Showing results for tags 'virtual symposium'.
Found 5 results
  1. First Wednesday in May! Where does the time go?!? Our Patriot Turners- A little slow this week. I think everyone is out mowing! A couple of "Blasts From The Past"! From our Ringmaster sub forum a chaos turning from @Headhunter More images are at the gallery- And from member @Big B (aka Brian Longshore)- This was posted at- What’s Coming Up- Click on the images for links to more information and registration. From the AAW- From Cindy Drozda- I hope to see you online at my Free Tool Talk Livestream! It's this Friday, May 9th, 2pm Eastern (18:00 UTC). For The Newbies- Tim Yoder answers another turning question. This one is about drilling on the lathe. And, here's a simple spindle turning project that also uses drilling on the lathe. Easy to make and then send home with your grandkids !! Expand Your Horizons- Tomislav Tomasic made a knockout bar handle. At the end of the video, he added a short segment on turning a sphere without a jig. Pretty cool. The "4 Ways" collaborators have posted their versions of a "Glasses Holder". These 4 projects are always really interesting to me. Love the way they interpret to the challenge in different ways. Turning Time With Easy Wood Tools- If you are in the Oklahoma, OK area, check out Jesse Horn's demo at the Woodcraft store! https://www.woodcraft.com/pages/store/oklahoma-city While you are there, take a look at the Easy Wood Hollowing tools. The EWT "Hollowers" come in three shapes- Straight (#1), 45 degree (#2) and 90 degree (#3). The Hollowers come in three different lengths, as well. The Mini Hollowers are about 15" long; the Mid Hollowers are about 22" long and both use the Ci5 standard or negative rake cutter. The Pro Hollers are about 32" long and use the Ci3 standard cutter or negative rake cutter. The #1 Hollower also works great for hogging out bowl interiors and making very small cove cuts. A short video from Craft Supplies USA demonstrating the use of the three hollowers- This short video from Easy Wood Tools, Doug Dixon, talks a little about the hollowers. Doug is one of the driving forces behind EWT and an expert in carbide cutter development. Doug Dixon from Easy Wood Tools sharing about their hollower. He is so knowledgeable and just fun to hang with #woodturning #turnerswarehouse.mp4 @Jordan Martindale New Turning Items- Not sure if this is a new tool. Picked it off of the Spring Vendors Showcase that was highlighted here a week or so ago. The cutting head and extendable handle look interesting. YouTube won't embed to video so click the link if you want to view the video of the hollowing tool. https://youtu.be/pKJVVo-vrKA?si=SJOyeYDEqGQM3XbO&t=6011 Everything Else- Safe turning
  2. Unbelievable, planted tomatoes last week supposed to be in the low 30's tonight! I hate this global warming! Our Patriot Turners- @Ron Altier brought us up-to-date on his epoxy finish for ornaments. Looks like he has pretty much perfected the process. Ron provides lots of tips on how he gets this mirror like finish- Several members posted in our "What's On Your Lathe" this past week. You can catchup with the new posts here- @forty_caliber added a couple and @teesquare added this beauty (and a couple of other pieces as well)- Do yourself a favor and check out all the new turning in the past week! What’s Coming Up- Click on the images for links to more information and registration For The Newbies- Thinking about turning that first bowl or maybe just need some more pointers? Kent Weakley's video could be what you are looking for. I thought this one was particularly helpful with the dialog and tips throughout the presentation. Richard Raffan puts his spin in the natural edge bowl project- Something to think about from Ron Brown's newsletter- This Is Just The Beginning It is easy to forget how much you have learned along the way. New turners also have to learn the same things we did. Or, if you are a new turner, there is much to learn. You can learn to sail in an hour – It takes a lifetime to become a sailor It is the same with learning about a wood lathe. Just like any other craft, getting the machine is only the beginning. Let’s start with the Four Pillars of Woodturning: #1-The Wood Lathe Itself There is a multitude of quality wood lathes available to fit most budgets. The most common starter lathe nowadays is a 12 to 12.5-inch swing lathe with a 1 hp variable speed motor. Many folks will keep this lathe when they upsize to a larger lathe with swings of 16 to 25” and motors up to 3 hp. #2-The turning chisels Beginning turners will see much faster results if they begin with carbide-tipped tools. A sharpening station is not required for carbide tools. High-Speed Steel tools require frequent