Showing results for tags 'fund raiser'.
We only have about 3 weeks left to get your raffle tickets for the Summer Fund Raiser. This fund raiser will help keep our site alive and allow us to help veterans. Please Donate! Our Patriot Turners- @Turn n Learn posted some more items he scored with his lathe and wondered what some were used for. New comments and items begin here- @Gordon made a cool jam chuck using some neoprene rubber- He posted more images and the source for the rubber in his post- @Fred W. Hargis Jr gave us a heads up for an awesome sale price on new Jet and Powermatic lathes- Check his post for the link to Craft Supplies USA If you aren't sure what to look for in that new lathe, this video from Popular Woodworking may help- From our "What's On" posts, @BuckeyeHomestead posted a picture of his NEW Jet lathe and its first project That's an awesome lathe! @RustyFN had some difficulty with buffing out a finish. He explains the problem in this post- Check out what Rusty said and maybe you have some tips that will help him. What’s Coming Up- Click on the images for links to more information and registration. For The Newbies- Sam Angelo posted a nice spindle gouge tutorial Tomislav Tomasic created a great video on tips for turning. His videos have excellent closeup of gouge positions. From Popular Woodworking, a written tutorial on lathe tool sharpening- https://www.popularwoodworking.com/techniques/sharpening-for-woodturners/ And another on scrapers https://www.popularwoodworking.com/tools/the-woodturning-scraper/ Expand Your Horizons- The theme for this week is embellishing- Mike Peace bleaches and burns turning to add neat effects- From Popular Woodworking- https://www.popularwoodworking.com/projects/square-platter-with-textured-rim/ If you are looking for a nice gift project, Jimmy Clewes' coffee scoop tutorial might just be what you want- https://www.popularwoodworking.com/projects/turned-scoop-with-pewter-finial/ Turning Time With Easy Wood Tools- Over the past several weeks, we have been showcasing the individual Easy Wood Tools. One thing that should be noted is that all Easy Wood products are made right here in the good ol' U. S. of A. Fascinating video of the manufacturing processes- All of the Easy Wood products are available directly from their home base in Lexington, KY and on Amazon. However, some of the best prices can be found by cruising their social media pages for special sales from woodworking retailers i.e. Woodcraft etc. For the month of June, a few - If you are thinking about attending the St. Paul, MN symposium, Easy Wood Tools will be well represented- And another shameless self promotion- @Jordan Martindale New Turning Items- Everything Else- From Ron Brown's Newsletter: Good Enough Perfection is often unattainable, and just as frequently, unnecessary. I hear from turners all the time who proudly sand salad bowls to 4,000 grit. Anything above 320 grit is just a waste of time and effort for most wood projects. However, acrylic and resin projects may well benefit from using abrasives up to 12,000 grit. The caution here is not to get bogged down in the last 2 percent trying to make something perfect when 98 percent of the work is very close to perfection and Good Enough. When I used to build custom furniture from cherry, walnut, oak, and hardwood plywood, I quickly discovered that stopping at 220 grit produced excellent results. Especially when covered by sanding sealer and pre-catalyzed lacquer as finishes. It’s true, sometimes less is more. The secret was to be careful with each finer sanding grit, ensuring that all scratches from the coarser grit were entirely removed. That is where patience really pays off, as I deliberately go over the entire surface, then examine my work with a raking light source before moving up to the next finer grit. Most folks don’t realize that excessive sanding with fine-grit paper creates heat that releases and then hardens the lignin in wood, often resulting in a splotchy finish. The finishing material will not be able to penetrate the surface evenly, and it looks awful. If you’ve ever blown up a bowl, it usually comes from making one last cut to get the finish just right and the walls as thin as possible. You forgot that wood moves and bowls can go out of round as you turn, even if they’ve been drying for months. As wood is removed, the moisture content can change, causing the thin walls to warp, or harmonic vibration to set in. That final cut produces an unexpected catch and bang! Fresh bowl pieces are lying around the shop once again. The problem with patience is that it takes so long. My projects rarely turn out exactly like I see them in my mind. My hope is to bring them close to my idea of perfection and bring them to the “Good Enough” stage of completion. I know some of you think I’m smarter than I actually am. What you see are the results of persistence, patience, and starting over many times before I was able to show you a finished version. You will never see the eight failures that came before. Remember how WD-40 got its name. I would rather have you do something slowly and well than do it quickly and poorly, sometimes referred to as Half-Fast. Many years ago, I got tired of hearing myself say “Oops! I didn’t see that before, and now it’s too late to fix it.” I am deliberate in my inspections before proceeding to the next step. It is always easier to fix it then, rather than several steps later. Safe turning
- 5 replies
- wednesday
- wisdom
(and 32 more)
- wednesday
- wisdom
- woodturners
- raffle
- fund raiser
- questions
- jam chuck
- neoprene
- lathe sale
- lathe selection
- buffing
- aaw symposium
- st.paul mn
- cindy drozda
- tool talk
- zoom
- threads
- sam angelo
- spindle gouge
- tomislav tomisec
- tips
- popular woodworking
- sharpening
- scrapers
- mike peace
- embellish
- bleach
- burn
- jimmy clewes
- coffee scoop
- easy wood tools
- ron brown
- newsletter
- sales
