Showing results for tags 'basket weave'.
I received a voice mail from the art center telling me I won a prize. I just have to wait until July 18th to find out what it is.
- 16 replies
- vase
- prize winner
(and 2 more)
Wow, where did the month of April go?!?!?! Our Patriot Turners- @RustyFN gave us an update on his latest basket illusion vase. It is absolutely gorgeous!! Head on over to Rusty's post and see what our members had to say- What’s Coming Up- If you missed Cindy Drozda's Live Tool Talk, she has it uploaded to her YouTube Channel- Click on the image for the link to more information and registration- https://www.woodcraft.com/pages/store/dayton https://www.woodcraft.com/pages/store/raleigh For The Newbies- A short video from Tim Yoder on choosing a drive center- Expand Your Horizons- Mike Peace demonstrates a multi axis turning with a beautiful piece of cherry burl- Turning Time With Easy Wood Tools- Easy Wood Tools has settled into their new digs! Click on the calendar for the link to the interactive page. The Easy Wood Tools Detailers are typically used to create fine lines on a turning. They can also be used to shape tiny details in objects like finials. The Detailers come in two configurations. The Easy Detailer, which uses the standard Ci4 cutter or the negative rake Ci4-NR cutter And the Easy Micro Detailer, which uses the Ci7 cutter or the negative rake Ci7-NR cutter This short video from Craft Supplies USA demonstrated the Easy Detailer This video, from Tracey Malady uses the Easy Detailer and Micro Detailer to help shape a finial- When using this tool, the best surface is created by having only one side of the cutter in contact with the material, at a time, as the cutter goes deeper into the turning. New Turning Items- Tomislav Tomasic reviews his new Vicmarc VL300 Wood Lathe. That sure is a nice piece of equipment, Everything Else- Safe turning
Cruising through April! Our Patriot Turners- @Gordon posted a question about wood identification. Specifically, he scored some really nice pieces but was uncertain about the species. Check out his post and see what our turners thought. If you have a better guess, I'm sure Gordon would love the input! @calabrese55 posted a great little jig in our Turner's Tips Sub-Forum. This neat little device can really help you dial in the correct size for chuck tenons or mortices. Head on over to the sub-forum and see more images and how it works. @RustyFN got a good start on another "basket weave" vase. These turnings sure do take a steady hand and awesome eyesight! See Rusty's post for additional images and more progress @Fred W. Hargis Jr gave us a look at his segmented ring, coin holder progress and details about how it is coming along. Fred posted images of his progress and details of how he accomplished the turning As his turning is nearing completion, Fred wondered if there is a way to burn an embellishing ring on the surface circumference of the turning. Our members offered suggestions as to what worked for them. If you have a technique that works for you, please give Fred a shout. From The Patriot's CNC Forum, @4DThinker posted his work on creating a turning tool handle. It turned out really nice! More images and the completed handle are shown in his post- What’s Coming Up- Click on the images for links to more information and registration. If you missed the live Spring Vendors Showcase, you can watch the replay. Cindy Drozda's Live Tool Talk- For The Newbies- Not every piece of wood is safe to turn. In this video, Tim Yoder describes a defect called "wind shake" and why you should be aware of the dangers. Sharpening your HSS tools takes practice. In this video, Mike Waldt demonstrates methods of making repeatable sharpening grinds. Richard Raffan explains the importance of knowing the difference between a bowl gouge and a spindle gouge. Personal safety could be compromised and tool damage can occur if used improperly. Expand Your Horizons- Neat idea, from Sam Angelo, on chucking a turned box without the use of a tenon. Turning Time With Easy Wood Tools- The Easy Wood Tools "finisher" is an all around turning tool. It can be used to remove material during spindle turning, create coves/beads and even smooth out the tool marks left by other tools. The finisher is available in every category of the Easy Wood line. Depending on the size of the finisher, the carbide cutter may be