Showing results for tags 'tool chest'.
  1. steven newman
    Something for this September?
    Decided to clear off a spot...donated an un-used MitreBox and saw...that was just sitting around and getting rusty.... Had 2 to send over to the Lutheran's Thrift Store...the area back there in the red circle...needed cleaned off.... Thing with a motor? A Wen Power Planer..about the size of a Stanley #5 Jack plane, and 3 times the weight... Had a stash of Ash planks I was going through, cutting out the bad areas....I sorted through the stacks...found enough to lay out... Imagine the ones laying flat as Drawer Fronts, and the ones standing up on edge as the dividers between the drawers...this gave me a measurement as to how TALL a case I needed to build...20"...then from there, I got a depth of 16" and a width of 24"...roughly... Next, find enough parts that were long enough to make a panel for the top, and 2 panels for the sides.. Cross cut a few for length...and laid out for the top panel.. left stick needed ripped down a bit(Didn't feel like lowering the saw blade just yet) Ripped that extra off, along with the defects along the outside edge...rearrange a few boards...some needed to be jointed.. We have ways... worked my way through, until.. Last edge...then set up for a glue up..(lowered the saw blade, this time) Spread a bead of glue along one edge, rub that edge against the next edge..repeat as needed...1 clamp on top, 2 clamps underneath..let this heavy mess sit a spell... Sorted out enough boards for one of the 20" long/tall sides... These will need cross cut, and the one on top need ripped down a bunch...then repeat for the other side panel... Same here, these need cross cut for length, jointed and maybe one ripped for width.. Plan at the moment...top corners will get through dovetails...and maybe a slight round over...Bottom divider, will be the "bottom" of the case...and sit in a rebate...may add feet of some sort. Maple runners for the drawers to slide on, front "dividers" out of Ash...both the runners and the dividers ( other than the bottom) will be in sliding dovetails...back of case is to be 1/4" plywood, glued and screwed into a rebate along the sides and the underside of the top... Then, build 5 drawers.. Should be fun, stay tuned...
  2. steven newman
    If only..
    Was just wondering how much to assemble one of these things.. Tool Chest No. A... Yep..a whopping $20 back then...Move up a bit, to the #B.. To put another 23 tools in the chest, it will cost you another $20 Maybe see what Chest #C has? 87 tools...$60.00 ? Almost afraid to look at Chest #D.. Not as many tools, just a fancier case to store them in...still $60.00 Well.. Afraid this would be about the top of MY budget... These can be found in.. This Swan Catalog...from 1911....
  3. Version 1.0.0
    41 downloads
  4. View File Workbench Magazine May-June 1968 Custom Made Tool Chest This is a scanned document of the now defunct Workbench Magazine of this era. Permission was granted by the new Workbench Publication for The Patriot Woodworker community to copy and use the old Workbench Magazine at our pleasure, and for free distribution and re-use. Submitter John Morris Submitted 04/08/2023 Category Shop Furniture
  5. steven newman
    The Tool Chest, a $0.05 Tour
    Tools have been put away...until needed. More of a "Ready Rack" for the most used saws in the shop....Time to open the doors for a look around? The Left side..and the Right side...a little further to the right... Is the Main Plane Til.... Just a quick look around...unless someone wants "close-ups"...
  6. steven newman
    A Project for June?
    May post a sign..."Watch this space".... Red lines are how much room I'll have. Need a chest of some sort to place all of this "stuff" in...and maybe dress up the area? Wondering IF 22 bdft will be enough.. Thinking about taking the 4 longer planks (5' long) and gluing up 2 panels....to make a front and back , and 2 ends....then the rest for the frames...will have to work around a couple live edges, too. Intend to build the "box" first, then build a lid to fit...may need a couple more planks? A Hobbit sized Tool Chest? At least enough to hold all that "stuff" on the floor... Area I have to work with...Length can be around 32"....height is 17"...with lid. front to back works out to be around 16" Frame & Panel.....Flat faced panels, or...Raised Panels..hmmm...we'll see.. Stay tuned..
  7. I'm going on a mission trip next month. No idea what particular projects I'll be doing, but in general Katrina rehab/repair. I was thinking about building a tool tote to carry my hand tools. I've been wasting time looking at youtube, pinterest, and general postings on tool boxes for a few days. What a remarkable lack of diversity there is. Open top tool totes with a handle or divider that runs from end to end, with or without a drawer bottom (have a couple of those, including my first from '70s made from a fruit crate) Open top box or crate (got a bunch of those, most in use) Carpenter's tool boxes, circa WWII. Tall not very wide, one side opens up and there is usually a till at the top of the main case (yep,, gave that one away) Jeremy Broun's tool box, essentially a smaller version of the prior item, but with both sides that open Just a box with a lid (big or small) maybe with a till -- got one of those Tool Stool a la Gary Katz . Might have two levels. I have a couple of those, not nearly so fancy (basically a saw bench) Stacking box Japanese tool box (couple of those that I've used on prior trips, now hold my Shaker oval box kits) Larger box a la Frank Klausz's box that he wrote about in a magazine Machinists' style boxes like the Gerstner Then there's the Anarchist's Tool Chest and Dutch Tool Chest and wall tool cabinets, not all that suited to portability. Meh. I think I'll just load up a couple of my nylon bags. I really like the backpack bags but I'm not sure I want to spend the money on one. My work kit is well tuned to what I do, but that includes repairs to cabinets, doors, and drawers, repairs to upholstered furniture springs, frames, recliner mechanisms, and fabric parts (remove and replace panels, or to get to the insides), and structural repairs to wood parts.