Please remember that our Christmas project fundraiser is in progress. If you haven't gotten your raffle tickets yet, don't put it off any longer. "We have raised $911.51 thanks to all our members and visitors alike! Great job folks! I'd like to make a plea to you all. Since our raffle goes all the way up to January 3rd, 2025, we'd like to get the bulk of the proceeds to our adopted Christmas family before Christmas, and then all the proceeds collected after the first distribution to the family, then proceeds collected up to the 3rd will be distributed to them at raffles end. So they'll have a wonderful Christmas, and a Happy New Year. Our target date of gift card delivery is December 20th. So we'd love to have most of the funds in place by then." Our Patriot Turners- @Fred W. Hargis Jr posted an ornament he finished. This cute little fellow will surely look good hanging on the tree! Fred was kind enough to provide a link to the Craft Supplies USA video he used as his inspiration. I've also added the YouTube link here- We have had more additions to our continuing "What's ON/OFF the lathe" From ON- The beginnings of a Calabash bowl- More images and description can be found at- And from OFF @Gerald posted a beautifully shaped hollow form In this post, he tells us more about the piece of wood and the purpose of the turning- What’s Coming Up- Click on the images for links to registration and more information- If you missed Cindy Drozda's tool talk last Friday, here's a replay from YouTube- For The Newbies- More on sharpening from Sam Angelo. This time he demonstrates spindle gouge grinds Expand Your Horizons- Fred Hargis showed us a gnome he turned from a video by Craft Supplies USA. Gnomes and snowmen currently seem to be very popular. How about combining a snowman and a candle? New Turning Items- Something new from Tim Yoder- A short video from Tim on these- And a link to Tim's Tools- https://wtwtim.com/tims-tools-1/ Everything Else- Safe turning
Please checkout the update on our Operation Help a Hero Christmas Project Fundraiser 2024. There has been an additional prizes added to the raffle! Our Patriot Turners- Please welcome new turner @DE Turner! He sent me a couple of pictures of his beautiful work- Say Hi and encourage him to post more of his pieces! In our site's "Good Monday Morning..." forum, @Gerald posted a cool Christmas tree turning- His post can be viewed here- We have had a few additions to our continuing topic of "What's Off..." this past week! @User74 and @calabrese55 both added turning projects- Catchup on all of the new projects at- What’s Coming Up- Cindy Drozda's tool talk "I'm looking forward to spending some time online with you at my free Tool Talk Livestream. It's this Friday, December 6th, at 2pm Eastern (19:00 UTC)" https://streamyard.com/watch/6QBkMFj5Crnh Live Interactive Remote Demonstrations December 10, 2024, Tuesday, 7:00-9:30pm, Eastern Time, Details of Hollow Form Turning https://lylejamieson.com/product-category/live-interactive-remote-demonstrations/ For The Newbies- We post a lot of the activities from Cindy Drozda. This past week she shared a tour of her shop. It's great to get to see how other turners' shops are equipped and laid out- Mike Peace posted a video discussing techniques for drying wood for turning. This video from Mike Mahoney, made available through Fine Woodworking Magazine, shows how to sharpen various woodturning tools. I don't think you have to subscribe to the magazine to view the video. https://www.finewoodworking.com/2015/03/25/episode-2-sharpening-turning-tools Expand Your Horizons- With Christmas fast approaching, a couple of season related turnings. One from Alan Stratton and one from Sam Angelo. The "4-Ways" collaboration turning series posted these videos. This month's concept is to demonstrates how to turn an enclosed vessel with a height greater than its diameter, using readily available tools. New Turning Items- Not new but on sale- Bowlsaver Max4 Coring System Save $100.!! https://woodturningtoolstore.com/product/bowlsaver-max4-coring-system/?receiptful=674cfd640a220e4070fe56ec&utm_source=CM Commerce&utm_medium=email&utm_campaign=newsletter-408&utm_term=newsletter&utm_content=other&receiptfultype=newsletter Everything Else- Safe turning
- 4 replies
- wednesday
- wisdom
(and 25 more)
- wednesday
- wisdom
- woodturners
- fund raiser
- raffle
- operation help a hero
- new member
- christmas tree
- pipe
- bowl
- rolling pin
- cindy drozda
- tooltalk
- shop tour
- mike peace
- wood drying
- mike mahoney
- sharpening
- ornaments
- alan stratton
- sam angelo
- 4-ways
- richard raffan
- tomislav tomasic
- bowl saver
- lyle jamieson
- hollow form
Just days left in our fund raising raffle. If you haven't picked up your tickets for some really special prizes, check out- Every little bit helps keep our site alive! Our Patriot Turners- @calabrese55 is getting rid of his extensive stash of pen making supplies. If you are looking for kits or pieces, see his post- @Gerald and @kreisdorph added some gorgeous items to our "What Finished" post. Gerald's project is for an AAW swap he participate in- And, Kent's are a couple of turned Chalices made from elm. This is where the new entries begin- What’s Coming Up- Cindy Drozda and Todd Raines will host a free Sharing Session this Friday, August 2nd, at 2:00pm Eastern (18:00 UTC). It's FREE, live, and interactive on Zoom! https://www.cindydrozda.com/html/Signup.html https://woodturningtoolstore.com/ For The Newbies- Woodworker's Journal published their monthly issue of the Woodturning Monthly. Lots of neat ideas and projects. Here's the link- https://www.woodworkersjournal.com/woodturning-monthly/?utm_medium=email Expand Your Horizons- Richard Raffan turns some "twig pots"- New Turning Items- OK, I know this is a stretch, but hey, I'm trying Sketchup is not generally thought of as software used by turners. This video demonstrates that the software is versatile enough to create elaborate shapes for the turner. For a smaller learning curve, this free software is available. Lathe Magic can create visual, 3D renderings of turning shapes. Free download is available here- https://www.shapemagic.com/lm/index.htm Everything Else- The rolling pin workshop is done. They made about 21 Celtic knot rolling pins of various shapes and designs. We started with this- This was one of the finished pins- Safe turning
