Showing results for tags 'live edge'.
Beautiful day in south central Pennsylvania... Our Patriot Turners- @Fred W. Hargis Jr Started a new turning and a new challenge for him- Fred had several questions about the best way to mount the piece on the lathe and some procedural turning questions. Our gang wasn't shy about offering their ideas and included some images of what they have done. Check out all of the interactions here- There were a couple of new comments on Fred's post about the lidded box he had turned. You can see the comments and images at- @kreisdorph scored some freshly cut oak. He turned this lovely bowl as a gift for the person who gave him the wood. Always a great thing to repay a gift and this lets the tree live on. What’s Coming Up- Click on the image for the link to registration and more information- For The Newbies- Sometime turners will uses different terms to describe the same thing or vice-versa. Here's Mike Peace's take on the Natural Edge Bowl and the Live Edge Bowl- And here he shows us his techniques for turning a live edge, or is a natural edge, bowl??? And from Lyle Jamieson, a tip on creating a strong glue block connection for bowl turning. Expand Your Horizons- Richard Raffan shows his method of sanding the inside of his turned boxes. Nice tip! Tired of turning bowls? Looking for another form that will be well received as a gift? Try turning a platter- New Turning Items- New style bronze threaded rings from Niles Bottle Stoppers Everything Else- Ron Brown's newsletter included a free sharing of his published list of woodturning "Pearls of Wisdom" and a free download of the Turners Reference Guide. Ron Brown’s Pearls: Turners Reference Guide© brought to you by Ron Brown’s Best, LLC 1. There are exceptions to every rule except this one. 2. Six types of chisels are needed to make up a basic turning set (Spindle Gouges, Roughing Gouges, Bowl Gouges, Skews, Scrapers & Parting Tools). 3. Sharp Lathe Tools are more fun. 4. Speed formula: diameter in inches X speed in RPM should equal 6,000 to 9,000 (10” X 800 RPM= 8,000). 5. Rub the bevel on all cutting tools; not on scraping tools. ABC= Anchor the tool, Rub the Bevel, Pick up the Cut. 6. Have safety gear on hand and use it; full face shield, dust mask. 7. Always rotate the workpiece by hand before turning the lathe on to check for interference. 8. Start at slow RPM to check for balance, and then speed up. 9. Speed can be our friend. 10. If you are afraid, slow down and take a breath. 11. “Life’s too short to turn ugly wood.” John Jordan. 12. Carpe Lignum, Torne Lignum – Seize the wood. Turn the wood. 13. Variable-speed lathes are better. 14. Learn to hone. 15. Have a plan before you start. 16. Be Flexible. 17. Turn green wood often. 18. Greenwood is like lettuce, cut what you can use or it will spoil. 19. Learn to use your tools well and keep them sharp. 20. Sharp tools are safer. 21. Sharp tools produce better results. 22. Invest in a good sharpening system and learn to use it well. 23. Then teach others. 24. Don’t skip grits. Never jump more than 50%, i.e. 100 grit to 150 grit to 220 grit to 320 grit. 25. Your family will love whatever you make. 26. Listen to your spouse; they usually have a better eye for design. 27. Never point out your mistakes to others. 28. Spindle turning often requires more skill and imagination than bowl turning. 29. “Never scrape when you can cut.” Mike Mahoney. 30. If you must scrape, raise a fresh burr. 31. Get and learn to use a ¼” wide parting tool. 32. Learn to make lots of “Fun Stuff” like tops, pens, stoppers, light pulls and small lidded boxes. It will make you a better turner and your family will think you are a genius, especially at Christmas time. 33. Make Christmas gifts for your family every year and start in June. 34. Invest in education like classes, seminars and symposiums. 35. Spend the money for personal one-on-one instruction with a professional turner. 36. If you are not failing every now and then, you are not learning. 37. You learn the most when you teach others. 38. Buy good quality M2 High-Speed Steel tools. Avoid high-carbon tools; they are a waste of time. 39. Learn to turn right and left-handed. 