  8. kmealy
    plywood tool chest
    Chris Schwarz does a simple too chest
  9. steven newman
    Something to do in August?
    Hauled a few planks to the shop...wanted enough to make 2 panels.....Not the best looking boards....but at ~$0.80 per Bft...oh well....Wanted 6 planks ~ 24" long... Cut out some of the worst spots.. Not too much I can do with these...maybe burn them? Edges were a bit wavy....so, set up the tablesaw's rip fence.. Idea being slide the best edge along the fence, and just skim off the wavy stuff...mark THAT freshly sawn edge.. With an "X"....reset the fence a 1/4"....slide the edge with the X along the fence... And now I have a second straight edge, parallel to the first edge....But....3 boards made a wide panel..too wide...2 of the planks had some bad areas...reset the fence.. And we have a filler strip. 2 wide planks were at 10-1/4" for the width...had some gaps to clean up, too...so (hand tool time!) Clamp a board to the bench, and get out the Cordless No.6 Jointer... Stanley No. 6 Small Jointer Plane. Then check for gaps... Repeat for the other wide board.... No gaps...Clear of the tablesaw, we have more work for it to do.... Set out 2 pipe clamps...moosh some glue around....add the upper/middle clamp..still no gaps....added cauls at both ends, to keep things flat...then back to the bench.. need to prep these for a glue up...once Panel No1 is done. Again, No. 6 Jointer at work.. No gaps? And.... Not too bad? Again..it is just sitting there, no glue, no clamps nor braces (don't sneeze!) haven't decided on how wide, how tall, what size drawers, or how many.....and what kind of lid...got all of August to figure it out.. Single Brain Cell Sketch Up.....stay tuned
  10. steven newman
    From the album: Just a Tool Chest
  11. steven newman
  12. steven newman
    Well, what did you expect for just $3?
    Well? Start out with a small roll-around tool chest. . Bottom compartment was missing it's shelves....Can always add some, IF needed.. Top chest did have a few "treasures" in it.. 1 good wrench, so-so pliers, gauge for spark plug gaps...and 3 spanners. Look carefully at the lid...there is a Blue Grass nail set sticking to the metal lid. Also dug out of the top compartment... A decent 5/16" wrench, a pin punch, 2 SMALL screwdrivers, 7/16" nutdriver, flexi sharpening sticks, a sharpening hone, and 3 files. Yep, that be a corncob handle..tossed thewee screwdriver wannabe. Driver bit is a long, hex shank, slotted bit...next, the top drawer.. May just toss these. Middle drawer? Wrench may get tossed. Brightyellow handle is an Irwin....more on that can opener in a bit...bottom drawer? Interesting selection. That skinny thing is a 4" XSlim saw file. 2 cold chisels could use a little cleaning up...not sure about the chisel, Crestoloy Wrench. Goodies? The small saw file. The nail set is by Blue Grass Center punch is by Herbrandt...now, about that can opener? Ring a bell with anyone? From BEFORE Pull tabs were even used.... same Yard Sale, bought 2 pair of "Cheap Sunglasses" for a dollar...total for that sale? $4.. Not too bad of a morning?
  13. steven newman
    Ye Olde Tool Chest
    Is no longer needed.....I need the shop space it is taking up. Went to check on how to get this thing out of the shop... This MIGHT be "fun"....Opened it up....found an old tote inside.. And a pair of slider trays.. . Spider hotels, actually....there was a few tools still inside... Walden-Worcester 3/4"/12mm socket, was still attached to the Williams speed bar. Pliers are 6" H. Bokers, not sure about the 1/2"' ratchet wrench, 5/16" chisel, 10" Crescent Co. Jamestown...and, a pair of round-nose scrapers... Hm, I don't have a lathe, any more. There are brace bits that aren't worth trying to dig out of a rack...so, I think that is all there is inside.. May keep the trays and tote...and the tools....box will be headed upstairs, and out to the curb....first come, first serve. Need that space it is sitting in...for other stands.....part of the shop clean up going on...
