he explains the significance of the choice of spheres. I can't imagine how he did the glue-up! @forty_caliber posted another beautiful bowl he turned from pecan He answers questions about the awesome center medallion he uses to sign his work- check this post @Gerald gave us a look at his setup for turning spoons without the aid of special jigs- He received lots of comments about his setup- Gerald also posted some of the ornaments he turned using an idea from last week's "4 Ways" Here's more from Gerald- Gerald's post got me thinking about some of the ornaments our members turned in years gone by. We had links to lots of design for ideas. Thought it would be nice to bring back some of them to stir your imaginations- https://www.woodcraft.com/blog_entries/turn-a-terrific-tree-ornament http://www.crwoodturner.com/files/how-to/ornaments.pdf http://kurthertzog.com/articles/creatingshellornamentsrev3red.pdf https://blog.woodturnerscatalog.com/2012/12/turning-a-snowman-box/ What’s Coming Up- https://community.woodturner.org/events/event-description?CalendarEventKey=a2728bff-a39d-4375-adee-018b90a311c9&Home=%2fevents%2fird-demonstrations&_zs=ceDib&_zl=rpKp3 For The Newbies- Thinking about turning duplicate parts? The December/January 2024 issue of Woodcraft Magazine's "Top Tip" in Tips & Tricks (pp 16) has a really neat lathe duplication jig. It uses your own turning tools and all the parts can be located at the Borgs. Check it out!! Expand Your Horizons- Craft Supplies USA posted a video on using CA glue as a finish. Another option for finishing some of your turnings- A nice pendant turning article from the AAW- https://www.woodturner.org/Woodturner/Resources/AmericanWoodturner/Articles-of-the-Week/2023/Tapered_Pendants.aspx?fbclid=IwAR3-6_s7nGVLEWvSgj9xpaXmybwFANI6UeAqDATbON-6HZpEGIrlh_En8io New Turning Items- Couldn't find anything special but remember Woodturners Wonders is running a daily sale- see last weeks "Wednesday's" for the list. Everything Else- I finished up the height adjust table to help accurately focus my engraving laser. It does work. Had to add up/down arrows to the adjustment knob after the pictures were taken. Finished table- Laser setup. The drill press table adjustment crank handle is visible back behind the orange laser safety shield. Very difficult to access to make focus adjustments. In action- Last week, at the local turner's club, one member demonstrated making a Christmas tree from a fresh cut limb. Thought I'd give it a try. Took longer to do the star than to turn the tree. Turned completely with Easy Wood Tools- except the star which was formed from a ball integral to the top of the tree. Cut out with a sharp utility knife. Star has gold leaf. Gonna leave the tree natural. Sort of a "primitive" item. From Ron Brown's newsletter- Curiosity As a child, whenever my mother gave me a new toy, it always came with the strong admonition “Don’t take it apart.” I’ve always had an intense curiosity for how things work, and how they do what they do. I had to see inside to understand them. So, I took them apart. I’ve been like that for as long as I can remember. In high school, I excelled in my field of study not because I was a good student, but because I needed to know what they were talking about to satisfy my curiosity. I went to work with the Atchison Topeka and Santa Fe railroad at the age of 19 as a long-haul brakeman. I had endless hours sitting on a caboose, so I read Popular Science and Popular Mechanics magazines from front to back two or three times. Then I graduated to Family Handyman Encyclopedias, every volume, every page from cover to cover to satisfy my curiosity. Every new field I’ve entered is the same way; intense curiosity drives me to learn everything possible. Not because I want to be the best, but because I need to know everything there is to know to satisfy my curiosity. Enter the world of turning wood. There are so many different facets to learn that it seems almost endless and I love it! This is one field that I will never completely understand and that is why I’ve stuck with it for so many years. I would encourage you to venture out of your specialty and explore something you think you might not like or might be beyond your capability. I promise you will be surprised. Here are some areas to explore: • Bowls, Plates, and Platters o Kiln-dried wood, green wood, hybrid resin and wood, glued-up full-thickness blanks, segmented glue-ups, bowls from one flat board, bowls with defects left in, natural edge bowls, end-grain blanks, blanks from root balls, blanks from crotches, exotic species from far away countries, construction grade lumber, laminated beams, from tiny to enormous, just to name a few. • Hollow Forms o Tall and narrow, short and wide, small requiring special shop-made tools, large in diameter requiring captive hollowing rigs or specialty hollowing tools, vessels with openings so small that you have to hollow through the bottom, impossible hollow forms requiring trickery such as invisible glue lines to hide your methods, dyed and tinted finishes, hollow forms