different. As with all Easy Wood Tools, the cutter identification is etched into the shaft of the tool so you will always know the correct cutter for that tool. Using the finisher is straight forward. The tool is held horizontal and the cutter contacts the turning at the horizontal center line of the work. The depth of the cut should not exceed 1/3 the diameter of the cutter to avoid vibration thus creating rough surfaces. The finisher demonstrated by Craft Supplies USA- Free demonstrations from The EWT calendar https://www.rockler.com/retail/stores/ok-oklahoma-city-store https://www.rockler.com/retail/stores/ga-sandy-springs-store?utm_source=local&utm_medium=organic&utm_campaign=sandy-springs @Jordan Martindale New Turning Items- A new face shield/respirator reviewed by Mike Peace. The link to the manufacturer- https://microclimate.com/ Sorta reminds me of the helmets used by the NASA crews. Everything Else- Safe turning
- 9 replies
- wednesday
- wisdom
(and 30 more)
- wednesday
- wisdom
- woodturners
- question
- wood species
- chuck jig
- tenon/mortice
- vase
- basket weave
- segmented
- embellish
- burning
- toool handle
- cnc
- vendor showcase
- replay
- tool talk
- cindy drozda
- tim yoder
- wind shake
- mike waldt
- sharpening
- repeatable
- richard raffan
- bowl vs spindle gouge
- sam angelo
- chucking
- ewt
- finsiher
- calendar
- mike peace
- respirator shield
I swear one of these days I'm going to use my lathe and turn something. Our Patriot Turners- Thanks to @User74 for posting his cool lidded bowl, on our "Off the Lathe" topic! More images and a description of how he did the dark ring embellishment starts here- @Fred W. Hargis Jr asked our turners their thoughts on a vacuum chuck vs. a jam chuck. Fred received some great input. Please check out his post and see if you can add to the discussion- @RustyFN posted his "basket weave" vase. This amazing piece certainly take a whole lot of patience, a steady hand and perfect eye sight! See Rusty's post for more description and process images- What’s Coming Up- If you missed Cindy Drozda's Tool Talk last week, she uploaded the event to her YouTube page for viewing. This Saturday- April 5- is the free, online Vendors Showcase. Registration can be done at - https://streamyard.com/watch/UwJbzWJMHmsV?receiptful=67eadc4126171910e58cc7c7&utm_source=CM Commerce&utm_medium=email&utm_campaign=newsletter-445&utm_term=newsletter&utm_content=other&receiptfultype=newsletter Or- https://streamyard.com/watch/UwJbzWJMHmsV For The Newbies- Mike Peace posted a 5 year review the Record Power Coronet Herald lathe. It is a mid size variable speed wood lathe with a 14” swing and a 1HP motor. If you are thinking of upgrading, check out what he has to say. Expand Your Horizons- The first of the month brings another turning collaboration between Richard Raffan, Sam Angelo, Tomislav Tomasic and Mike Peace. As you saw in Cindy's tool talk, Easter is approaching and turning eggs is as much fun as coloring real ones- except they are not as edible. Tim Yoder goes one step farther and turns an "Easter ??? Bunny". Some of you may be aware of my love of Monty Python- Turning Time With Easy Wood Tools- Easy Wood Tool Demonstrations for the month of April for locations around the country- Why does Easy Wood Tools have the best carbide in the industry? Check out this article- Not All Carbide is Created Equal Final.pdf Tim Yoder turns Easter Eggs using Easy Wood Tools- @Jordan Martindale New Turning Items- Hoping the Spring Vendors Showcase will be introducing some new stuff. Check out the link above. Everything Else- Many turners are familiar with the name Rebecca DeGroot. Well known as a talented turner with a weird imagination, a tattoo artist, former high school art instructor and a contestant on the Food Network's Outrageous Pumpkins. Ms. DeGroot is featured in the February American Woodturner magazine. Link to the article- https://www.woodturner.org/Woodturner/Resources/AmericanWoodturner/2025/40-1/Rebecca-DeGroots-Creepy-Crawlers.aspx?fbclid=IwY2xjawJap6RleHRuA2FlbQIxMAABHYoPblEISEOS8K8BmeTWgGCyC-EDP0Vs5r4eq28xnALVQzulxIePbROvyA_aem_sfboYCYcwKY5SwZV6VzkVg Safe turning
For our next presidents challenge at our club our president picked an 11” tall vase with two embellishments. I decided to do a basket illusion vase so I have beading, burning and coloring. Here it is from start to finish. It was turned from hard maple.