  14. steven newman
    A cabinet for some tools
    Ok, might as well get started....this all came about because of a royal mess ( aka cluster-....) of tools piled up, and getting dusty and rusty.. yeah... So..have been going through all the tools, deciding which to keep handy, and which to stash....(cleaned up down in the Tool threads.) Picked up a few pine boards the other day... Ten 1 x 10 x 4' planks....not the best looking ones on the pallet...but, will do for a tool cabinet build... A few 1 x 4s as well. Handsome, ain't they....$45.75 counting tax.... So, today..the pick of the litter..4 planks of 1 x 10 were hauled to the shop....goal WAS to build a cabinet 3' wide, by 4' tall...WAS...until I stood one of the up, where the cabinet will go... Sitting on a 3' tall toolbench....another 4' would have been a bit too tall....design change! so that instead of 4' tall, it will be 3' tall...yet still 3' wide..needed to trim the worst ends of the 4 planks...one even split after the saw made the cut.. Not up for that much Cardio, today....besides.this is a Vintage SKIL saw... Should be enough to do this job... Once they were all trimmed down to 36", time for the jointer. . Except this Jointer was New in the box about 1905 Stanley No. 7c, type 9 needed the edges jointed for a BIG glue up....first was the start of the mess..and the cussing.. Have 4 planks to glue up, and I didn't want 2 to fly apart while adding the next one..problem was finding long enough cauls....and clamps.... Came out to 36 x 37"....glue lines will be vertical, once the glue is cured....looks like I am done, for the day. Need to decide how deep to make the box itself....a 1 x 10 may not quite do it....may glue those 1x4s to the four 1 x 10s for the box......then decide how to join the corners, and the back to the box.....making me head hurt, Imagine trying to cut the ends square on this "little" panel... Stay tuned...this might take a day..or three
  15. kmealy
    The "Studley"
    A tour of a classic
  16. steven newman
    Starting to Work on a "Chest"
    Got to start somewhere. Breaking down a couple of 4/4 x6 x8' Walnut planks. Cut a few down to match the raised panels I made a while back. Cleaned up the rough sawn edges a bit, and marked them for a rip cut. After a rip down the middle, these will go on the ends, to house them raised panels. Going to get these to a somewhat finished sized, and then smooth the faces up. Less to plane, that way. Tried to handsaw these boards down, ran out of breath ( COPD??) so an OLD Sears Craftsman Circular saw was used. It will also do all the rip cuts. Corner posts were straight edged up. Then set up for a rip down the middle. I'll then add a Tongue & groove joint to the edges of the corner posts.
  17. steven newman
    Tool Chest Part 2
    Install a lid. and a seal coat. Found some water a-going across the Dungeon floor today. Figured I get the lid on, and then seal the wood up. First the hinges a bit of chisel work with just a few hand tools. Scratch awl is a Stanley. Used it to make some pilot holes, then ran a screw into each. After start to get things together....found the hinges were on up-side down....ooops. Re-install the hinge, right side up. Brass screws that came with the hinges were a bit too long. Grinder made them the right length. Lid also has a pine cleat on one end, to keep a crack in place. Used the un-cut end of the cleat as a hand-hold, while screwing down the hinges There were a bunch of counter-bored screws on the case and lid. Went out and got some store bought plugs. The seven on the edge of the lid were easy, lid was standing up, just add some glue, and a plug. Tap down until flush with the end of the mallet. The sides, however were different. Needed an old block of wood, drop a big blob of glue on it, moosh the plug around a bit, and install with the mallet head made a mess of the mallet. the plugs were then planed down a bit this was a before a block plane leveled them down. Well, that is about all for wood working..... oh yeah, a seal coat? remember, this is just the first/seal coat. Raised panels on the ends are Sycamore. Another view? and maybe a look at the lid? there is a big, fancy word for that strange shine, begins with, Chato.....?
  18. John Moody
    Patriot Picking in June
    I was out the other afternoon and drove by a place getting ready for a yard sale. Got out and walked up and was told to look around. I saw this great looking old tool chest under a table and looked at the price. I ask them if this was correct? Really $5.00 for the chest and the contents. Right off I could see a wooden moulding plane and all kind of bits for a bit and brace drill. There were some small rulers in still in the boxes and a jar of corks. It had a little hidden tray that you pull up and it had a old cast plumb bob and several other items. Well for $5.00 I had to take it home and Steve it didn't come from Ohio while I was passing through there. I love finding old treasures. The lady told me it was her grandfathers old tool chest. I told her I was a woodworker and she said well it was meant to be that you would stop and get it.
  19. Ok, a start on filling this thing up. First off, needed a way to hold the lid open. Trimmed a piece to length for along the back edge of the lid To keep the lid from going too far back. Glue and screws to install Sorry about the fuzzy photo. Seemed to work. Ok, lid will stay open, so I can get a little work done on the inside. Set up a corral for the four braces, and a drill bit holder A 1x1 screwed to the floor. A 1x upright to keep them upright. A diagonal brace to keep the divider upright. Whew. Had to keep working on the top of the divider to get it below where the trays will slide across. Yeah, a few handplanes showed up, wanting a place to hide. As for the bits for these braces And an eggbeater drill, too. I already had the 2x4 block made up. Was going to make a drawer like thingy for it. Screwed to the side of the chest. One last look at the crowded floor There is even a pair of rails installed for the next tray to slide on. Then, the battery on the Makita died. Bummer. Oh well, BREAK TIME! Need to plan a few trays anyway.