re-sharpening and require a suitable sharpening station (more in #4) The turner must learn a whole new skill set for sharpening in addition to learning woodturning. #3-The means of holding your work Most lathes come with a spur drive center for the headstock and a live center for the tailstock. Great for beginning spindle projects like baseball bats, lamps, etc. Most lathes also come with a faceplate mainly used for turning bowls. I consider a 4-jaw scroll chuck a basic necessity. I recommend extra jaws also Pin jaws for very small spindle projects #3 or 100 mm jaws for larger spindle work and for many larger bowls. #4-A sharpening station Slow-speed grinders (1750 rpm or similar) with 8” grinding wheels made to work with High-Speed Steel are recommended A sharpening jig specially designed for sharpening lathe tools is virtually a necessity when using HSS lathe tools. Note: Using only carbide-tipped wood lathe tools eliminates the need for any kind of sharpening station and eliminates 25% of the learning curve and initial expense. Folks trying their hand at any new craft are much more likely to stick with it if they can experience early success. Easy projects to learn on are pens, small bowls, spinning tops, and small lidded boxes. Someone can successfully make all of them with simple carbide tools. Some folks only turn bowls while others only turn pens. As long at they turn something, I’m happy for them. Most folks who begin using carbide tools eventually add HSS tools and a sharpening station down the road. I recommend that route to see if they are going to enjoy turning wood and if they are going to stick with it long term. It seems like you never have every widget you want, but over time you can accumulate most of them. Remember that you can turn small items on a big lathe, but it is much harder to turn something big on a small lathe. So get ready to see that huge smile on that kid’s face from ages 8 to 88 when you show them how to make their first slimline pen or maple bowl. There is nothing like it! Expand Your Horizons- In last week's post, one of the "What's Coming Up" events were classes on turning kitchen utensils. The classes were at Highland Woodworking in Atlanta, GA. Not everyone can travel that far to learn to turn a spoon, so I found a bunch of videos, if you'd like to give it a try. If kitchen ware isn't your thing, Mike Peace demonstrates how to add an insert to a turned box New Turning Items- Sorry, couldn't find anything this week Everything Else- Started working on one of the elm rough blanks. I have enough meat on the bottom to remove some of the thickness around the mortice. It will make the thing set a little lower on a surface and lighten up the piece a bit. Safe turning
  3. Just a couple of days left in our summer fund raiser. Please consider getting those raffle tickets, if you haven't already done it. Our Patriot Turners- @Gerald posted a fantastic walnut platter he just finished- Check out more images and the comments from our turners- @PostalTom moved his chess piece post into our woodturning forum. He has a great start on a bunch of the pieces. He is getting ready to turn the "Knights" and was curious about the procedure. Maybe you can help him with some ideas. What’s Coming Up- https://www.woodturner.org/Woodturner/2022VirtualSymposium/2022-Virtual-Symposium---Main.aspx?_zs=ceDib&_zl=kVAC3 For The Newbies- A chuck, stuck on the headstock threads, can be a real problem. In this video, Mike Peace discusses some of the ways to remove it and how to prevent it. Cindy Drozda hosts live tool chats from time to time. You can sign up for notifications when they will be available. http://www.cindydrozda.com/html/Signup.html This is the video she posted from her last presentation- This video, from Kent Weakley, is on twice turning a bowl. What I found interesting is the type of chuck he used to hold the bowl to get it ready for mounting on his chuck. Expand Your Horizons- Last week we posted information on cleaning CBN grinder wheel. @Gerald pointed out there is some disagreement on whether or not this is necessary. Not having used CBN sharpening products, I was not aware of this difference in opinion. I searched the AAW boards for some more information and found this- https://www.aawforum.org/community/threads/cbn-wheel-cleaning.13014/ The discussion touches on several "cleaning" ideas as well as some other wheel care. Along the CBN lines, here's a video from Mike Waldt setting up a grinder with CBN wheels. Although the video is about a specific manufacturer, there are lots of great tips- From the AAW, a video on multi-axis spindle turning How does a true artist deals with the unexpected? Richard Raffan demonstrates- New Turning Items- Ken Rizza, from Woodturners Wonders, has a video demonstrating the Kodiak MAX sharpening system. Everything Else- The Richard Raffan video demonstrated how to work around the unexpected. Frank Howarth takes it to a whole other level. Rick Turns list of YouTube woodturning videos from last week- Safe turning