- 7 replies
- vase
- basket weave
(and 1 more)
Looks like things are picking up, now that the holidays are over. Let's get to this! Our Patriot Turners- @RustyFN is participating in his turning club's annual contest. He has posted a couple of images as he begins to create his entry. Rusty has more in his post at- @forty_caliber gave us a look at another one of his Hays County pecan bowls- Monty supplied some additional information about his drying process- There have been a couple of new entries on our "What's On Your Lathe" continuing thread. @calabrese55 added some process images of this - Also posted was a red oak platter- Check out all the comments starting at- @Gerald is making a design change on his little spinning tops. I really like the new design and the colors he uses. In his post, Gerald added a picture of his previous design for comparison- What’s Coming Up- Click on the images for more information and registration- Todd Raines continues his presentation on the spindle gouge- If you missed Cindy Drozda's live tool talk last week, here's the YouTube video- Also from Cindy- For The Newbies- The skew chisel is a powerful tool, once you have mastered it. Richard Raffan shows us how that done- Mr. Raffan goes further, in this video, demonstrating using the skew to turn finials- There are several ways to chuck mount a bowl. Two of the more popular ways are the Mortise and Tenon. I typically use the mortise because it allows me to finish the bowl bottom with my preferred method. The mortise, however, is not without pitfalls as Kent Weakley points out- Jim Rodgers demonstrates how to make a bottle stopper. Unlike the metal stopper kits, Mr. Rodgers uses corks to seal the bottle. Also check out the home made mandrel at the end of the video- Tim Yoder offers up a short video on turning a curve Although a chuck is a really nice piece of equipment to own, especially when making small items. Lyle Jamieson shows us the chuck is not the only way to to accomplish it. Expand Your Horizons- If you are ready to move up to bowl turning, Craft Supplies USA has a nice video illustrating the process step by step. The bowl blank in this demonstration was partially dried commercially- Never too early to start those ornaments for next Christmas! Here Alan Stratton creates an 8 point, 3 axis item! @Steve Krumanaker turns items for artisans in his area. Recently he started making "drop spindles" for a craftsperson who works with wool. I thought this might be another thing Steve could use as a money maker From Woodworker's Journal, a Three Winged Jewelry box. The how-to article is at- https://www.woodworkersjournal.com/project-three-winged-jewelry-box/ Check out what Tim Yoder does with a small 3 branch crotch piece- New Turning Items- A sale on Woodturners Wonders LED lights https://woodturnerswonders.com/ Everything Else- From Ron Brown's newsletter- You Are Called To Be A Mentor You have to know something about your subject. First-hand experience is helpful. If you can explain What, How, and Why so a 5th grader can understand it, you will be a good mentor. It only takes a very small portion of your time (15 minutes to 1 hour) here and there to show individuals or groups of folks what you are talking about. You might need to take an occasional phone call to clear up misunderstandings. In this day and age, you might need to answer a text message or send a YouTube link addressing the issue. Unless you are a paid demonstrator, you must accept that you most probably will receive nothing material in return from those you help so unselfishly. Some won’t even say thank you and some will argue that you are wrong. A few of the people you help will go on to accomplish even greater things than you did. Some of the students will indeed go on to become the teachers. You need to accept and appreciate that others gave of themselves to help you achieve the things you know. Even if you learned most of what you know by yourself (so-called self-taught), chances are that you watched YouTube videos, attended a trade show demonstration, or a club demonstration. Perhaps you were just a member of the crowd and not in a one-on-one situation. Someone took their time to show you something you didn’t know in a way that helped you be more successful. Sometimes folks will want to be paid for their advice. They are still exercising mentorship. I was very fortunate during my early turning career to encounter some very talented and generous mentors; Nick Cook was the very first and Don Russell gave of his time and energy unselfishly on numerous occasions. I hosted Chris Stott from England for a full week! That turned out to be a magnificent chapter in my turning career. Kirk Deheer of Craft Supplies in Utah gently guided me over a period of several years and I will be ever grateful for his wisdom. Mike Mahony offered guidance and freely answered my list of 20 questions over dinner many years ago. Others have given their time and energy and are wonderful examples of mentorship even when they didn’t realize it. Of course, it required me to put their advice into practice to make it my own, but, as they say, the way you get to Carnegie Hall is practice, practice, practice. A mentor simply guides someone willing to learn. It is really that simple and anyone can and should do it when given the opportunity. Safe turning
