Showing results for tags 'aaw symposium'.
We only have about 3 weeks left to get your raffle tickets for the Summer Fund Raiser. This fund raiser will help keep our site alive and allow us to help veterans. Please Donate! Our Patriot Turners- @Turn n Learn posted some more items he scored with his lathe and wondered what some were used for. New comments and items begin here- @Gordon made a cool jam chuck using some neoprene rubber- He posted more images and the source for the rubber in his post- @Fred W. Hargis Jr gave us a heads up for an awesome sale price on new Jet and Powermatic lathes- Check his post for the link to Craft Supplies USA If you aren't sure what to look for in that new lathe, this video from Popular Woodworking may help- From our "What's On" posts, @BuckeyeHomestead posted a picture of his NEW Jet lathe and its first project That's an awesome lathe! @RustyFN had some difficulty with buffing out a finish. He explains the problem in this post- Check out what Rusty said and maybe you have some tips that will help him. What’s Coming Up- Click on the images for links to more information and registration. For The Newbies- Sam Angelo posted a nice spindle gouge tutorial Tomislav Tomasic created a great video on tips for turning. His videos have excellent closeup of gouge positions. From Popular Woodworking, a written tutorial on lathe tool sharpening- https://www.popularwoodworking.com/techniques/sharpening-for-woodturners/ And another on scrapers https://www.popularwoodworking.com/tools/the-woodturning-scraper/ Expand Your Horizons- The theme for this week is embellishing- Mike Peace bleaches and burns turning to add neat effects- From Popular Woodworking- https://www.popularwoodworking.com/projects/square-platter-with-textured-rim/ If you are looking for a nice gift project, Jimmy Clewes' coffee scoop tutorial might just be what you want- https://www.popularwoodworking.com/projects/turned-scoop-with-pewter-finial/ Turning Time With Easy Wood Tools- Over the past several weeks, we have been showcasing the individual Easy Wood Tools. One thing that should be noted is that all Easy Wood products are made right here in the good ol' U. S. of A. Fascinating video of the manufacturing processes- All of the Easy Wood products are available directly from their home base in Lexington, KY and on Amazon. However, some of the best prices can be found by cruising their social media pages for special sales from woodworking retailers i.e. Woodcraft etc. For the month of June, a few - If you are thinking about attending the St. Paul, MN symposium, Easy Wood Tools will be well represented- And another shameless self promotion- @Jordan Martindale New Turning Items- Everything Else- From Ron Brown's Newsletter: Good Enough Perfection is often unattainable, and just as frequently, unnecessary. I hear from turners all the time who proudly sand salad bowls to 4,000 grit. Anything above 320 grit is just a waste of time and effort for most wood projects. However, acrylic and resin projects may well benefit from using abrasives up to 12,000 grit. The caution here is not to get bogged down in the last 2 percent trying to make something perfect when 98 percent of the work is very close to perfection and Good Enough. When I used to build custom furniture from cherry, walnut, oak, and hardwood plywood, I quickly discovered that stopping at 220 grit produced excellent results. Especially when covered by sanding sealer and pre-catalyzed lacquer as finishes. It’s true, sometimes less is more. The secret was to be careful with each finer sanding grit, ensuring that all scratches from the coarser grit were entirely removed. That is where patience really pays off, as I deliberately go over the entire surface, then examine my work with a raking light source before moving up to the next finer grit. Most folks don’t realize that excessive sanding with fine-grit paper creates heat that releases and then hardens the lignin in wood, often resulting in a splotchy finish. The finishing material will not be able to penetrate the surface evenly, and it looks awful. If you’ve ever blown up a bowl, it usually comes from making one last cut to get the finish just right and the walls as thin as possible. You forgot that wood moves and bowls can go out of round as you turn, even if they’ve been drying for months. As wood is removed, the moisture content can change, causing the thin walls to warp, or harmonic vibration to set in. That final cut produces an unexpected catch and bang! Fresh bowl pieces are lying around the shop once again. The problem with patience is that it takes so long. My projects rarely turn out exactly like I see them in my mind. My hope is to bring them close to my idea of