Our Summer fund raiser is still happening! Remember, this is to provide funds for the site operation and unexpected expenses. Our Patriot Turners- @AndrewB posted a couple of new items he is working on, check out his posts! And- We had a post on our "What's Off Your Lathe And Finished" by @kreisdorph. That Black walnut sure is lovely! What’s Coming Up- Cindy Drozda posted the video of her live tool talk event from last week. Always some great tips! Cindy and Todd Raines will be hosting a Woodturning Sharing event on August 2, 2024 https://community.woodturner.org/events/event-description?CalendarEventKey=22337b94-ff08-4811-a511-019074232f14&Home=%2fevents%2fird-demonstrations&_zs=ceDib&_zl=EQRA4 https://community.woodturner.org/events/event-description?CalendarEventKey=48fd6950-9604-44ed-b3d9-0190c7ad94e2&Home=%2fevents%2fird-demonstrations&_zs=ceDib&_zl=AQRA4 https://mawts.com/ For The Newbies- @AndrewB posted about learning to turn bowls. Member @Gerald was kind enough to locate a video from Stuart Batty on the subject. Reposting Gerald's link here- Also, here's a video from Kent Weakley on the correct use of the bowl gouge- Some great tips from Tim Yoder! Check out the one on turning speed. Expand Your Horizons- Do you do craft shows or just looking for some new ideas for turnings? Mike Peace has two neat turned "animals" that might interest you. New Turning Items- A couple of weeks ago, we posted a video from Todd Raines demonstrating the Robust "Tru-Arc" tool. Sam Angelo gives us his impression of the tool in this video- Everything Else- I did an Easy Wood Tools demonstration for The Catoctin Area Turners' club last Thursday in Leesburg, VA. I thought @Gerald would be interested in their Beads of Courage boxes shown during the show and tell portion of their meeting Well the rolling pin blanks are finally finished- yesterday! The demo/workshop is this Saturday. 24 blanks here and 2 more at the workshop location. I make my blanks 22" long and 2 x 2" square. The lathes available for the workshop max out at 15" and 17" so angles had to be adjusted for a pleasing look when turned. Also some of the supplied blanks were smaller that 2 x 2 all that required different cutting angles. Some blanks were larger (almost 3 x 3) and my jig for cutting the angles wouldn't let the saw blade reach a high enough point to cut the proper insert slots. Had to design another jig for those blanks. Now on to Mimi's honey-do list that has been expanding exponentially! Safe turning
- 2 replies
- bowl turning
- kkent weakley
(and 28 more)
- bowl turning
- kkent weakley
- stuart batty
- midatlantic symposium
- globe ornaments
- turned
- scott hampton
- sharing
- todd raines
- tool talk
- cindy drozda
- natural edge
- question
- laminate
- bowls
- fund raiser
- raffle
- woodturners
- wisdom
- wednesday
- bowl gouge
- tim yoder
- tips
- mike peace
- owl
- elephant
- sam angelo
- tru-arc
- beads of courage
- box
We have a little over a month left in our summer fund raiser drive! Some great prizes from our very generous sponsors. Get your raffle tickets here- Our Patriot Turners- Please welcome back a forum member who checked in this week. Great to have @AndrewB posting again and getting all of us caught up with what he has been doing! @John Morris posted about a turning artisan he follows, Jarrod Dahl. Mr. Dahl's video created a question that got lots of responses from our group. Jump over to John's post and see if you can add more to the conversation- Another great week for our "On/Off Your Lathe" running post! From "On"- @Gerald's spalted maple plate. Beautiful wood and lovely shape! And from "Off"- Gerald showed us his finished sculpted lidded vessel. Talk about a beautiful work of art!! I can't imagine how much sandpaper he must have gone through!! Our gang gave him a huge thumbs up on this one! What’s Coming Up- Click on the images for links to more information and registration. Cindy Drozda's Tool Talk this Friday Cindy and Todd Raines Zoom Sharing Meeting- For The Newbies- When it comes to bowl turning, the grinds on a bowl gouge can be confusing. Which one is best? Which one should I use and where? Sam Angelo has some information that may help you answer these questions- Turning a bowl, box or any hollow type form requires the turner to know just how deep into the wood they can go before making the inside larger than the outside. Richard Raffan shows us how to make a simple tool to help with judging the depth. When hollowing out turnings with straight sides (i.g. boxes), the box scraper can help to make more precise cuts. Mike Peace takes a look at some of the advantages and disadvantages of some of the tools- Expand Your Horizons- Don't have a nice piece of wood to turn a larger project? Alan Stratton has the answer- New Turning Items- Woodturners Wonders has a sale on lighting. https://woodturnerswonders.com/collections/lamps?_kx=gV5SF2As_3IwtBi5TrpHVQM0F3UvGVbQKzhWGippDlk.VJvU8R Everything Else- Still working on those rolling pin blanks for a demonstration. Received the last of the wood an hour ago. Going to be in Leesburg VA at the Catoctin Area Turners club tomorrow evening for an Easy Wood Tools product demonstration ( @Jordan Martindale ) Safe turning
- 5 replies
- woodturners wonders
- cut offs
(and 25 more)