40. You can use a bowl gouge on spindle work, but usually not the other way around. 41. Sandpaper is cheap; throw it away often and use fresh stuff. 42. Sign and date your workpieces along with the kind of wood. 43. Buy the best chuck you can afford, and then buy lots of jaws for it. Then buy another chuck. 44. Make your own tool handles. 45. Try someone else’s tools. They might know something you don’t. 46. Join an AAW chapter then go to the meetings. 47. Read turning magazines. 48. Watch turning videos on YouTube, but don’t believe everything they tell you. 49. Buy educational DVD’s. https://longworthchuck.com/index.php?route=product/product&path=10&product_id=219 Turners_Reference_Guide.pdf Safe turning
- 3 replies
- richard rodgers
- sanding stick
- (and 20 more)
From the album: Heartpine live edge shelf
© The Patriot Woodworker
- floating shelf
- heartpine
(and 1 more)
- floating shelf
- heartpine
(and 1 more)
- floating shelf
- heartpine
(and 1 more)
- floating shelf
- heartpine
(and 1 more)
Hard to believe that October is almost half over! Usually we have had a frost by now. Not too much happening, here, this past week- Our Patriot Turners- @forty_caliber finished up a gorgeous multi species bowl for his Mrs. He tells us more about the species, finish and how it got its name- @Fred W. Hargis Jr asked our turners for their input on bowl gouge use. Fred had started turning a bowl and was unsure of just how to get the best cut from his gouge. We had a very informative conversation with a lot of our turners. They offered their ideas, suggestions and links to resources - Head on over to the this thread and see if you can give Fred additional ideas- What’s Coming Up- Click on the images for links to registration- From the AAW- For The Newbies- If you are considering purchasing carbide turning tools, please consider checking out our sponsor Easy Wood Tools. To learn more about using the EWT products, they have added an "EWT University" tab on their website. Check out this link! https://www.easywoodtools.com/resources Thanks @Jim from Easy Wood Tools !! Expand Your Horizons- The AAW has made available this video on multi-axis turning by Barbara Dill Ms. Dill has another video on the same subject- Wanna turn a BIG bowl??? Watch Mike Waldt- New Turning Items- Hang on to your lunch money, this week. Everything Else- Rick Turns list of YouTube woodturning videos from last week- How about a little fun with Tim Yoder and this year's Halloween project!! After a go of antibiotics and industrial strength decongestants, I was finally able to get back into the basement shop. The first order of business was to make a dust collector "hood" to do the sanding on the last batch of rolling pins. I cobbled it from scraps around the shop but did buy a piece of acrylic at Hobby Lobby. The hood attaches to my PVC port that was built sometime back. This port can be positioned along the length of the lathe as well as placed close/farther from the turning. Front view- the "hood" is 24" long End view- Back view- Interface between the PVC pipe and the collector- Top View- Bottom view- the bottom is a piece of aluminum trim coil. Oblique view- Mistake- the acrylic bowed up as I bent it into shape. The heat gun idea to bring it down was not a complete success To attach the hood onto the PVC, I used a pin through the 1.5" thick interface block and into the PVC pipe- Now, will it work? A strip of what passes for toilet tissue these days IMG_0241.MP4 IMG_0242.MP4 I power sanded 6 rolling pins thru 3 grits and there was no dust on the white bottom. I'm pretty happy. Safe turning and stay well
- 6 comments
- maple
- curly maple
(and 4 more)
Tried something new today; end grain thin bowl. Used live oak and turned to just over 1/8 inch live edge. Easy turn bud did start to crack in center when sanded. Fixed that with CA. Put in a bag to slow drying and hope for the best.
From the album: my furniture
live edge work station -
Hey Cal, as promised. First PIPs. More after the slab gets cut and planed. And after Phyl gets back with the camera. That slab is 2" thick, about 16' wide and I'll cut it to yield a 48" long table top. The finished width will depend on the width of the glass "river".