perfection and bring them to the “Good Enough” stage of completion. I know some of you think I’m smarter than I actually am. What you see are the results of persistence, patience, and starting over many times before I was able to show you a finished version. You will never see the eight failures that came before. Remember how WD-40 got its name. I would rather have you do something slowly and well than do it quickly and poorly, sometimes referred to as Half-Fast. Many years ago, I got tired of hearing myself say “Oops! I didn’t see that before, and now it’s too late to fix it.” I am deliberate in my inspections before proceeding to the next step. It is always easier to fix it then, rather than several steps later. Safe turning
- 5 replies
- wednesday
- wisdom
(and 32 more)
- wednesday
- wisdom
- woodturners
- raffle
- fund raiser
- questions
- jam chuck
- neoprene
- lathe sale
- lathe selection
- buffing
- aaw symposium
- st.paul mn
- cindy drozda
- tool talk
- zoom
- threads
- sam angelo
- spindle gouge
- tomislav tomisec
- tips
- popular woodworking
- sharpening
- scrapers
- mike peace
- embellish
- bleach
- burn
- jimmy clewes
- coffee scoop
- easy wood tools
- ron brown
- newsletter
- sales
A lot happening this week! Our Patriot Turners- New member @Turn n Learn posted a question about chuck jaws and which ones we use. He is lucky enough to own an Easy Wood Tools chuck. Please stop by his post and see if you can add to the advice or members gave- This is his chuck- And a picture of his lathe- Tony introduced himself Please make him feel welcome! We've had a couple of additions on our "What's On" running post. @Gerald and @calabrese55 both added items. See more images and check out how Mike makes his segment calculations starting here- @Fred W. Hargis Jr is making great progress on his coin holder plaques. He posted this picture in the General Woodworking forum- Fred tells us where he is in the build- What’s Coming Up- Click on the images for links to more information and registration. For The Newbies- A nice video from Craft Supplies USA on Scrapers. Covers the use, sharpening and some of the myths about scrapers. Expand Your Horizons- Turn Geometric Shape into a box, a hollow form for this months "4 Ways" collaboration. Some really neat ideas! John Lucas has published a new video on turning an end grain bowl. This short video is just a preview. All John's videos are available from https://www.glennlucaswoodturning.com/product-category/guides/ Turning Time With Easy Wood Tools- One of the more recently added products to the Easy Wood Tools line up is their Wire Burning Kit. The set consists of two handles and 3 sets of wires. Both wire ends have colored plastic grommets for quick attachment to the handles. Red grommets signify .016 diameter wire, white grommets are .020 diameter wire and blue grommets are .026 diameter wire. Each gauge wire is available in 3 lengths- 6", 9" or 18". This video from Carl Jacobson demonstrates the burning operation And this shows the product being unboxed and used If you are in any of these locations, during June, check out the live Easy Wood Tools demonstrations and take advantage of the sale prices on all the EWT products- A little shameless self promotion (above right) @Jordan Martindale New Turning Items- A new item from Ron Brown to help with centering a turning blank, on the lathe. Ron calls it a "Centering Genie" A short video of the operation- A bunch of sales on turning tools are currently happening. From Lyle Jamieson- http://lyle@lylejamieson.com From our sponsor Woodcraft- https://enews.woodcraft.com/q/0fOPEbuuaMTfutmbE1_HFhUhY0i90HGE0R4AaZvh1CIRPbWQSj2NQL50r Spiracraft is having a 3 day sale. You may remember that Bradley is closing shop, for a while, due to health reasons. https://spiracraft.com/ From Taylor Tool Works- https://taytools.com/ Everything Else- I'm doing a local club demonstration in August. I thought explaining/showing how the John Beaver wave bowls were made would be an interesting presentation. The process from start to finish can take a couple of days due to glue drying time so I thought I would make several bowls showing the stages of development. Those 7 roughed out spalted sycamore bowls have volunteered. Four have been drying for about 8 days and the other 3 for 5 day. I weigh them every day and look for checks/cracks/splits Only 2 of the bowls have shown excessive cracks. I used CA on them as soon as the cracks appear and that seems to stabilize them. The crack were expected on these 2 due to the branch inclusions/knots. I think they will be fine for the "early stage" of the bowls construction. Safe turning
