Showing results for tags 'trent bosch'.
Found 9 results
  1. Our Patriot Turners- @Headhunter posted another fantastic bowl in our Ringmaster sub-forum. Tony is always coming up with spectacular ideas for his work and this one is at the top of the list! Check out his post for more information and images! An entry on our continuing post of "What's On". Seems this happens often when a turner says "just a skosh more" What's Coming Up- Cindy Drozda's Tool Talk from last Friday is available on YouTube- Also, Cindy is hosting a IRD on making a ginger jar. This is from her email. Saturday, October 25th, 1pm Eastern (17:00 UTC). Click on the image for the link to registration For The Newbies- Thinking about buying that first lathe or upgrading to a newer model? Tomislav Tomasic has some thoughts- Halloween Ornaments!!??!! Give these a try from Craft Supplies USA Expand Your Horizons- Are you considering selling your turnings? Craft shows, Etsy or other venues? Carl Jacobson and Ruth Niles have some things to think about https://nilesbottlestoppers.com/marketing-tips/ Alan Stratton creates a sphere, a box and a multi-axis pumpkin! Turning Time With Easy Wood Tools- Easy Wood Tools and Woodcraft are teaming up for some great prices and demos for this weekend! And, here's where you can find the EWT demonstrators next week! https://www.woodcraft.com/pages/store/tampa https://www.woodcraft.com/pages/store/tulsa https://www.hartvillehardware.com/middlefield-location https://www.woodcraft.com/pages/store/orlando https://www.woodcraft.com/pages/store/orlando https://www.woodcraft.com/pages/store/raleigh https://www.rockler.com/retail/stores/oh-cincinnati-store?utm_source=local&utm_medium=organic&utm_campaign=cincinnati https://www.woodcraft.com/pages/store/cincinnati https://www.woodcraft.com/pages/store/harrisburg-york https://www.woodcraft.com/pages/store/sacramento Tim Yoder turns a hybrid blank into a Sorcerer's Wand using Easy Wood Tools! @Jordan Martindale New Turning Items- San Angelo reviews the Peke Safety Powered Air Filtration System Everything Else- Safe turning
  2. Our Patriot Turners- A little bit more happening this week! Long time member @Steve Krumanaker is still making items for a local artisan. He showed us the wooden lids he turned for herb jars- Steve's lids include a metal lid inset. He tells us more about these and some of the other types he turns in this post- We also had an entries in the "What's On" and "What's Off" posts. A red oak medium sized bowl and a smaller bowl What's Coming Up- Cindy Drozda was at SWAT. Wonder if @Gerald talked with her? Cindy did a walk about and posted it on her YouTube channel- She also posted the video of of the bowl turning battle between Mike Mahoney and Stuart Batty- And, Cindy has a Tool Talk coming up this Friday. Click on the image for the link to registration. For The Newbies- An article, from Fine Woodworking, reviewing midi lathes. If a full size lathe isn't in your budget or you have a very small shop, this might be helpful. https://www.finewoodworking.com/2023/10/27/tool-test-midi-lathes-2 Tim Yoder shows us a less expensive way to sand some of those turning projects- Expand Your Horizons- Mike Peace dives into buffing. In this video, he demonstrates the use of the Beall Buffing System. I usually put Ron Brown's newsletter thoughts at the end of our Wednesday's post. Ron's thoughts, this time, really fit into expanding your horizons. Correct Proportions Help Make A Pleasing Shape The Golden Mean, also known as the golden ratio, golden section, or Fibonacci rule, is a principle of design that can be applied to wood turning to create objects with proportions that are considered aesthetically pleasing. The golden ratio is approximately 1.618. This ratio is found throughout nature, from the spirals of a seashell to the branching of trees. Artists and architects have used it for centuries to create a sense of balance and harmony. Applying the Golden Mean In wood turning, the golden mean can be used as a starting point to determine the proportions of various elements of a turned piece, such as: • Height to Diameter: For a vessel like a vase, the golden mean can guide the ratio of its height to its widest diameter. For example, if a vase is 10 inches tall, the golden ratio suggests its widest point should be approximately 6.18 inches (10 divided by 1.618) from either the top or the