- 123 replies
- mesquite
- river table
(and 1 more)
From the album: coffee table
I have always wanted to take a shot at making some bowls so I finally got serious and ordered some bowl gouges last winter. A co- worker had a Hickory tree come down and I got a few pieces of it to try. Here is my first attempt at live edge turning and my first glued up bowl as well. I took them to the county fair and the live edge bowl earned a blue in the woodcrafts category while the glued up bowl took a red in recycled items. The live edge bowl is Hickory. The other is reclaimed Walnut beam, part of an Osage Orange fence post, and a scrap of Oak house trim. I really enjoyed these projects and plan to do more. Much to learn with the lathe.
Thank you Gerald, for gracing our community with your work. Big bow, bow, bow, bow, like a China Man, I am bowing, backing away, slowly, still bowing, you are the God of bowl turning, I love your work! We've tweeted it, facebooked it, and featured this album, you make our community look great! And to all Patriot Woodworkers, please upload your images to your gallerys, so we can drool over it all! Use our gallery, it's one of the least used departments in our community.
Started it this AM the wood is elm, damp but mostly dry so I'm going for finished dimensions.
I've still got at least dozen of the natural edge walnut pieces to finish up. Was kind of between projects and decided to sand and finish this one. I chose this one because it looked like my cuts were decent and it wouldn't take as much sanding as some of the others. It's about 16X12X5.5. The bark is just really nice on this one I think. It was just about to big for my little photo booth. Steve
I was asked to provide a woodworking project for a fundraiser. So I decided to mix my photography job and woodworking hobby to create a mixed media project for display. I took a shot of the Alley Springs Mill (Jacks Fork Missouri) late one winter, accentuated the mill over the black and white background and had an 8x12 printed on metal (aluminum). I then took a piece of scrap live edge walnut and created a background to "frame" the image. The print is raised of the background by 1.5" using blocking to give it a 3 dimensional look. This is the live edge piece after cutting for length, jointing the long edges, hand planing the face and back and a base sand with 40 and 80 grit. A quick test to see how the print looked over the natural wood. I decided on staining. I wiped on Minwax walnut stain, then sprayed three coats of semi-gloss polyurethane over the entire piece. Epoxied the print to the board and placed on a stand for display. I'm extremely pleased with how this turned out. It allowed me to work with the metal media, and use a piece of live edge to accentuate the print. Will
- 12 replies
- photography
- woodworking
(and 2 more)
I really, really hope this one behaves while it's drying.
Steve Krumanaker posted a topic in Wood Turners
I say that just about every time but this one could be special I think. About 19" diameter and five inches deep. Spectacular grain and markings in it as well. There's going to be a bit of sanding and I'll probably let it dry for a couple months but if it turns out I'm going to call it "ET" Steve- 15 replies
- bowl
- walnut bowl
(and 5 more)
Well, found out the hinged items and I still don't get along. Trying to install a lid on these Lap Desk.......didn't go too well. Trashed the non-moving part of the lid, as the meeting angles...didn't. Got out the last of the wider boards from the stash. Had a "Live Edge"......maybe a design feature? marked out where I needed to cut. Bandsaw still refuses to cut a straight line, so I'll dig this little saw out. At least it will saw a straight line. Clamped things up, to see what angles needed cut And test fitted some hinges.....close enough for now.... Closed the lid...still a bit "hinge-bound", but better than it was. More Walnut plugs to install, and then just called it a night Front view, and a look at the back edge BTW, while trying to plane a bevel on the edge of this curly Maple stuff That plane sitting beside the panel is one of the two from an auction Seems to be tuned up enough to make a few shavings....The little smooth plane also did a bit of work on the flat areas Millers Falls No.8....about the size of a Stanley #3. Might just add a coat of BLO to this desk, and see what turns up.....