Please don't forget our summer fund raiser is in progress! Check here for more information and the raffle tickets- Our Patriot Turners- Again, THANKS to everyone who takes the time to show us all what you have been working on. We've had several additions to our "What's On Your Lathe" post. @User74, @Gerald and @kreisdorph posted this week! The new items start here- What’s Coming Up- If you missed Cindy Drozda's tool talk last Friday, she has it loaded up on her YouTube channel. This discussion was on Box Hollowing Tools- Todd Raines, from the Woodturning Tool Store will be demonstrating the Robust Tru-Arc tool- Registration and more information can be found here- https://woodturningtoolstore.com/live-stream-woodturning-with-tod-raines/?receiptful=668c77471ee11bbc67cec8e6&utm_source=CM Commerce&utm_medium=email&utm_campaign=newsletter-363&utm_term=newsletter&utm_content=other&receiptfultype=newsletter Cindy and Todd will be doing a Zoom Sharing event on August 2, 2024- Registration for the sharing event- https://community.woodturner.org/events/event-description?CalendarEventKey=22337b94-ff08-4811-a511-019074232f14&Home=%2fevents%2fird-demonstrations&_zs=ceDib&_zl=5jU94 For The Newbies- Lyle Jamieson's Tuesday Tip is about removing that little nub from the inside of a bowl- Anxious to turn that first bowl. It doesn't have to be a monster! In fact small bowls are very useful as Kent Weakley demonstrated- Another nice little hollowing project from Mike Peace that doesn't require a large hollowing system. Couple of neat tips included! Expand Your Horizons- Now that you have that laser, how can you use it with your turning projects? Carl Jacobson has some ideas- New Turning Items- Not any new products but Woodturners Wonders has revamped their website. https://woodturnerswonders.com/ Everything Else- I know it seems like I don't do any turning but I have a valid excuse. A month ago, I committed to creating rolling pin blanks for the local woodturning club. They've been a little slow in getting me the remainder of the materials. My shop is a "one man" shop- literally!! Only one person can fit at a time! Now I have everything waiting for more materials as time is critically short. Also, a little over a week ago I did an Easy Wood Tools demo and will be doing another in about a week and a half. All my stuff is packed for transport and not easily accessible. In the middle of all that, I'm trying to work on a new jig (ala Alan Stratton) for the bandsaw. Safe turning
- 3 replies
- hollow
- mike peace
- (and 20 more)
Happy Birthday, America! Here's how it really happened! Our summer fund raiser is underway! If you haven't gotten your raffle tickets or checked out the great prizes, see the following post!!!! Our Patriot Turners- We've had some additions to our continuing post of "What's On Your Lathe" @Gerald and @kreisdorph both added images of what they have been up to- Catch up on all this week's action starting here- What’s Coming Up- It's been awhile since we've done a recap of the upcoming AAW events. Click on the images for links to registration and more information. Southwest Florida For The Newbies- Mike Peace posted a video to help turners understand the various methods and tools for center finding. Expand Your Horizons- Last week we posted a video on turning a trembleur. I guess the YouTube algorithm was watching me because this one showed up a couple of days ago. It's really neat how the turners create string steady rests- Carl Jacobson turns a cool paper clip holder- The collaboration between the "4 Ways" turners continues- New Turning Items- I received an email from Wood World of Texas covering their Kitchen Essentials products/kits. Check out their products here- https://woodworldtx.com/ Everything Else- Pulled this from a Woodturners Wonders email. Carbide vs. traditional HSS tools. This week, we want to share some helpful information so you can choose the best turning tool option for you. Additionally, we are offering a 15% discount on Sorby, Crown Hand Tools and Easy Wood Tools! * The discount will be reflected in the cart * Choosing the Right Turning Tools: Traditional vs. Carbide Woodturning is a craft that blends artistry with precision, and selecting the right tools is crucial for achieving the best results. At WoodTurners Wonders, we offer a wide range of turning tools from renowned brands such as Robert Sorby, Crown Turning Tools, Easy Wood Tools, and Yellowhammer Turning Tools. Whether you're a novice or a seasoned turner, understanding the differences between traditional and carbide turning tools can help you make an informed decision. Here are some factors to consider when choosing your turning tools, along with a comparison of the pros and cons of carbide and traditional tools. Factors to Consider When Choosing Turning Tools Skill Level: Beginners may find carbide tools easier to use due to their low-maintenance nature, while traditional tools offer greater versatility and control, which can appeal to more experienced turners. Maintenance: Consider how much time you're willing to invest in maintaining your tools. Traditional tools require regular sharpening, while carbide tools typically only need occasional replacement of the carbide inserts. Material and Projects: The type of wood you work with and the projects you undertake can influence your choice. Traditional tools are often preferred for fine detail work, while carbide tools excel in roughing and removing large amounts of material quickly. Budget: Evaluate the initial cost and the long-term investment. Traditional tools might have a lower upfront cost but require ongoing investment in sharpening equipment, whereas carbide tools have a higher initial cost but lower maintenance expenses. Comparing Traditional and Carbide-turning tools Traditional Turning Tools Pros: Versatility: Traditional tools come in a variety of shapes and sizes, allowing for a wide range of cuts and finishes. Control and Precision: Skilled turners can achieve intricate details and smoother finishes with traditional tools. Lower Initial Cost: Typically, traditional tools are less expensive upfront compared to carbide tools. Cons: Maintenance: Requires regular sharpening, which can be time-consuming and necessitates additional equipment like sharpening stones or grinders. Learning Curve: Mastering traditional tools takes time and practice, as each tool and cut requires different techniques and angles. Safe turning