- 11 replies
- ron brown newsletter
- lamps
(and 32 more)
- lamps
- woodturners wonders
- tim yoder goblet
- winged jewelry box
- woodworkers journal
- mike peace
- shaw ring pin
- alan stratton
- ornament
- craft supplies usa
- lyle jamieson
- no chuck holds
- curves
- tim yoder
- jim rodgers
- bottle stopper
- kent weakley
- mortise fails
- richard raffan
- skew
- hollow vessel
- tool talk
- cindy drozda
- todd raines
- spindle gouge
- tops
- platter
- staves
- bowl
- woodturners
- basket weave
- wisdom
- wednesday
Not much to report this week. Been TDY to Coop Cleaning as relatives are visiting for Thanksgiving. Our Patriot Turners- @calabrese55 posted a new segmented form in our "What's On Your Lathe" thread. This one is a mixed media work. Mike tells us a little more about the acrylics and his go-to guy for information in his post- @RustyFN shares his very first basket weave illusion turning and it is Awesome! He posted it here- I know my old eyes would be crossed before the first row was finished! @HandyDan and @Smallpatch posted some of their Christmas ornaments Check out the comments at- New member @knightwolf is looking for some help in locating a part for a Delta lathe. Please see his post and if you can provide assistance he would certainly appreciate it- What’s Coming Up- Click on the images for links to registration and more information- For The Newbies- The question about food safe finishes comes up quite a lot. This article from Wood Magazine has some good information- https://www.woodmagazine.com/materials-guide/finishes/is-your-finish-food-safe?fbclid=IwAR0o48QrIVH14qM2EvSXQfu7w6aDoV9_Iz_2TAhglBQ4iD4cAFikKGzBwdY Expand Your Horizons- Carl Jacobson demonstrates the use of the Joyner Off Center Jig- New Turning Items- Maybe Santa is hording all the new stuff until after Thanksgiving Everything Else- From Ron Brown's newsletter- Figuring It Out – How To Succeed At The Small Stuff Success in many small things can add up to success in big stuff. The advice that follows is applicable to non-life-threatening situations, small undertakings, and must be tempered with wisdom. If failure could result in injury, substantial financial loss, or divorce, don’t do it! We are not given the gift of seeing the end from the beginning most of the time. Nor are we granted understanding in advance exactly how we will get there. Many times, our adventure starts with nothing more than hope and faith that we will figure it out along the way. The key is to take some time to think it through as best you can, then begin. Now that you’ve started, a pause after each step will reveal how to proceed with the next step. Before you know it, you will have figured it out as you went and chalked up another success. As an example: your project is to turn a cube into a 3-winged bowl and you’ve only seen the video, you’ve never actually attempted this method before. You are unsure what to do next. Mount your blank and start. You made an outline while watching the video so you have a rough idea of what to do first, second, etc. Go for it! You will figure it out. The next one will be much easier and so on. Don’t let yourself be a victim of “Paralysis of Analysis.” Gather the necessary materials and tools, give it an appropriate amount of thought, then start. Even if you do it wrong the first time, you will figure it out along the way. I love to invent stuff and solve problems, especially for the turning community. I rarely know how my approach to a problem will turn out in the end. I do my research to understand everyone else's approach then I develop my unique approach to make it better, easier, safer, and sometimes faster. The marketable jig, fixture, or tool seldom resembles the first few attempts. I average between 8 and 10 prototypes before I discover one that works the way I intend and doesn’t do any of the bad things the first ones did. Plus, it has to look way cool! I figured it out along the way. If I never get started with the first one, I never get to number ten so you can do things easier, faster, and safer. There are always unintended consequences with every project and I adjust accordingly. I often can’t see the challenge until I get to that step. Patience and persistence coupled with wisdom and insight carry me through. Safe turning
- 5 replies
- joyner off center
- carl jacobson
- (and 15 more)
Did a few of these a while back but it's been a while. This is soft maple, turned to about 2.5mm or 3/32" and just over 12" diameter. It will get my version of a basket weave illusion done with piercing and pyrography. This is the basic pattern, it's adapted from a Polynesian Lei, Lei weave which is normally done with water hyacinth reeds. The "X" areas will get pierced and the rest will get wood burned and shaded to produce the basket weave illusion. Have just started to layout the grid lines to draw the pattern. That's an LED lamp on the back side. Produce_0.mp4 Hoping this one turns out as it's intended tobe a gift.