  4. OK, we are getting close to the end of our summer fund raiser and we are seriously short of our goal. If you haven't donated, please consider helping our site stay alive. Our very generous sponsors have donated some awesome items as prizes. Please head on over to this post and donate. Every little bit helps! Our Patriot Turners- @Gerald started catching up on some older projects and in the process did some cleaning- Part of Gerald's post was a challenge to our members to show us some of the unfinished projects we are procrastinating about completing! One of Gerald's projects to be finished up was a turned vase that cracked. Instead of the burn pit, Gerald used this as a chance to turn it into spectacular embellishments. In his post, he shows us his process- @RustyFN Finished up a gorgeous lidded box. Perfect glue-up and centered on the lathe. Made from two of my favorite woods. In his post, Rusty explains a little on how he mounted it on the lathe. What’s Coming Up- Click on the images for links to more information- For The Newbies- Another informative video in the series from Mike Peace- From the AAW, a video demonstrating a beautiful turning from shop scraps- Alan Stratton posted a video turning a bowl from start to finish. A couple of things of interest are his reason for not band sawing the blank round at the beginning and his thoughts on drying. Check out his faceplate jig for uneven surfaces! Expand Your Horizons- Watch Mike Waldt turn a beautiful, shallow mahogany bowl! Off-center and eccentric turning are similar but different. In this video, Carl Jacobson turns an eccentric goblet. Notice he does this without the aid of jigs. Cindy Drozda posted a short video demonstrating sphere turning- New Turning Items- From Craft Supplies USA, their new turning smocks- Everything Else- Rick Turns list of YouTube woodturning videos from last week- Safe turning
  5. We have started our annual site fund raiser. There are some fantastic prizes to be had for the lucky winners. If you like this site, consider donating to the operating costs! Also, don't forget this coming Sunday is Mother's Day. We can't forget our Moms. Our Patriot Turners- It has been a slow week here on the Woodturner's Forum, so we will jump ahead to What's Coming Up What’s Coming Up- Click on the above image for more information. Looking for some inspiration, ideas or conversations on turning? Check out the World Wide Turners web site. Lots of great turners there- https://worldwidewoodturners.org/ For The Newbies- Last week we posted a video from Record Power on lathe maintenance. Here is the second part- Highland Woodworking published a nicely illustrated article on using the fingernail gouge, by Temple Blackwood- The article can be read here- https://www.highlandwoodworking.com/woodturning/woodturning-with-a-small-fingernail-gouge.html?utm_source=ActiveCampaign&utm_medium=email&utm_content=Read+the+May+2021+Issue+of+Wood+News+Online&utm_campaign=May+2021+Wood+News&vgo_ee=SSZUGqILrYqLrMaaxASZAzpxdzkQNl9LgdxZ9pnzLRY%3D Expand Your Horizons- Jim Rodgers has a very nice series on turning miniature articles. This is Part 1 and the others are referenced on his YouTube channel- I've been making Celtic Knot rolling pins for a long time. Although the wood I use matches the pepper mills and salt cellars I make, I always wished there was a way to duplicate the knot in those items. Thanks to Alan Stratton, I think this might be the answer- Our sponsor, Laguna, linked this video on social media. Turning a coffee spoon. It incorporates multiple media and some cool jigs. New Turning Items- We mentioned these wooden threads before. Here's a short video, From Ron Brown, showing the steps to using them on a pet urn. Turner Carl Jacobson has quite a large following on social media. He recently posted a video answering questions about his favorite tools. The last tool he mentioned is a pneumatic sander. Here's the video- And the link to the sander he mentions- https://www.woodworkingshop.com/product/WK45950/ Also, check out his comments about that awesome Easy Wood Chuck The folks at Woodturners Wonders have a new product to help fill those cracks and splits in your turning. It can also be used for decorating and embellishments- Check it out at- https://woodturnerswonders.com/collections/featured-products/products/wonder-putty-two-part-sculpting-epoxy Everything Else- Rick Turns list of woodturning YouTube videos from last week- Safe Turning and stay well aaa