- 4 replies
- carl jacobson
- trembleur
(and 33 more)
- carl jacobson
- trembleur
- center finder
- mike peace
- todd raines
- cindy drozda
- taw
- southwest florida
- virginia woodturning
- northwest washingto woodturner
- association of woodturners
- mid atlantic symposium
- ornamental turners
- swat
- chicago
- kirk deheer
- aaw
- bowl
- carved
- hollow
- fund raiser
- raffle
- woodturners
- wisdom
- wednesday
- paper clip
- 4 ways
- tomislav tomasic
- richard raffan
- sam angelo
- woodworld of texas
- kitchen essentials
- bud vase
- carbide vs hss
The summer community fund raiser has begun! Our very generous sponsors have donated some awesome gifts for the raffle winners. Here's where you can participate- Our Patriot Turners- @RustyFN gave us a look at some cedar he scored. Looks like some awesome turnings and lovely fragrance filling his shop- @Fred W. Hargis Jr finished up his "learning experience" and posted images of what he had done. Our turners had good things to say about Fred's experience. His new information picks up here- Fred also posted the images of his finished, turned box. The update is here- Our What's On Your lathe had some activity this past week. There were some comments on past activity and @teesquare and @Geraldposted images of urns they have turned. These urns are incredibly beautiful and have such interesting stories about their creation. Catch up on all of the activity and see more images at- What’s Coming Up- If you missed Cindy Drozda's live Tool Talk, last Friday, it is available on YouTube- Then, this Friday, June 28, Cindy and Todd Raines are doing a live sharing event. Sign up for this free zoom at- https://www.cindydrozda.com/html/Signup.html For The Newbies- From Mike Peace, some information about turning catches, fails and some humorous bloopers. Mike explains why things went wrong. Expand Your Horizons- Lyle Jamieson's Tuesday Tip gives us his thoughts on the bandsaw for making round turning blanks. Alan Stratton demonstrates turning a Trembleur- Jim Rodgers turns a square platter. The corners droop down to become feet. Keep the band aids close at hand! New Turning Items- Couldn't find anything this week. Everything Else- I've been preparing French rolling pin blanks for the local turning club. About 20 blanks are needed of several different lengths and diameters. Ran out of stock. Started gluing what I could cobble together. Safe turning
- 4 replies
- footed platter
- jim rodgers
- (and 20 more)
ONE DAY LEEFT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Our Patriot Turners- @Gerald started a new topic for our turners! I hope we can make this one as popular as the one @RustyFN started for showing what's on our lathes! So far we've had two members add items. Let's make this topic sail to the "Most Posts" list! Our other continuing topic of "What's On Your Lathe" also had activity! @RustyFN and @forty_caliber both added some of what they are working on! Check out this post for more images! @forty_caliber also posted a nice little "catch-all" bowl. I think these bowls are so useful. Not too large to take up a lot of space but large enough to hold most small items. Great for pocket dumps! See more images here- What’s Coming Up- Click on the images for links to more information and registration Well, it happened last week, but if you missed it, Cindy has posted the video- For The Newbies- How fast should I turn is a question we often hear. There really isn't a hard and fast rule. Ron Brown has some thoughts in this video "short"- Mortice or tenon to attach the bowl to the lathe. Ask 10 woodturners and you'll probably get at least 15 different answers. My personal choice in a recess and use it to incorporate the foot. Here's what Kent Weakley thinks about it- Of course, if you don't have a chuck, there are other ways to attach a bowl blank to the lathe. Sam Angelo shares his thoughts on some methods of securing that blank- Expand Your Horizons- It's just past the first of the month and the videos from "4 Ways" is available. This month Richard Raffan, Tomislav Tomasic, Sam Angelo and Mike peace each turn their version of a natural edge bowl. Tim Yoder turns a beautiful Flame Elder platter. He eve uses some of his Easy Wood Tools in the process! It is not too soon to start thinking about making Christmas ornaments. Alan Stratton creates one that is out of this world! Craft Supplies USA has an idea for something that the ladies in your life might enjoy- New Turning Items- Ron Brown has a new Ladle Chuck System- Safe turning
- 3 replies
- ornament
- alan stratton
(and 27 more)
- ornament
- alan stratton
- platter
- tim yoder
- 4 ways
- mike peace
- tomislav tomasic
- richard raffan
- sam angelo
- screw chuck
- faceplate
- kent weakley
- recess turning
- ron brown
- lathe speed
- tool talk
- demo
- cindy drozda
- blanks
- bowls
- turnings
- fund raiser
- raffle
- woodturners
- wisdom
- craft supplies usa
- cake stand
- ladle chuck
- wednesday