with lots of carving and texturing, you get the idea. • Spindles o Furniture legs and parts, wands and canes, pepper mills, fancy finials, mallets, gavels, gnomes, kitchen utensils, turned-lidded boxes, tool handles, lamps, Christmas ornaments, inside-out two-step globes, spheres, items with hand-chased threads or threads from a threading jig, baseball bats, I could go on. That should keep you busy for a while. Just when you were getting comfortable you discover there is so much more left to explore. You will never run out of new things to try. Every time I turn around, I find new challenges to solve and that is what keeps me fresh and drives me to invent and explore every new day God gives me to serve my fellow men and women. Thanks for your support and encouragement. Safe turning
- 4 replies
- pine tree
- (and 21 more)
Unbelievable, planted tomatoes last week supposed to be in the low 30's tonight! I hate this global warming! Our Patriot Turners- @Ron Altier brought us up-to-date on his epoxy finish for ornaments. Looks like he has pretty much perfected the process. Ron provides lots of tips on how he gets this mirror like finish- Several members posted in our "What's On Your Lathe" this past week. You can catchup with the new posts here- @forty_caliber added a couple and @teesquare added this beauty (and a couple of other pieces as well)- Do yourself a favor and check out all the new turning in the past week! What’s Coming Up- Click on the images for links to more information and registration For The Newbies- Thinking about turning that first bowl or maybe just need some more pointers? Kent Weakley's video could be what you are looking for. I thought this one was particularly helpful with the dialog and tips throughout the presentation. Richard Raffan puts his spin in the natural edge bowl project- Something to think about from Ron Brown's newsletter- This Is Just The Beginning It is easy to forget how much you have learned along the way. New turners also have to learn the same things we did. Or, if you are a new turner, there is much to learn. You can learn to sail in an hour – It takes a lifetime to become a sailor It is the same with learning about a wood lathe. Just like any other craft, getting the machine is only the beginning. Let’s start with the Four Pillars of Woodturning: #1-The Wood Lathe Itself There is a multitude of quality wood lathes available to fit most budgets. The most common starter lathe nowadays is a 12 to 12.5-inch swing lathe with a 1 hp variable speed motor. Many folks will keep this lathe when they upsize to a larger lathe with swings of 16 to 25” and motors up to 3 hp. #2-The turning chisels Beginning turners will see much faster results if they begin with carbide-tipped tools. A sharpening station is not required for carbide tools. High-Speed Steel tools require frequent re-sharpening and require a suitable sharpening station (more in #4) The turner must learn a whole new skill set for sharpening in addition to learning woodturning. #3-The means of holding your work Most lathes come with a spur drive center for the headstock and a live center for the tailstock. Great for beginning spindle projects like baseball bats, lamps, etc. Most lathes also come with a faceplate mainly used for turning bowls. I consider a 4-jaw scroll chuck a basic necessity. I recommend extra jaws also Pin jaws for very small spindle projects #3 or 100 mm jaws for larger spindle work and for many larger bowls. #4-A sharpening station Slow-speed grinders (1750 rpm or similar) with 8” grinding wheels made to work with High-Speed Steel are recommended A sharpening jig specially designed for sharpening lathe tools is virtually a necessity when using HSS lathe tools. Note: Using only carbide-tipped wood lathe tools eliminates the need for any kind of sharpening station and eliminates 25% of the learning curve and initial expense. Folks trying their hand at any new craft are much more likely to stick with it if they can experience early success. Easy projects to learn on are pens, small bowls, spinning tops, and small lidded boxes. Someone can successfully make all of them with simple carbide tools. Some folks only turn bowls while others only turn pens. As long at they turn something, I’m happy for them. Most folks who begin using carbide tools eventually add HSS tools and a sharpening station down the road. I recommend that route to see if they are going to enjoy turning wood and if they are going to stick with it long term. It seems like you never have every widget you want, but over time you can accumulate most of them. Remember that you can turn small items on a big lathe, but it is much harder to turn something big on a small lathe. So get ready to see that huge smile on that kid’s face from ages 8 to 88 when you show them how to make their first slimline pen or maple bowl. There is nothing like it! Expand Your Horizons- In last week's post, one of the "What's Coming Up" events were classes on turning kitchen utensils. The classes were at Highland Woodworking in Atlanta, GA. Not everyone can travel that far to learn to turn a spoon, so I found a bunch of videos, if you'd like to give it a try. If kitchen ware isn't your thing, Mike Peace demonstrates how to add an insert to a turned box New Turning Items- Sorry, couldn't find anything this week Everything Else- Started working on one of the elm rough blanks. I have enough meat on the bottom to remove some of the thickness around the mortice. It will make the thing set a little lower on a surface and lighten up the piece a bit. Safe turning