- 35 replies
Starting into another month already. This is April and taxes are due in a little over a week. Hope our turners post their new tools purchased with those gigantic refunds! Our Patriot Turners- @Reese Aukee showed us some more of those cute little hedgehogs she turns. Reese received lots of positive comments and some questions about her turnings. Check out her post- @Gerald posted a comment in our sub-forum for Ring Master Turning. We have an ongoing thread in our woodturners forum discussing how we decide what to make from a chunk of wood. @Gerald suggested this topic and we have had several entries. Please take some time to see the thought processes (or lack thereof ) when trying to decide what to make. We look forward to seeing your turnings and how they came to be. If you are into turning miniatures, @kmealy showed us a neat portable lathe. He received lots of comments! ¹ What’s Coming Up- Click on the images for links to registration and more information- Cindy Drozda has been offering both paid and free online presentations. If you would like to receive notifications of her events, check out this link- http://www.cindydrozda.com/html/Signup.html For The Newbies- A hodgepodge of videos to help us be more knowledgeable as beginning turners- Have some wood from a downed tree? Ashley Harwood has a few tips on helping prevent logs from cracking- Of course you need to first get that tree cut into manageable chunks. Here Lyle Jamieson and Sam Angelo have some tips on using the chainsaw- In combination with a chainsaw, the bandsaw can be used to create turning blanks. Robo Hippy's informative video gives us lots of pointers- Expand Your Horizons- Once you get that tree log into a manageable blank, you can create a beautiful natural edge bowl. Lyle Jamieson shows us how. If a natural edge bowl doesn't thrill you, here, Kent Weakley shows us how to turn a "magnetic" paper clip bowl! With Easter coming up fast, a cool turning from Alan Stratton on turning the perfect egg- What is a Kuksa? And How to Turn One? Mike Peace does some turning, carving and shaping! Basket weave illusion bowls are quite popular. Carl Jacobson turned something a little more shapely using the basket weave process. New Turning Items- For the pen turners, Craft Supplies USA has a new pen kit- Hobble Creek Craftsman King's Camo Bolt Action Pen Blank Click on the image for the link to more information Everything Else- Rick Turns list of YouTube woodturning videos from last week- Safe turning ¹ Only available on April 1st.