A little early with Wednesday's post. 71° outside and I've just been informed I'll be cooking supper on the grill tonight Our Patriot Turners- @John Hechel posted in our Ringmaster Sub-Forum showing us an awesome bowl he fabricated from a neat glue-up. Check out his post for more information- We had activity on both our continuing posts about projects on and off the lathe! From "On" the lathe- From @calabrese55, @RustyFN, @Pauley and @kreisdorph showed us these beautiful pieces! Catch up on all the action and comments beginning here- From "Off" the lathe- Both @RustyFN and @Gerald shared their fantastic projects- More here with comments from our group- What’s Coming Up- Click on the images for links to more information and registration- For The Newbies- I always struggle with the concept of "Form vs. Function". Lyle Jamieson gives us his thoughts in this short video- Richard Raffan adds another chucking idea for hard to hold pieces- We sometimes post links to the Woodturners Wonders site for their products/sales. I found this link with videos about many of their products. (Full Disclosure- I am not affiliated with Woodturners Wonders. I do purchase some sanding supplies from them from time to time). https://woodturnerswonders.com/pages/videos?_kx=gV5SF2As_3IwtBi5TrpHVQGZ2p91Dzyb6Hq8u86HRP26F2J3AVp8xSSqd_hTF8cT.VJvU8R Expand Your Horizons- If you do the Craft Show circuit, Carl Jacobson shows us a project that might be an addition to your product line. This project from Mike Peace would make an awesome gift and could also be a craft show article. It lends itself to design customization- When I saw this from Alan Stratton, I thought of some of the embellishments done by @Gerald. New Turning Items- Couldn't find anything this week Everything Else- Something I need to learn more about, from Rom Brown's Newsletter- Technical Skills or Wisdom and Discernment? When you see a finished piece that is visually stunning, do you ever wonder what made it that way? Perhaps the end result was because the maker has superior technical skills with lathe chisels. It is much more likely they got the proportions just right, presented a balanced form, and knew when to stop and call it done. A great form can make even a bland piece of wood appear pleasing. If the material is ordinary, that is an opportunity to add embellishment such as painting, carving, or texturing to the great shape. Out of balance shapes, non-fair curves, sloppy transitions, deep sanding scratches, tool marks, and torn grain all contribute to a less pleasing finished piece. While technical skills go a long way toward reducing the time and energy needed to complete a project, I’ve seen many beautiful pieces completed by much less skilled turners who developed an eye for forms, paid attention to details and worked on the finish until they got it right. That means having the wisdom to know what shapes go together to make a pleasing finished item. A prime example where discernment is key might be a lidded hollow form, lidded small box, or Christmas ornament. Getting the finial in balance relative to the piece, or a lid and knob combination that compliments the box can be challenging. Discernment is knowing when to stop and move on to the next step. Those of us who have a loving partner will benefit mightily by asking their opinion on how a project can be improved. Ask for their honest observations and tell them you can only learn by seeing through someone else’s eyes. They won’t want to hurt your feelings, but this is a time for brutal honesty if you really want to improve. “Technical skills are important, but a discerning eye is importanter.” I would encourage you to develop your understanding for the things that result in a pleasing form along with your technical expertise. I studied shapes in other media including pottery and ancient vessels that survived the ages and it really helped. Don’t forget how important the Fibonacci formula is throughout nature. Safe turning
- 5 replies
- valet
- wednesday
(and 32 more)
- valet
- wednesday
- wisdom
- woodturners
- bowl
- ringmaster
- vase
- segments
- bowling ball
- rocket ship
- natural edge
- lids
- aaw symposium
- adirondack woodturners
- tool talk
- cidny drozda
- egg turning
- lyle jamieson
- hollow vessel
- sharing session
- todd raines
- vendor showcase
- function vs form
- richard raffan
- chuck extension
- product videos
- woodturners wonders
- carl jacobson
- craft show
- mike peace
- alan stratton
- inlay
- embellishments
- ron brown newsletter