- 4 replies
- ernie conover
- ron brown
- (and 21 more)
Nice little 3" snowfall this morning. Used the snowblower for the first time this winter. Our Patriot Turners- @Steve Krumanaker Showed us a really neat beading tool handle he made. The handle serves the normal handle function while turning but Steve also designed it to act as a storage place to protect the tip during transportation- Steve created a video of the build and posted it to his YouTube channel- Instead of just making a just a handle, @HandyDan made a complete beading tool! Dan details the tool fabrication and the operation in his post- Beading tools and bowls dominated our posts this past week. @HandyDan has been turning some little bowls and used his beading tool to decorate them! He shows us what he made in this post- @jthornton continues working on his popcorn bowls segments. If you missed what JT has done, check it out here- @smitty10101 is looking for some ideas on making a hand help drill chuck. He posted his questions in our Woodturners Tips sub-section Our members have offered several ideas/suggestions. Maybe you could drop by his post and see if you can help him. @Bob Hodge added to his post on lathe tool carbide cutters. He was curious about the cost and quality of the various suppliers. Check the latest in his post and see if you can offer some suggestions- What’s Coming Up- Click on the images for links to more information and registration. For The Newbies- Neat little project from Carl Jacobson to practice spindle turning- A short video from Stuart Batty on grain direction- Want to make that turned bow even more attractive Kirk DeHeer shows what can be done in this video from Craft Supplies USA- Twice turned bowls are a great way to have finished bowls that are symmetrical and less likely to crack. Richard Raffan discusses it in this video- If you've been turning for awhile and thinking about moving up to a new lathe, Mike Peace has some things to consider- Expand Your Horizons- Richard Raffan discussed the procedure of twice turned bowls but bowls can be turned start to finish with "green" or wet wood. Alan Stratton turns this bowl and adds carved feet. I think I found what my relatives will be getting next year for Christmas- New Turning Items- You may remember that Easy Wood Tools has purchased Yorkshire Grit. Another product often used in conjunction with the grit is Hampshire Sheen. Hampshire products are featured on their YouTube channel. They are constantly adding new products. https://www.youtube.com/@HampshireSheen Their products can be ordered from https://thewalnutlog.com/ Everything Else- I see Rick is back! Rick Turns list of YouTube woodturning videos from last week- Safe turning
- 5 replies
- green wood bowl
- alan stratton
(and 26 more)
- green wood bowl
- alan stratton
- mike peace
- lathe choice
- kirk deheer
- craft supplies
- richard raffan
- inllay
- turned box
- grain direction
- stuart batty
- carl jacobson
- mushrooms
- stewart furini
- carbide cutters
- question
- lathe drilling
- bowls
- handles
- beading tool
- woodturners
- wisdom
- wednesday
- carved feet
- volcano salt urn
- hampshire sheen
- rick turns
- videos
Well, I've graduated to Headquarters Driver but still TAD to Ships Laundry and assistant Coop cleaner. Mimi goes for her follow-up 2 week appointment with the surgeon tomorrow. Probably remove the staples and start therapy as well. Our Patriot Turners- @John Morris posted an inquiry on the popularity of pen turning. Turners seem to follow trends and pens were all the rage a while back. Our turners had several thoughts on the subject- I had missed one of John's post from back in December. He wondered, if given a choice, what would be our favorite three traditional turning tools- Check out what several of our members chose and while you're there tells us what you would select- @forty_caliber finished his drying kiln. He has really thought this through and looks like the internal environment will really do the job- There's a bunch more photos in his post along with descriptions of the controls he is using- @jthornton continues to work on his chevron bowls. He took the time to perfect the accuracy and it shows in the alignment of the design- JT's post takes us along through the glue-up and turning process. Please check it out! You may remember from last week that JT's original idea for this design was to create "popcorn bowls". As with all turners, design changes are part of the game. Check out what JT decided to do with the popcorn bowl design- JT was also one of the lucky winners of our Ward 