Only ONE week left in our summer fund raiser. Please consider donating to help keep our site alive- Our Patriot Turners- @forty_caliber hasn't used up all of that pecan stash. Check out this beauty- He tells us a bit more in this post- @Gerald was turning a tenon and uncovered this unusual shape. He asked what we thought it could be. Check out more images and the thoughts of our members- Boy, did we get a bunch of neat turnings posted on our "What's On Your Lathe" topic! @Gerald, @calabrese55, and @RustyFN all were busy in their shops- You can catchup starting here- What’s Coming Up- Click on the images for links to more information and registration For The Newbies- Form Mike Peace. Some good tips about the size of a tenon vs. the diameter of the piece- Mike also has some thoughts on purchasing kits- A hint from Tim Yoder about retaining those beautiful colors in your turnings- Are there little ones in your family? Sam Angelo shows how to create some simple turnings that could become favorite toys. Expand Your Horizons- You pulled that bowl round off the shelf and discovered it had a nasty split, now what! Here's what Richard Raffan does- Got the outside turned and starting to hollow out the inside and then this! What would you do? Tenon or mortice?? How about neither! Mike Waldt's video short of turning a large platter illustrates the strength of hot glue! New Turning Items- Several of the vendor attendees to SWAT did a live video showing much of what was happening and is available for viewing. I did catch one unique item from Niles Stoppers. Audio is a little off. https://streamyard.com/watch/8dzBZqCXEzpu A couple of weeks ago, we posted a new item from Ron Brown- the lathe disk sander. Ron has since added a short video of its operation- Woodturners Wonders is now handling Crown Tools. Check out more at- https://woodturnerswonders.com/search?type=article%2Cpage%2Cproduct&q=crown* tools*&_kx=gV5SF2As_3IwtBi5TrpHVQM0F3UvGVbQKzhWGippDlk%3D.VJvU8R Everything Else- From Ron Brown's newsletter- I Meant To Do That! Show-and-tell is an important element at any gathering of craft people, turners included. I implemented a guideline at the Gwinnett Woodworker’s regular Saturday morning meetings: "Don’t point out flaws.” If it isn’t blatantly obvious, don’t talk about it. Stay positive and share what you enjoyed about making this piece and possibly what you might have learned. In an attempt to appear humble, we sometimes point out our shortcomings or mistakes so we won’t appear to brag about what we’ve accomplished. You put in the time, energy, and effort to create something you are proud of. Don’t diminish it by pointing out the smallest of mistakes. One of our members was describing his piece which was very impressive by the way, he mentioned what became known as “the hanging hole.” None of us could see it, folks asked him to show us what he meant because it was so minor that even if you saw his mistake, you wouldn’t think anything of it. Most of the pieces woodturners make are unique because the wood's character can vary dramatically. Often there is no standard for comparison. If your piece didn’t turn out exactly like you intended, don’t be disappointed, be proud of what you did accomplish. Mistakes Can Be An Opportunity For An Object Lesson! A famous highly skilled local woodturner was demonstrating hollow forms when he suddenly pierced the vessel's side. Rather than giving up, he brilliantly used this turn of events as an object lesson on what to do with the remaining material. If you have never come through the bottom of a bowl or through the side of a hollow form, just wait, you will sooner or later. It’s a little more difficult when you do it in front of 30 other turners! Things are rarely perfect and yet most are still beautiful. Only someone lacking wisdom would criticize your work and point out small flaws. Don’t be easily offended and don’t do it yourself; that can lead to false humility. You’ve put in the work and practiced for untold hours, sometimes years, to gain your specific skill set. In other words, you’ve earned it Safe turning
- 3 replies
- vendor show case
- hot glue
(and 28 more)
- vendor show case
- hot glue
- mike waldt
- alan stratton
- richard raffan
- sam angelo
- toys people
- tim yoder
- fading
- kits
- mike peace
- tenon
- pat carroll
- ird
- symposiums
- bowls
- mulburry
- walnut
- maple
- bradford pear
- pecan
- bowks
- fund raiser
- woodturners
- wisdom
- wwednesday
- ron brown
- lathe sansing
- crown tools
Just 2 weeks left is our fundraising drive. Please consider donating and taking a chance on wining one of our sponsors' awesome prizes! Our Patriot Turners- @Steve Krumanaker continues to supply his unique turnings for a local "Bee" business- Steve's post has more images of some of the custom things he makes! @RustyFN scored some Bradford pear and showed us his blank preparation. Looks like some awesome bowls in his future Check out Rust's post- @Gerald has been busy replenishing his craft show stock- Check out his post to see what these are! @PostalTom updated us on the chess set he made. Tom included a closeup of the turned chess pieces, in his post Tom also posted some kitchen utensil items in our "What's On Your Workbench" forum- Our "What's On Your Lathe" continues to showcase our turners' projects! @nevinc, @forty_caliber and @Gerald all shared images of what's happening What’s Coming Up- Click on the images for links- For The Newbies- A variety of topics from around the web- From Tim Yoder, a couple of short video tips- From Mike Waldt, help for using my old nemesis- the Skew! This is a live demo so it is really long- Have you ever tried to cut a round blank on the bandsaw? Not a bowl blank, but rather an end off of a cylinder shape. If not secured properly, the blade can grab the piece and even break the blade. Mike Peace cautions about this and shares a video on making it safer. Expand Your Horizons- Craft Supplies USA created a video demonstrating the use of the Easy Core One Way Coring System. This is a rather long video but does demonstrate using the system. In the description, the presentation is broken down so the viewer can select sections to view. We've noticed several discussions about finishing, on other Patriot forums, and the subject of shellac pops up frequently. This link, from Kent Weakley, is to an article on making and using shellac as a bowl finish. https://turnawoodbowl.com/make-shellac-wood-bowl-finish/ I think everyone here knows my love of carbide turning tools. @smitty10101 posted about using Easy Wood Tools ( @Jordan Martindale ) to turn a bowl. The video is