- 4 replies
- wednesday
- wisdom
(and 33 more)
- wednesday
- wisdom
- woodturners
- hedghog
- pine cone
- ring master tool
- what to turn
- miniature lathe
- woodturning boxes
- scott hampton
- aaw
- oval box
- todd raines
- cindy drozda
- log preservation
- chainsaw
- ashley harwood
- lyle jameson
- sam angelo
- robo hippy
- bandsaw
- bowl blanks
- natural edge bowl
- kent weakley
- magnetic bowl
- alan stratton
- perfect egg
- kuksa
- mike peace
- basket weave
- carl jacobson
- pen kit
- craft supplies
- videos
- rick turns
Here's hoping those Patriot members, in or near the path of hurricane Dorian, are safe and well. Our Patriot Turners- @Billy B posted information about his latest basket weave illusion. If you haven't seen his work, you MUST head over to his post and see the miracle transformation he does with a piece of maple! To say our turners were impressed is an understatement- What’s Coming Up- The Ohio Valley Woodturning Guild's symposium is October 17-20. Click on the above image for the link to more information and registration. For The Newbies- Turners often would like to sell their pieces but may not always know what route to take. The "Router Forums" has an article that may answer some of those questions. Clicking on the above image will direct you to the article. Easy Wood Tools ( @Jim from Easy Wood Tools ) shared a great video on bowl turning. The Easy Wood turning tools really do make turning a lot easier! Expand Your Horizons- Arguably, Cindy Drozda is the master of finial turning. Her skills at the lathe are reflected in all her work. In this recently posted Youtube video, she demonstrates her skills. Use this link to view the video as it cannot be embedded- https://youtu.be/qL0czX5iQjc If tiny is your thing, check out Tim Yoder's recent post on making goblets! Listen for Tim's endorsement of the Easy Wood Chuck at about 45 seconds into the video! New Turning Items- The folks at Woodturners Wonders are stocking a new sharpening system for lathe tools. The Kodiak Sharpening system, used in conjunction with your grinder, helps make sharpening easier and more accurate. Check it out at- https://woodturnerswonders.com/collections/kodiak-sharpening-systemhttps://woodturnerswonders.com/collections/kodiak-sharpening-system Spiracraft is now stocking pressure pots and vacuum chambers as well as resin casting chemicals and supplies. Check out their new stuff at- https://shop.spiracraft.com/product-category/resin-casting/ Everything Else- Rick turns posted his August update for YouTube woodturning videos. Thank You, Rick! Seems like it has been months since I was able to spend time at the lathe. You may remember my failure as I was practicing a hollow vessel. Failure or re-design opportunity. I hate to give up. The hollow vessel was turning into a small oddly shaped bowl. Maybe I could make a lid! Now, the astute observer will notice that an item that has often been the brunt of jocularity has been replaced. The little bowl has a hat! The outside spiraling was done with a Sorby spiraling tool. The inside spirals were a happy accident using the new Easy Wood Tools mini straight hollower. The little hat needed a top OK, I took it a little farther. I wanted to try something different. The spiral embellishment is covered with copper leaf. The texture telegraphed through the copper but I probably should have cut the spiral a little deeper to provide more definition. I still need to finish the entire piece with a protective coating. Probably clear gloss poly. It was turned completely with Easy Wood Tools- with the exception of the spiral detail. I am calling this piece- "Klaatu Barada Nikto". Safe turning
I don't make a lot of boxes. No particular reason, just not something that really appeals to me. I've had a basket weave pattern in my mind and wanted to do it on a smaller item before attempting it on a larger one. So, for some reason I decided to do a box. Since I had planned to embellish this box, I wondered if I could hide the join between the top and the bottom so I planned my pattern with that in mind. Then, I wondered, could I trick people about where the top and the bottom meet. So, I made it upside down, kind of. Anyway, here's the pictures, this is my sort of upside down, basket weave, maple box. It's about 4" high and a couple inches in diameter. I really haven't figure out how to terminate one of these basket weaves, I can see it in my mind but it just doesn't work when I try to draw it. At any rate, the wife says she likes this so that's good enough for me. This is the top. The bottom, I know I use this "phicops" pattern a lot but I just really like it. Opened and the inside, the join is about 3/4" from the bottom as the box is sitting upright. I'm hoping to have some fun with this at our meeting next Sunday. I believe most people will think the join is near the obvious "top" and try to open it there. We'll see. Steve
From the album: Steve Krumanaker
Maple bowl with basket weave pattern.-
- basket weave
- zentangle
(and 2 more)
Maple bowl with basket weave pattern. Bottom has zentangle pattern "phicops"-
- basket weave
- bowl
(and 4 more)