57 raffle. He tells us about the prize we won - @HandyDan posted information about a great deal from Penn State Industries and gave us a look at how he modified a set of chuck jaws to suit his needs. From PSI- The link-https://www.pennstateind.com/store/CUG3418CCX.html?utm_source=Google_Shopping&utm_medium=organic&utm_campaign=&utm_term=CUG3418CCX&gclid=Cj0KCQiAq5meBhCyARIsAJrtdr70ldWCA_YmLJ606Nrzu2Q_cEi44g6K3bWv-v2lWtTpmg-0b7wwgpAaAksvEALw_wcB @Steve Krumanaker can't wait for Christmas! He has already started on his ornaments for 2023! I love these little birdhouses. What’s Coming Up- Click on the images for links to more information and registration- Cindy Drozda does a lot of free online programs. Her only request is that you signup for her emails. Click on the image to get to the signup page For The Newbies- Keeping your lathe Morris Tapers clean is important to ensure the centers don't slip. You can buy brushes but Mike Peace shows us how to make one- Lyle Jamieson demonstrates how to create an Koa crotch bowl with undercut rim. This is a piece of beautiful wood. The techniques can be used on any species. Expand Your Horizons- From the AAW, this quite long video from a live demonstration by Al Stirt. He demonstrates carved square platters Adding threads to a lidded box can add another level of pizzazz to your turnings. The following three videos offer several considerations. @jthornton showed us his segmenting procedures. This video from Jim Rodgers shows his methods of designing, cutting, gluing and turning. Within the video, there is mention of software that can be used to assist in design and calculations. The link to WoodturnerPro software- https://www.woodturnerpro.com/ New Turning Items- Not specifically a turning item but Starbond Adhesives has released a new odorless thin CA. From their website- NO-05 Starbond Infiltrant Odorless Thin CA Glue is a 3D printer infiltrant that is fumeless, odorless, and hypoallergenic. This watery-thin adhesive is perfect for getting into those hard-to-reach hairline fractures, pores, and narrow slots. Our NO-05 is ideal for porous materials such as foam, soft wood (balsa), ceramics, unpolished minerals, and fossils. Often used as a glossy finish, this glue can be sanded, then polished to perfection! Using capillary action, the NO-05 glue works wonders on inlay applications as it penetrates and stabilizes the material. Click on the above image for the like to the product page. Everything Else- Not sure what happened to Rick Morris (Rick Turns). His weekly list of YouTube woodturning videos has been missing for a while. Hope he is OK.
- 3 replies
- wisdom
- woodturners
(and 27 more)
- wisdom
- woodturners
- pens
- traditional tools
- kiln
- shopmade
- bowl
- segments
- psi
- chuck
- modification
- ornaments
- birdhouse
- lyle jamieson
- scott hampton
- kade bolger
- turned box
- meet the woodturner
- cindy drozda
- mike peace
- morris taper bursh
- undercut rim
- al stirt
- carved platter
- wednesday
- threaded inserts
- software
- jim rodgers
- starbond
Our Ward 57 Christmas project is underway! We've made it to about 20% of the way to our goal! If you haven't donated yet, please checkout this link- Also, Easy Wood tools has added some awesome prizes to the Ward 57 raffle! And, speaking of Easy Wood Tools, we have a new member to our turning forum. Please welcome @Jordan Martindale! She is the Administrative Assistant & Sales Support person at Easy Wood Tools. Jordan is also working to expand Easy Wood Tools' involvement in the social media world of things. Our Patriot Turners- Last week's posted video on the skew prompted @forty_caliber to challenge us to show the eggs we created. @HandyDan accepted the gauntlet and posted this- Fantastic work, Dan!! Leave it to @Steve Krumanaker to create another awesome mechanism for embellishing a turning. This one is so cool! Thanks, Steve!! About a year ago, @smitty10101 posted a question about turning end grain and how to handle tear out. New member @Bill Blasic picked up with the posted and added his thoughts. Check out the additional comments- What’s Coming Up- Click on the images for links to more information/registration- For The Newbies- Mike Peace continues with his series of videos covering the use of turning accessories- Richard Raffan demonstrates turning a small cross grain box. Expand Your Horizons- We mentioned last week about Cindy Drozda's live presentation of using a camera to assist in hollowing. If you missed it, she posted the video on YouTube. Couple of weeks ago, @HandyDan was looking for a video on turning a natural edge wine glass. Not quite a wine glass but maybe this will help- What to try ebonizing? Really short video from Richard Raffan- Alan Stratton reuses a bandsaw jig to add interesting details to his turnings- New Turning Items- Niles Bottle Stoppers has added a new product. Carl Jacobson demonstrates the new bronze threaded inserts. Woodturners Wonders is having their Black Friday's sale for the entire month! https://woodturnerswonders.com/ Everything Else- Rick Turns list of YouTube woodturning videos from last week- Finished and delivered the walnut bowls. Nothing special. I really need to get more experience with the Sorby spiral/texture tool. I've watched Darryl Jones ( https://www.youtube.com/Dreadknotwoodshop ) and Jeff Hornug (https://www.instagram.com/jeffreyhornung/ ) to try and understand how they get those beautiful designs but so far mine are miserable failures. I used the sanding paste, Yorkshire Grit from Easy Wood Tools ( @Jordan Martindale ). Love the results! The lady was happy o I guess that's what matters. Safe turning