from Craft Supplies USA New Turning Items- Ron Brown has been creating and posting videos, on his YouTube channel, discussing his hollowing stabilizer. You can check them out at- https://www.youtube.com/@Ronbrownsbest/videos With SWAT happening this weekend, there will probably be some new products shown. Be sure to check out the Vendor showcase listed above for live feeds of some of the products. Everything Else- From Ron Brown's Newsletter, something I think we all have struggled with from time to time- What Is It Worth? I’ve had lots of questions about pricing one or two special pieces. For the vast majority of woodturners, it is a hobby, they never intend to sell anything they make. Some folks are interested in turning as a side gig but have no idea how to price their work. As someone who has experience in just about every conceivable selling venue, I would like to pass along what I have learned. Any object is only worth what someone is willing to pay for it. When I’m considering how to price anything I’ve made or plan on making, there is a formula I use: Cost of material + Time @ desired labor rate = Hard Cost Hard Cost X 4 = Suggested Retail Selling Price Hard Cost X 2 = Wholesale Selling Price Average Market Price For Similar Items; Am I Close? This is only a starting point. Determine the “Market Price” for similar items depending on the selling venue, are you in the ballpark? The Market Price in an Arts & Crafts Gallery is very different from the Market Price at a street craft fair and those prices are different on Etsy, eBay, your own website, or Amazon. Don’t forget about the associated cost for each venue. The last measure is a selling price that I feel good about. In other words, it is a Win-Win; the customer is happy at that price and I was happy to make it for them. An absolute fact of life is that everybody loves a bargain. (See the scripture below). Your “Retail Price” should be some amount above the price you hope to sell it for. Every retail store on the planet understands this and so should you. If you are selling one-on-one, you can comfortably offer a deal if they take it now and still earn what you needed in the first place. If you are selling online, this is the perfect scenario for a sale with either free shipping or a percentage discount. You must also consider why you want to sell at least some of your work. Perhaps you want to fund additional tool purchases. In that case, forget the time you put in and consider the amount of profit dollars such a sale will contribute to your “new widget” fund. If the income is important as a supplement to other household income, it needs to be worth your time. If you are thinking of this as a main income stream, you need to maximize the return on your capital and your time and this will require counsel and careful consideration. Try to pick items that are fast, easy, and cheap to make that you can sell tons of i.e. pens, bottle stoppers, pepper mills, spinning tops, utility bowls, cutting boards, kitchen utensils, etc. The bottom line is complicated depending on your specific situation. Only you can make that determination. I recommend setting your initial asking price higher than you think you should. Often someone else thinks your widget is worth more than you do. You can always lower the asking price, but it is difficult to raise it. As I said before, something is only worth what someone else is willing to pay for it. Here is a true quick story. I used to sell fancy laser-cut Christmas ornament kits and made finished samples for display at The Woodworking Shows. I got many inquiries from folks wanting to buy the finished ornaments that I really didn’t want to sell. I finally put a price of $150 on each one figuring that would stop all of the questions because nobody would pay that much for a Christmas Ornament. The first year we sold 12! Don’t sell yourself short Safe turning
- 3 replies
- videos
- ron brown
(and 32 more)
- videos
- ron brown
- one way
- coring
- wednesday
- wisdom
- woodturning
- fund raiser
- raffle
- honey
- dippers
- lids
- bradford pear
- fire sticks
- chess set
- kitchen
- measuring cup
- bowls
- blanks
- vase
- hollow vessel
- swat
- vendor showcase
- cindy drozda
- fall crafts
- tim yoder
- tenons
- skew
- catches
- mike waldt
- mike peace
- bandsaw safety
- jig
If you haven't seen the post, we are beginning our summer fundraiser to help support the operations here at the Patriot. Please consider donating to this worthy cause and maybe be lucky enough to walk away with some cool prizes- Our Patriot Turners- @nevinc posted a couple of beautiful bowls- Head on over to his post and check out additional images. @calabrese55 finished up that gorgeous segmented bowl. What a beauty! Check out his post to see what his plans are for this turning- @Gerald posted a vessel he is doing on the "What's On Your Lathe" forum. His image shows the business end of his hollowing rig and the laser attachment- @forty_caliber turned some more bowls fresh from the blanks in his drying kiln. I really like how he does the feet on these- There are more images in his post- What’s Coming Up- Click on the images for links to more information and registration- These first two might be a bit of a drive- If you missed Cindy Drozda's live presentation with Carl Jacobson. She has it posted on YouTube- For The Newbies- Drilling on the lathe may not require a Jacob's chuck, especially for smaller diameter bits. Tim Yoder demonstrates- Tim also shows a quick and easy way to round over the ends of handles- Pretty neat explanation about lathe speed- Kent Weakley on the importance of good lighting. Mike Peace demonstrates how to make a soft touch cone for the live center- Expand Your Horizons- What do you do when the bowl becomes a funnel- fix it or toss it? Mike Peace has some pretty strong feelings about it- Couple of turnings from Richard Raffan- Alan Stratton modified his Celtic Knot idea to create swirls and added it to his goblets. I had done this on some bottle stoppers- New Turning Items- Robert Sorby has a new multi-tip hollowing tool- Sorby tools are now available from Woodturners Wonders https://woodturnerswonders.com/collections/sorby?_kx=gV5SF2As_3IwtBi5TrpHVQM0F3UvGVbQKzhWGippDlk%3D.VJvU8R From Spiracraft, a new drilling device for those who make salt/pepper grinders https://spiracraft.com/product/woodcut-tools-mill-drill/?inf_contact_key=48786b7cec548ebb0bc98929c43bd777 Everything Else- Safe turning