Remembering all my Brothers and Sisters on this 50th anniversary of the end of the Vietnam War, Welcome Home. Our Patriot Turners- @Headhunter posted some of his Ringmaster turnings in our sub-forum. Thought it would be nice to share them with the entire group. He also posted an awesome open segment turning. Headhunter was kind enough to add a photo of how he created the blank to create this beauty. @forty_caliber Has bee working with some spalted pecan. I really like the way he embellished the rim of this bowl- Check out his post to see what our turners had to say- Forty also posted an inquiry asking if any of our members had any experience with a specific type of knot/gap filler. Please check out this post and offer any additional help- Can't express how happy I am to see everyone adding to our continuing thread of "What's On Your Lathe"! Some of the recent additions include- This is about where we left off last week- What’s Coming Up- Click on the images for links to more information and registration- For The Newbies- Found this article that compares these tools. https://turnawoodbowl.com/carbide-vs-traditional-hss-wood-turning-tools-high-speed-steel/ Alan Stratton's video on turning a box from tree to display. To add interest to the turning, Alan burns some detail lines. Check out his wire burning tool at 9 minutes- Expand Your Horizons- Carl Jacobson turned a small lidded box, and used the urn threaded rings. This was a live demonstration so it's a little long- Mike Waldt turns a hollow Mulberry hollow form- New Turning Items- Couldn't find anything new but checkout this week's Vendor Showcase (link above). Not sure what they will be doing. Everything Else- From Ron Brown's newsletter- Driving A Stake In The Ground Sometimes progress seems so slow that you have to drive a stake in the ground to see if you are moving. I first heard this phrase when I worked on the railroad as a long-haul trainman. The first half of our route took us from near sea level over a 4,000 foot high mountain range. Sometimes I could run alongside the train faster than it was moving! Developing our skills can be a lot like that. You want to be able to use a skew chisel like they do on YouTube and roll perfect beads, disks, and wonderfully symmetrical coves. But you get catch after catch and it seems like you are never going to figure it out. Or the grain tears on the outside of your bowl blank even with freshly sharpened tools. You wonder if you will ever be able to start sanding with 120 grit or higher rather than 60 or 80 grit. You look forward to the day you don’t have to spend so much time sanding. Practice makes perfect because each time you try, you get a little bit better. You develop muscle memory whether you know it or not. Suddenly, or so it would seem, you can roll a beautiful bead with that skew and not get a catch. Where is the stake now? I used spinning tops as my demonstration canvas on the Woodworking Show Circuit for 13 seasons. I glued up 1,200 top blanks at the beginning of each season and more when those ran out. All day long I would load a blank into the lathe’s collet chuck for my next demo. I used a skew to turn the disk to round in less than 3 seconds. Then I shaped the disk in preparation for texturing. That took another 10-15 seconds, one pass on the front, and one pass on the back. In one continuous motion, I shaped the stem using the same spindle gouge I had shaped the front and back of the disk. Then I made 3 cuts with the texturing tools and finished with various color combinations. I had developed so much muscle memory that I could carry on a lucid conversation and make the top at the same time. Elapsed time, less than 5 minutes including all of the decoration and coloring. It didn’t start out like that, but after the first thousand tops, it got easier. I’ve told you before that you don’t really know how to make something until you made 50 or 100 of the same thing. Then you begin to understand but still have much to learn. So, drive that stake in the ground, metaphorically, and watch as you get better each time you try again. Remember that wherever you go, there you are. Safe turning
- 4 replies
- hollow form
(and 24 more)
- hollow form
- mike waldt
- threaded inserts
- lidded box
- carl jacobson
- wire burning
- end grain box
- alan stratton
- kent weakley
- carbide vs hss
- derek weidman
- sculpting on lathe
- presenters
- aaw symposium
- vendor showcase
- tool talk
- cindy drozda
- whats on your lathe
- gap filler
- hot melt
- ringmaster
- bowls
- woodturners
- wisdom
- wednesday