- 5 replies
- videos
- rick turns
(and 25 more)
- videos
- rick turns
- woodturners wonders
- inserts
- bronze thread
- carl jacobson
- bandsaw jig
- allan stratton
- ebonizing
- natural edge goblet
- camera hollowing
- turned box
- richard raffan
- scroll chuck
- mike peace
- vendor showcase
- end grain tearout
- cindy drozda
- eggs
- spiral jig
- skew
- ward 57
- easy wood tools
- woodturners
- wisdom
- wednesday
- walnut bowls
OK, gang, it's that time of year where we get to make a difference in a wounded warrior's life. We all have been blessed with good fortune and here is our chance to give back. Please consider donating and along the way you could win some awesome prizes! Our Patriot Turners- Just a reminder, we now have a new sub-forum for those turners using the Ringmaster tool. In addition, @John Morris added a new gallery section for you to post your images! https://thepatriotwoodworker.com/gallery/category/26-ring-master-turning/ Speaking of ringed bowls, @HandyDan showed us one of his turning. This was added to last week's Wednesdays... Dan used an idea from Mike Waldt to create a neat little box Dan received lots of positive comments and even some ideas for use- @Gerald does a show at his local Ag Museum. He was kind enough to post some images of some of the activities. Looks like the turned tops were a hit with the little ones! Gerald also gave us a heads up on an interesting video covering how to set up a new chuck. @Grandpadave52 posted an alert that the Woodturner's Monthly newsletter is available! Thanks for the heads-up Dave! What’s Coming Up- Click on the above images for links to registration and more information. This Saturday, November 20, there will be another Virtual Craft Show on YouTube. These cover a variety of skills as well as turning. For The Newbies- @Gerald's post on the chuck works in nicely with this IRD video from Mike Peace on hold work on the lathe- From the "Rebel Turner"- making a snowman on the lathe- Not sure if you will need a Facebook account to see this Tip video, on shear scraping, from Lyle Jamieson- http:// https://www.facebook.com/lyle.jamieson1/videos/320429766218298 From Capt. Eddies Worldwide Woodturners meeting, turning a mouse with Martin Clarkson- Expand Your Horizons- Here's a video, from Alan Stratton, on turning an ornament. Lots of tips and techniques in this video from "Turn A Wood Bowl" New Turning Items- Not a tool but a new site from Zac Higgins. If you are into resin casting, Zac has great tips and techniques. Check it out! OK, I know you can buy these and Cindy Drozda has a really nice one. However, Harbor Freight often offers these for free- Everything Else- Rick turns list of YouTube woodturning videos from last week- A live Q&A from Mike Waldt with a wide variety of topics- Safe turning and stay well
- 7 replies
- wednesdays
- wisdom
(and 28 more)
- wednesdays
- wisdom
- woodturners
- adopt-a-family
- wounded warriors
- ringmaster gallery
- turned box
- show
- chuck
- setup
- woodturner monthly
- scott hampton
- ornament
- dalenish
- virtual craft fest
- chuck holding
- mike peace
- snowman
- rebel turner
- turned mouse
- martin clarkson
- alan stratton
- turn a wood bowl
- zac higgins
- casting
- led hack
- rick turns
- videos
- mike waldt
- q&a
OK, gang, it's that time of year where we get to make a difference in a wounded warrior's life. We all have been blessed with good fortune and here is our chance to give back. Please consider donating and along the way you could win some awesome prizes! Our Patriot Turners- Just a reminder, we now have a new sub-forum for those turners using the Ringmaster tool. In addition, @John Morris added a new gallery section for you to post your images! https://thepatriotwoodworker.com/gallery/category/26-ring-master-turning/ Speaking of ringed bowls, @HandyDan showed us one of his turning. This was added to last week's Wednesdays... Dan used an idea from Mike Waldt to create a neat little box Dan received lots of positive comments and even some ideas for use- @Gerald does a show at his local Ag Museum. He was kind enough to post some images of some of the activities. Looks like the turned tops were a hit with the little ones! Gerald also gave us a heads up on an interesting video covering how to set up a new chuck. @Grandpadave52 posted an alert that the Woodturner's Monthly newsletter is available! Thanks for the heads-up Dave! What’s Coming Up- Click on the above images for links to registration and more information. This Saturday, November 20, there