- 2 replies
- sorby
- swirls
(and 31 more)
- sorby
- swirls
- alan stratton
- salt scoop
- richard raffan
- funnel
- live center cone
- mike peace
- lighting
- kent weakley
- lathe speed
- handle ends
- tim yoder
- chuck
- tool talk
- cindy drozda
- virginia symposium
- florida symposium
- iwg national seminar
- vessel
- hollowing
- segmented
- bowls
- fund raiser
- raffle
- woodturners
- wisdom
- wednesday
- hollowing tool
- spiracraft
- mill drill
Just a couple of days left in our summer fund raiser. Please consider getting those raffle tickets, if you haven't already done it. Our Patriot Turners- @Gerald posted a fantastic walnut platter he just finished- Check out more images and the comments from our turners- @PostalTom moved his chess piece post into our woodturning forum. He has a great start on a bunch of the pieces. He is getting ready to turn the "Knights" and was curious about the procedure. Maybe you can help him with some ideas. What’s Coming Up- https://www.woodturner.org/Woodturner/2022VirtualSymposium/2022-Virtual-Symposium---Main.aspx?_zs=ceDib&_zl=kVAC3 For The Newbies- A chuck, stuck on the headstock threads, can be a real problem. In this video, Mike Peace discusses some of the ways to remove it and how to prevent it. Cindy Drozda hosts live tool chats from time to time. You can sign up for notifications when they will be available. http://www.cindydrozda.com/html/Signup.html This is the video she posted from her last presentation- This video, from Kent Weakley, is on twice turning a bowl. What I found interesting is the type of chuck he used to hold the bowl to get it ready for mounting on his chuck. Expand Your Horizons- Last week we posted information on cleaning CBN grinder wheel. @Gerald pointed out there is some disagreement on whether or not this is necessary. Not having used CBN sharpening products, I was not aware of this difference in opinion. I searched the AAW boards for some more information and found this- https://www.aawforum.org/community/threads/cbn-wheel-cleaning.13014/ The discussion touches on several "cleaning" ideas as well as some other wheel care. Along the CBN lines, here's a video from Mike Waldt setting up a grinder with CBN wheels. Although the video is about a specific manufacturer, there are lots of great tips- From the AAW, a video on multi-axis spindle turning How does a true artist deals with the unexpected? Richard Raffan demonstrates- New Turning Items- Ken Rizza, from Woodturners Wonders, has a video demonstrating the Kodiak MAX sharpening system. Everything Else- The Richard Raffan video demonstrated how to work around the unexpected. Frank Howarth takes it to a whole other level. Rick Turns list of YouTube woodturning videos from last week- Safe turning
- 2 replies
- kodiak max
- wednesday
(and 30 more)
- kodiak max
- wednesday
- wisdom
- woodturners
- fund raiser
- raffle
- platter
- feather
- walnut
- chess pieces
- knight
- aaw
- virtual symposium
- atuck chuck
- mike peace
- cindy drozda
- tool talk
- twice turn bowl
- chuck
- kent weakley
- cbn
- cleaning
- mike waldt
- grinder setup
- multi-axis
- barbara dill
- richard raffan
- bowl
- rick turns
- frank howarth
- videos
We only have a little over a week left in our fund raiser. If you haven't had the chance to get your raffle tickets, don't wait. Some really great prizes- Our Patriot Turners- @RustyFN finished up a beautiful cherry vase for his Mrs. Here is the entire thread Rusty posted that takes us along from start to finish! What’s Coming Up- There is still time to get tickets for the Woodturner's Retreat- Get your ticket now for the next level of LIVE woodturning demonstrations. 6 Turners LIVE is bringing you our Summer Fun Extravaganza. On July 23, 2022 we will run a Zoom-based event showcasing 3 live 1.5 hour long demonstrations, followed by a short break and 3 MORE live 1.5 hour demonstrations! You get to pick and choose which demos you see and have the ability to pop in and out of them as you like. We plan to record the demos and make all 6 videos available to ticket holders after the event. More information is at- https://woodturnersretreat.com/?fbclid=IwAR0h2BSaucz6JcVDZ_0gcWNkIUtLWvNgRKi7ORogBYAE5Pv3BJYzoldH6Mo Cindy Drozda is having a live FREE tool talk on July 21 via YouTube- The Mid-Atlantic Woodturning Symposium is coming this September- For registration and more information- https://events.r20.constantcontact.com/register/eventReg?oeidk=a07ej1qyiwj1a79db74&oseq=&c=fa444490-93d3-11e7-adbb-d4ae52753a3b&ch=fa644fb0-93d3-11e7-adbb-d4ae52753a3b Then in October, the AAW virtual symposium is scheduled- More information will be available at this web site- https://www.woodturner.org/Woodturner/2022VirtualSymposium/2022-Virtual-Symposium---Main.aspx?_zs=ceDib&_zl=nClB3 For The Newbies- A nice spindle turning project from the AAW- Turned kitchen scoops make nice gifts. Here's another presentation/method from Wood Magazine- Expand Your Horizons- One of the nicest compliments you can get from another turner is- "OK, how'd you do that?" Here's a video from Carl Jacobson that will surely get someone to ask that!! New Turning Items- This has been available from Woodturners Wonders for a while. Ken Rizza demonstrates the process/products used to clean CBN grinding wheels- Everything Else- Rick Turns list of YouTube woodturning videos from last week- Safe turning
- 4 replies
- rick turns
- cbn cleaning
- (and 19 more)