Big doings at Gobbler's Knob tomorrow! Will Phil see his shadow??? Our Patriot Turners- @jthornton has finished up his popcorn bowl! And, what a beauty it is! His post picks up at- @HandyDan commented on JT's glue up and showed us the kind of glue he likes to use. Thanks for the tip, Dan! A while back @John Morris asked about our favorite 3 turning tools, JT posted this about his- JT also shared a video of a young man using a very creative way to make a vase. A little scary at a couple of places! @forty_caliber added some really cool instrumentation to his drying box. He tells us a little more here- And, it is pretty obvious that Forty's drying box works great. This is his first bowl he turned from his kiln- Check out more image in his post- @Masonsailor made a glued up bowl blank but he didn't use any of the traditional methods. Check out how Paul milled the blanks and what type of finish he used- What’s Coming Up- Click on the images for links to registration and more information- From Cindy Drozda- For The Newbies- Sharpening traditional turning tools can be made easier by using a sharpening system. In this video, Sam Angelo demonstrates the use of the Wolverine system- You've spent a lot of money on that new lathe! Here are tips from Mike Peace on how to keep it in top condition. NOTE: this is a video from a live presentation so it's a little long- Turning a bowl can be a intimidating at the beginning. Kent Weakley offers some tips to help you along- Expand Your Horizons- It's always fun to watch Richard Raffan. He makes it look so easy! Two recent videos in which I found some techniques to help me. In this one, I was amazed at just how shallow of a mortice he used for reversing the piece- And here, the hollowing seemingly done with wild abandon and yet perfectly executed- Make some of these for the grandkids and then send them home to their parents- Last week, we posted a project called a Salt Volcano. Alan Stratton gives us a some insight on the design Finally, Carl Jacobson uses the new Niles bronze thread inserts to make a pill box- New Turning Items- Thread cutters/chasers are not new but this tool has a neat design by combining inside and outside threading operations in one. https://spiracraft.com/product/carter-and-son-toolworks-double-ended-thread-chaser/?inf_contact_key=8268ca260892678527d2626eaa684eee Video from Carter and Sons demonstrating the tool. https://vimeo.com/788457481 Everything Else- Rick Turns list of YouTube woodturning videos from last week- And from Ron Brown's Newsletter- Artistic License Another reason turning wood is so satisfying is the total creativity allowed when turning most projects. Take pens for example; simple and straight, curvy, puffy, long, short, wood, plastic, bone, resin, one-piece, two-piece, pencil, ballpoint, or fountain. A quick look on Facebook, Etsy, or YouTube will reveal a wide variety of examples. While we all have our preferences, the folks who made each one loved every minute and are just as proud as the next fellow is of their creations. Some folks strive to make their turnings perfectly symmetrical and seemingly flawless. Others are just the opposite reveling in off-center, out-of-balance projects leaving as many natural defects and voids in the final product as possible. Aren’t all of us just like that; off-center and out of balance according to someone else? I often repeat the phrase “Everyone seems normal until you get to know them.” I’ve come to realize that is the beauty of my fellow beings. There is a reason that everyone is a unique combination of God’s creation. That is what makes them special. Yes, there are accepted standards of what makes a great shape for a bowl, vase, pen, urn, or finial. But who says those are the only pleasing shapes? I encourage you to use your artistic license to explore something outside the traditional shape, material, or order of things. My friend, Michael Gibson turns ultra-thin vessels, then pierces and colors them so they become something you might find floating in a whirlwind in the forest. Some would seem to be so fragile that merely looking at them may cause them to break. I discovered the joy of turning green wood from start to finish in one session just so I could see how much it would warp and distort, not unlike myself. Now I sometimes even add rubber bands to help it along! Celebrate your artistic license as you stand at the lathe and welcome each new friend, knowing they are probably just a little bit off-center too. Remember that wherever you go, there you are. Safe turning
- 8 replies
- ron brown
- rick turns
(and 30 more)
- ron brown
- rick turns
- spiracraft
- thread chaser
- carter & sons
- pill box
- carl jacobson
- alan stratton
- salt volcano
- chipper
- tim yoder
- richard raffan
- egg cuo
- square dish
- kent weakley
- bowl tips
- mike peace
- lathe maintenance
- sam angelo
- wolverine
- sharpening
- cindy drozda
- aaw symposium
- lyle jamieson
- drying kiln
- favorite tools
- glue
- segments
- bowls
- woodturners
- wisdom
- wednesday