will be another Virtual Craft Show on YouTube. These cover a variety of skills as well as turning. For The Newbies- @Gerald's post on the chuck works in nicely with this IRD video from Mike Peace on hold work on the lathe- From the "Rebel Turner"- making a snowman on the lathe- Not sure if you will need a Facebook account to see this Tip video, on shear scraping, from Lyle Jamieson- https://www.facebook.com/100000091394781/videos/320429766218298/ From Capt. Eddies Worldwide Woodturners meeting, turning a mouse with Martin Clarkson- Expand Your Horizons- Here's a video, from Alan Stratton, on turning an ornament. Lots of tips and techniques in this video from "Turn A Wood Bowl" New Turning Items- Not a tool but a new site from Zac Higgins. If you are into resin casting, Zac has great tips and techniques. Check it out! OK, I know you can buy these and Cindy Drozda has a really nice one. However, Harbor Freight often offers these for free- Everything Else- Rick turns list of YouTube woodturning videos from last week- A live Q&A from Mike Waldt with a wide variety of topics- Safe turning and stay well
- 3 replies
- wednesdays
- wisdom
(and 28 more)
- wednesdays
- wisdom
- woodturners
- adopt-a-family
- wounded warriors
- turned box
- show
- chuck
- setup
- scott hampton
- ornament
- dalenish
- chuck holding
- mike peace
- snowman
- rebel turner
- turned mouse
- martin clarkson
- alan stratton
- turn a wood bowl
- zac higgins
- casting
- led hack
- rick turns
- videos
- mike waldt
- q&a
Hasn't been this busy on our forum in quite a while so let's just jump right in! Our Patriot Turners- We have had a new sub-forum added to the Woodturners Forum. The Ringmaster sub-forum is dedicated to those makers who create bowls using the Ringmaster method. You can find it listed under the main Woodturners Forum- https://thepatriotwoodworker.com/forums/forum/98-ringmaster-turning/ Let's see some of those beautiful creations!! @Gerald gave us a look at a commissioned bowl he is in the process of turning- Gerald tells us about the species and more in his post as well as a bit about his "new" kiln- Gerald also posted an interesting article by Ron Brown providing some additional thoughts on Carbide tipped tools. We have had several insightful discussions here on the forum comparing traditional and carbide tools. @FrederickH posted a question to the group about using a fluted parting tool. Several of our members provided their insights. If you can help out Rick, give him your thoughts at- One of our newer members @adot45 gave us a look at his latest fantastic turning. Please see his post and welcome him to the forum! More about Dave and some additional images are in this post- And more here- Even @smitty10101 is getting into the stacked ring bowls! He is looking for information about a thin parting tool. If you have a source or have made such an animal, why not share your knowledge with him- @forty_caliber and family have taken some friends under their wing. As a way to help ease the sorrow of a loss, he has turned a memory box for a family member- Forty shows us some additional images in his post. Note the laser burned embellishments! Last week we had a question about bowl saver tools. Not sure this is what the author had in mind but @forty_caliber found one that will certainly doe the trick! @forty_caliber's post from last week generated additional input that might be useful for those following the discussion of hollowing tools- Or resident Christmas ornament designer has done it again. @Ron Altier turned this gorgeous little jewel- Ron explains his design idea in his post We had lots more from our members on @FlGatorwood's little train that could. If you missed it, here's where the discussion left off- @bradleyheathhays's post from last week also continued to receive comments and inputs. Here is the entire thread location- @Grandpadave52 gave us a heads up on the contest being run by Woodworker's Journal. The challenge was to turn a honey dipper. Not sure if our own @Steve Krumanaker entered the contest or he decided to let someone else win first place . https://www.woodworkersjournal.com/honey-dippers/ What’s Coming Up- Women In Turning in conjunction with the AAW presents Kailee Bosch, Rebecca DeGroot, and Marjin Wall to give short presentations about their work, ideas, and inspirations, followed by a group discussion and Q&A, led by artist and moderator Hayley Smith. The event is free and open to the general public. For registration- https://www.woodturner.org/Woodturner/WIT/WIT-Home-Page.aspx?WebsiteKey=c9100f02-c77e-4177-a9bc-7d3eb0216238&hkey=7f6a65b2-ec98-472f-a7b6-2ac573f7258d&New_ContentCollectionOrganizerCommon=8&_zs=lMMTa&_zl=02Hp2#New_ContentCollectionOrganizerCommon For The Newbies- Nice little project for the coffee lover in the family. If you prefer a heavier version, Ruth Niles, https://nilesbottlestoppers.com/ , has some stainless steel kits. https://www.woodworkersjournal.com/project-classy-espresso-tamper/ Expand Your Horizons- Turning demo from Mike Waldt- New Turning Items- Tim Yoder has an improved hollowing rig- The folks at Woodturners Wonders have some special, short time deals on grinders- https://woodturnerswonders.com/pages/grinders Everything Else- Rick turns list of YouTube woodturning videos from last week- Safe turning and stay well