bottom. • Dividing the Space: The ratio can be used to divide the bowl's form into different sections. For instance, the ratio of the bowl's base diameter to its rim diameter could follow the Golden Ratio. This would create a pleasing visual progression from the bottom to the top. • Location of Features: The golden mean can also be used to position design elements on a turned piece. For a hollow form or vase, it can help determine where the widest point should be located to create a visually appealing curve. Similarly, on a wide-rimmed plate or bowl, it can guide the size of the central bowl in relation to the overall diameter of the piece. • Proportions of a Foot: The size of the foot or base of a bowl can be determined using the golden ratio in relation to the bowl's overall diameter. This helps create a stable and visually balanced foundation. • Proportions of a Finial: A finial is typically composed of several distinct segments, such as a base, a sphere or urn shape, and a tapering spire. The Golden Ratio can be used to determine the ideal proportion of these segments to each other. For example, a designer might ensure the ratio of the total length of the base section to the total length of the tapering section is approximately 1:1.618. This creates a natural-looking visual flow, preventing any one part from appearing too large or too small. Tools and Considerations Woodturners can use golden ratio calipers to apply this principle to their work easily. These calipers are designed to maintain the golden ratio as they expand and contract, allowing the turner to quickly check and adjust the proportions of their piece while it is on the lathe. Trent Bosch* offers high-quality Golden Mean Calipers HERE. Prices range from $40 to $175. While the golden mean is a powerful design tool, it is not a strict rule. Many turners find that using the golden ratio as a starting point or a general guideline helps them create pieces that feel "right" to the eye. It's important to remember that design is also about personal preference and artistic expression, and a piece can still be beautiful and well-proportioned without adhering strictly to the golden mean. Some artists prefer a more intuitive approach, relying on their "eye" and experience, which may lead to proportions that are very close to the golden ratio without any deliberate calculation. Trent Bosh also offers an excellent visualization with several examples for using the Golden Mean Calipers in this 8-minute Video.* There are several YouTube videos that show you how to make your own calipers if you prefer. Turning Time With Easy Wood Tools- Some great savings on those easy wood tools! https://www.thewoodturningstore.com/?srsltid=AfmBOorjI1m11YEv2ly3Mt17JasshNCyx_w_aMJ90hXPCw-n3_zvdwVW A couple of demos in early September- https://www.rockler.com/retail/stores/fl-altamonte-springs-store?utm_source=local&utm_medium=organic&utm_campaign=altamonte-springs https://www.rockler.com/retail/stores/az-phoenix-store?utm_source=local&utm_medium=organic&utm_campaign=phoenix From Nathan McCollim demonstrating how "Easy" it is to learn turning with Easy Wood Tools! AQMcZvOK77-bg2XUyRjjsDUvwMhM0RPXER-BLRMnv2rqtzSRtJYH0qiEObuzn1g9o0tbfzxDORcVk3Ishka-KiV7eMgD5_TG4X3MLWQ.mp4 @Jordan Martindale New Turning Items- Definitely not new but relates to Ron Brown's thoughts on pleasing proportions. https://trentboschtools.com/product/golden-mean-calipers/ Everything Else- Safe turning
  3. We only have about 2 weeks left to get your raffle tickets for the Summer Fund Raiser. This fund raiser will help keep our site alive and allow us to help veterans. Please Donate! Sorry about the late post. Our Patriot Turners- @Fred W. Hargis Jr Finished up his segmented coin displays and they are absolutely gorgeous! Check out more images and what our members had to say- Sad news in the world of woodturners this past week. @Gerald was kind enough to post his information about David Ellsworth. If you are not familiar with Mr. Ellsworth's art, here's a link to get you started https://ellsworthstudios.com/about-david What’s Coming Up- Click on the images for links to more information and registration For The Newbies- Thinking about selling your work at a craft show? Here's a fairly simple item from Tomislav Tomasic. Gets you started into simple bowl turning- Expand Your Horizons- Sam Angelo turns his version of a scoop using a shop made collet system Turning Time With Easy Wood Tools- Did you know Easy Wood Tools has a newsletter? To quote Joe Namath- It's FREE! Sign up here! Great prices on EAT products from Taylor Toolworks until the end of June. https://taytools.com/ @Jordan Martindale Carl Jacobson uses EWT equipment to create a beautiful lidded box. Checkout how easy it is to change jaws on the EWT chuck! New Turning Items- Sam Angelo reviews the Trent Bosch Laser Bar used for hollowing. Everything Else- Safe turning