Coming up on the middle of May already! Our Patriot Turners- @Gerald gave us a peek at a couple of bowls he has finished. Gorgeous wood and designs. Check out his post for more images and descriptions of what he has done What’s Coming Up- Several turning events and IRD's. Click on the images for the links to registration/information. TOMORROW MAY 12, 2022 For The Newbies- Looking for something new to try? Check out this neat idea for holding a mirror, turned by Jennifer Shirley- Before starting a turning, it is often wise to consider what type finish it will have. In this video, Sam Angelo discusses his thoughts on the subject. Expand Your Horizons- Most of the time turners do a lot wood prepping to prevent a turning from warping. In this video, Alan Stratton experiments with green wood to see the results of warping- New Turning Items- The lid is off the secret! New Easy Wood Tools products are now available and shipping!! Thanks @Jim from Easy Wood Tools!!! Here's the link to the Easy Wood Tools site for ordering- https://www.easywoodtools.com/shop-lathe-accessories This video shows Carl Jacobson turning a bowl, using the new rings. These are the quality you would expect from Easy Wood Tools. VERY heavy, lots of mounting holes, absolutely now slippage between the chuck and ring and no runout on either the side or face of the rings. This is a PDF of the announcement- New Public Product Announcement May 2022.pdf From Ultra-Shear, a new pen mandrel Click on the image for more information. Woodturners Wonders is running a sale on CBN Hones https://woodturnerswonders.com/collections/sales Everything Else- Rick Turns list of YouTube woodturning videos from last week- Safe turning
Punxsutawney Phil saw his shadow this morning. Not sure if that's good or bad news. Seems like winter has been wasted around here. When it's cold there's no precipitation. It warms up and then we get rain. Our Patriot Turners- Our resident ornament master is at it again. @Ron Altier posted some things he created from just scrap pieces. Ron sure has an eye for design- Check out his post for additional details and some of the comments left by our members- @Steve Krumanaker picked up some elm from his son. Steve turned some lovely bowls. As always, he adds his personal touch to the bottoms- Steve showed us more images in his post- Steve also found a way to keep busy when it was too cold to work outside In his post, Steve explains how he attaches the removable roof @Bundoman Has been teaching his daughter about turning. Looks she is a natural and has created several imaginative pieces- Head on over to this post to see what he and his daughter have made- @Gerald decided to try his had at making a scoop shown in a video from last week's post- You can check out what he said here- What’s Coming Up- Click on the image for the link to more information- For The Newbies- A couple of turning safety videos from Mike Peace- I recently saw another turner use this method of reverse chucking a roughed out bowl to finish turning. Here's Richard Raffan showing us who it's done- Wondering how to dry that wet wood turning? Tim Yoder tries a different way. Check out Tim's use of those Easy Wood Tools! ( @Jim from Easy Wood Tools ) Expand Your Horizons- The Woodturners Worldwide Online Symposium offered many interesting presentations. This one from Cindy Drozda on turning a sphere- Mike Peace has a 2 part video on embellishment and embellishing tools. These were made available through the AAW. Richard Raffan turns a beautiful wide rim dish- Alan Stratton continues his series on offset turning. The beginning of this video describes the modifications he made to his original shop made jig- New Turning Items- From Turners Warehouse for the pen turner (click on the image for the link)- Package deal for bowl turners from Woodturners Wonders (click on the image)- Craft Supplies USA has some new kitchenware items (click the image) Ruth Nile has Penn State Pizza Cutters back in stock! Check Ruth's site- https://nilesbottlestoppers.com/product/pizza-cutter-2/ This past weekend was the on-line symposium from Woodturners Worldwide. Cindy Drozda did an informative presentation on live tail stock centers. Although these are not new, it should provide guidance for those in the market for one- Everything Else- From the AAW, a tribute to Stephen Hogbin- Rick Turns list of YouTube woodturning videos from last week- Safe turning and stay well
- 6 replies
- wednesday
- wisdom
(and 28 more)
- wednesday
- wisdom
- woodturners
- ornaments
- bowls
- birdhouse
- honey dipper
- scoop
- aaw symposium
- cracked wood
- turning speed
- bowl remoung
- oil dry
- easy wood tools
- sphere
- cindy drozda
- richard raffam
- embellish
- mike peace
- eccentric jig
- alan stratton
- pen pushing
- sanding
- pizza cutters
- kitchenware
- live centers
- stephen hogbin
- rick turns
- videos
- snowmen