- 8 replies
- grinders
- (and 26 more)
Wow, just had the last remnants of tropical depression Fred move through. Got a little over 1.5" of rain in less than an hour but no wind or other damage. Our Patriot Turners- We haven't heard much from @Ron Altier, but he has turned a beautiful ornament made from a matched grain glue up- Here's his post explaining what he did! @Gerald belongs to the Magnolia Woodturners. They often have competition turnings to challenge their members. Gerald showed us a box he turned for the upcoming meeting. In his post, Gerald tells us a little about the techniques he used to create this lovely item! @AndrewB continues working on his Dragon Egg. In this post he shows us the finished sanding/polishing. Your turners gave him lots of kudos on his work- In the Patriot "What's On Your Weekend Agenda?" @forty_caliber posted pictures of a couple bowls he is in the process of turning. This one with some brass inlay- And this one, which has a really neat shape- There were lots of comments and questions following each of Forty's posts. Check out what our members said following each of the entries. What’s Coming Up- Cindy Drozda has and IRD coming up. Click on the above image for the link to registration. Several AAW events. Please click on the images for links to registration For The Newbies- Woodturning Monthly is available from The Woodworker's Journal- https://www.woodworkersjournal.com/woodturning-monthly/?utm_medium=email Bottle stoppers are nice gift projects and can supplement your inventory if you do craft shows. In this video, Mike Peace makes a really nice display piece for those stoppers- If you are looking for a source for bottle stoppers, check out https://nilesbottlestoppers.com/ @Gerald showed us a turned box he made. Here's a recent video from Craft Supplies USA demonstrating the techniques for turning a similar box- Expand Your Horizons- Jim Rodgers has a 2 part video on making open segmented turning. He demonstrates the glue up techniques and shop made jigs that assist in accurate, repetitive steps. And- If you are a member of the AAW, a recent email and magazine articles deal with color on turnings. Here's an excerpt from the email- Considering Color Adding color to woodturned objects is a fairly recent phenomenon. And, according to the late collector Arthur Mason, "There is no question that color can be a valuable design feature in wood art and that it can enhance the beauty and appeal of the work. But it also can diminish the pleasing effects of the natural features of wood. An artist’s decision to use color results from balancing these considerations, as well as from his or her ability to use color to an artistic advantage."* While applying color may not be for everyone, it can make the impact of a piece more dramatic and expand the artistic possibilities for a turned work. This week’s picks encourage you to consider and explore adding color to your work. New Turning Items- Sorry, couldn't come up with any new stuff. If you checkout the "Vendors Showcase" in the What Coming Up section, there are some hints as to what we can expect. Everything Else- Rick Turns list of last week's YouTube woodturning videos- I received a request to turn some bowls for a lady with whom I used to work. They supplied the wood (flame box elder and walnut) got a few finished, still have 2 to go- So far, I am really liking the Yorkshire Grit and Hampshire Sheen. My biggest concern was if finish would "stick" to the Yorkshire Grit finish. I used a piece of hard maple as a test subject. Following the instructions for surface prep- sanding to 240, using sanding sealer and then "sanded" with the Yorkshire product. From left to right, one application and no buffing- Mineral oil/beeswax, acrylic paint, gloss brushed on lacquer, gloss wipe on ploy, gloss spray on lacquer. These are the finishes I use most often. The film finishes seem to be unaffected by the sanding paste. The oil/beeswax doesn't penetrate deeply into the wood. A better test will be something dark like walnut. The acrylic paint would definitely need several applications and then a top coat for protection. Safe turning and stay well