Heads Up! The Patriot Fundraiser has been extended for a few days. If you haven't had the opportunity to get those raffle ticket, you're in luck! Check this post- Sorry about no post last week, we were at the shore last week celebrating our 45th wedding anniversary, Our Patriot Turners- @RustyFN gave us a tip on where to purchase some upgrades for a vacuum chuck as well as some other great specialty lathe drive accessories- Check out their website at https://www.rubberchucky.com/#/ Rust also added a new piece of equipment to his turning arsenal- He received lots of positive comments on his acquisition. Check out his post- @AndrewB is finishing up a pepper mill. He is really getting to be a professional at cranking these out Check out his post for some more images of his progress- We don't hear much from @Cliff but when we do, he is always looking at some thing interesting. Recently he is considering making a thread chasing jig for his lathe. Hope he posts it when it's finished- It may be the beginning of summer but that isn't stopping @Ron Altier from making Christmas ornaments! Please hop over to Ron's post for a description of what he did- Ron also posted a picture of a bowl he found at the thrift store. Someone put a lot of work into this turning! Please see Ron's post for additional photos- Speaking of bowl finds, @Steve Krumanaker came across a unique bowl while on vacation- In his post, Steve tells a little more about this one- @forty_caliber put his Longworth chuck to good use in making a project for his daughter. He tells us a little more about this sweet segmented turning in his post- @Gerald got a great start on a bowl being turned from a root ball. The colors in this are fantastic- Gerald shows us some more images and explains some of what he has done in this post- Gerald provided us with a way to keep up with the Magnolia Woodturners Club, of which he is a member. This is a Facebook page. Facebook has become a popular way for woodturners to communicate and display their turnings. You can see some of the awesome turnings produced by the club's members by following the "Visit Website" button. @HandyDan helped out a friend by reproducing some chair spindles. These sure are perfect replicas! Check Dan's post for all of the kudos he received from our members- Although posted in our general woodworking forum, the content applies to all aspects of woodworking. @kmealy gave us a link to an article on pricing your work, originally published in Fine Working. A great discussion ensued. Thanks, Keith! New member @woodburner59, gave us a his first impressions of a new book he has added to his library. We are looking forward to seeing some of the turnings Scott produces. What’s Coming Up- With the AAW Symposium coming up, I've been trying to provide the latest information. These two items are related to that symposium. Click on the images for links to more information- Vendor Showcase! Free Zoom meeting! This one is a little bit in the future- Do you have a special interest and want to see/do an interactive demo? Captain Eddie and the World Wide Woodturners group is looking for ideas- For The Newbies- Another Mike Waldt video aimed at the beginning woodturner. As this is a live demo, it is quite lengthy but has a lot of great tips- From Woodworker's Journal, a nice project by Ernie Conover turning a tray- Expand Your Horizons- A short video on making a lamp from green wood, from Woodworker's Journal Captain Eddie was one of the early experimenters with CA glue as a finish. Capt. recently added a video on tips and hints of CA finishes- New Turning Items- Didn't come up with anything, although, the Rubber Chucky website Rusty mentioned does have an alert on their homepage to watch for some new products. Everything Else- Rick Turns You Tube woodturning videos for the past 2 weeks- Before we left, I did have a chance to finish up the little spalted elm bowl. I turned it to the finish dimensions and then left it dry in my little air kiln ala Rick Turns. Need to get some better picture- It's been warm here so I spent time in the cool basement shop. Got started on a large cherry bowl that had bee drying in the air kiln- Had to make a run for some supplies today. Mimi said she was going to vacuum the pool. This is what I found when I got home- They stayed most of the afternoon! Safe turning and stay well
- 8 replies
- raffle
- vacuum chuck upgrad
(and 24 more)
- raffle
- longworth
- pepper mill
- thread chasing
- ornament
- bowl
- segmented
- coconut
- turned box
- walnut root ball
- magnolia woodturner
- spindles
- richard raffan
- book
- aaw symposium
- vendor showcase
- cindy drozda
- virtual woodworking
- captain eddie
- ca finish
- mike waldt
- ernie conover
- tray
- turned lamp
- videos