Heads Up! The Patriot Fundraiser has been extended for a few days. If you haven't had the opportunity to get those raffle ticket, you're in luck! Check this post- Sorry about no post last week, we were at the shore last week celebrating our 45th wedding anniversary, Our Patriot Turners- @RustyFN gave us a tip on where to purchase some upgrades for a vacuum chuck as well as some other great specialty lathe drive accessories- Check out their website at https://www.rubberchucky.com/#/ Rust also added a new piece of equipment to his turning arsenal- He received lots of positive comments on his acquisition. Check out his post- @AndrewB is finishing up a pepper mill. He is really getting to be a professional at cranking these out Check out his post for some more images of his progress- We don't hear much from @Cliff but when we do, he is always looking at some thing interesting. Recently he is considering making a thread chasing jig for his lathe. Hope he posts it when it's finished- It may be the beginning of summer but that isn't stopping @Ron Altier from making Christmas ornaments! Please hop over to Ron's post for a description of what he did- Ron also posted a picture of a bowl he found at the thrift store. Someone put a lot of work into this turning! Please see Ron's post for additional photos- Speaking of bowl finds, @Steve Krumanaker came across a unique bowl while on vacation- In his post, Steve tells a little more about this one- @forty_caliber put his Longworth chuck to good use in making a project for his daughter. He tells us a little more about this sweet segmented turning in his post- @Gerald got a great start on a bowl being turned from a root ball. The colors in this are fantastic- Gerald shows us some more images and explains some of what he has done in this post- Gerald provided us with a way to keep up with the Magnolia Woodturners Club, of which he is a member. This is a Facebook page. Facebook has become a popular way for woodturners to communicate and display their turnings. You can see some of the awesome turnings produced by the club's members by following the "Visit Website" button. @HandyDan helped out a friend by reproducing some chair spindles. These sure are perfect replicas! Check Dan's post for all of the kudos he received from our members- Although posted in our general woodworking forum, the content applies to all aspects of woodworking. @kmealy gave us a link to an article on pricing your work, originally published in Fine Working. A great discussion ensued. Thanks, Keith! New member @woodburner59, gave us a his first impressions of a new book he has added to his library. We are looking forward to seeing some of the turnings Scott produces. What’s Coming Up- With the AAW Symposium coming up, I've been trying to provide the latest information. These two items are related to that symposium. Click on the images for links to more information- Vendor Showcase! Free Zoom meeting! This one is a little bit in the future- Do you have a special interest and want to see/do an interactive demo? Captain Eddie and the World Wide Woodturners group is looking for ideas- For The Newbies- Another Mike Waldt video aimed at the beginning woodturner. As this is a live demo, it is quite lengthy but has a lot of great tips- From Woodworker's Journal, a nice project by Ernie Conover turning a tray- Expand Your Horizons- A short video on making a lamp from green wood, from Woodworker's Journal Captain Eddie was one of the early experimenters with CA glue as a finish. Capt. recently added a video on tips and hints of CA finishes- New Turning Items- Didn't come up with anything, although, the Rubber Chucky website Rusty mentioned does have an alert on their homepage to watch for some new products. Everything Else- Rick Turns You Tube woodturning videos for the past 2 weeks- Before we left, I did have a chance to finish up the little spalted elm bowl. I turned it to the finish dimensions and then left it dry in my little air kiln ala Rick Turns. Need to get some better picture- It's been warm here so I spent time in the cool basement shop. Got started on a large cherry bowl that had bee drying in the air kiln- Had to make a run for some supplies today. Mimi said she was going to vacuum the pool. This is what I found when I got home- They stayed most of the afternoon! Safe turning and stay well
- 8 replies
- raffle
- vacuum chuck upgrad
(and 24 more)
- raffle
- longworth
- pepper mill
- thread chasing
- ornament
- bowl
- segmented
- coconut
- turned box
- walnut root ball
- magnolia woodturner
- spindles
- richard raffan
- book
- aaw symposium
- vendor showcase
- cindy drozda
- virtual woodworking
- captain eddie
- ca finish
- mike waldt
- ernie conover
- tray
- turned lamp
- videos
My daughter's birthday is coming up and she requested a pencil box for her desk. It must be large enough to accomodate pencils, pens and markers.( Plus who knows what else.) She wanted it colorful, so I made it of cedar and maple that I already had. I put felt on the bottom of the inside and outside base. Cutting those angles is always a challenge, followed by glue up and turning it round. I don't use aromatic Cedar much anymore, but when I do I use a lot of caution, a good mask and plenty of vacuum.
- 18 replies
- lathe
- turned box
(and 3 more)
Haven't had a lot of time in the shop the past few days but I did get two more boxes done. These are also based on Liam O'neill's "crooked grain box" design. I like the grain in both of these but especially the one on the right. Both spalted beech and walnut. Four more to go for this project but I have the demo for the next meeting, figure I may as well do it on one of these. Steve
- 8 replies
- spalted wood
- spalted beech
(and 5 more)