  4. Cold and windy here. Expecting a coating of snow tomorrow. Our Patriot Turners- @Fred W. Hargis Jr is prepping the load of wood he picked up a while back. He is sealing the ends of the blanks to slow down the drying process. Fred received some tips, from our members, on sealing materials. Check out his post at- @Gordon posed a question about using coloring agents to finish off a bowl. Specifically, he is looking for input on using dyes. Several of our members have provided some guidance. If you have experience, please add your comments to Gordon's post- A couple of entries and comments on our post for "What's ON/OFF" the lathe From what's ON- From @Gerald New comments start here- And from What's OFF- @RustyFN's awesome bowl. Check out the grain patterns! New entries start here- What’s Coming Up- Click on the images for links to more information and registration- Any one up for a road trip?? For The Newbies- You've started to turn bowls. The outside looks pretty good but you are not happy with the roughness/ridges on the inside. Tomislav Tomasic demonstrates techniques to help improve the surface. Expand Your Horizons- Is there a use for a 3-D printer for the woodturner? Mike Peace investigates. A few weeks ago we posted a source for the new bowl coring system from the Woodcut company. Craft Supplies USA created an in-depth video from unboxing through use. New Turning Items- From Trent Bosch, a new design in tool rests. Asymmetrical Tool Rests. Click the image for link to the site. From Ron Brown, a video demonstrating the new "Bowl From A Board Extended Reach Base"- Everything Else- The new Craft Supplies USA catalog is available online at- https://indd.adobe.com/view/773366dd-1e4a-437f-92f0-c98e00d316ab I may have to buy an iPad to be able to peruse the pages while relaxing in the "Reading Room" Safe turning
  5. Been one of those computer days from He$$ Our Patriot Turners- @AndrewB converted some logs into turning stock the old fashioned way- hammer and wedge!!! A lot of work! New member @DeVere posted some images of the musical instruments he builds. These are some fantastic items!! Please check these out and give him some feedback. @windward woodturning added additional information to his post on deep pour epoxy. Great observations and reviews of several brands- Our turners are keeping the "ON/OFF" posts alive with gorgeous pieces! From ON- @RustyFN and @kreisdorph both posted More images and details start here- And from OFF- @DeVere posted some of his beautiful pieces- Check out more of his turnings here- What’s Coming Up- Click on the images for links to registration and more information. For The Newbies- Scroll chucks are not the only way to hold a turning. Kent Weakley shows us how versatile the Jam Chuck can be- Sam Angelo explains how to mill a bowl blank from half a log- Expand Your Horizons- The Woodworker's Journal published this month's edition of Woodturning Monthly Some neat turning ideas. The entire newsletter is at: https://www.woodworkersjournal.com/woodturning-monthly/?utm_medium=email New Turning Items- Not exactly a new item but Sam Angelo discusses some of the features of the Trent Bosch Laser Bar. Everything Else- The smaller cherry bowl came out of the drying box today. Larger sycamore still needs a couple of days. Maybe I'll finally be able to get back to the lathe!! Safe turning
  6. March already! Some of the trees are starting to show signs of waking up and I have garlic greens showing through the mulch! Our Patriot Turners- @Fred W. Hargis Jr posted an inquiry about a new tool rest. He asked particularly about the curved type used for turning bowls. Several of our members offered their opinions. Maybe you could hop on over to Fred's post and provide additional insights. @HandyDan posted a link to a site for turning tool handle inserts. If you make your own handles you might want to check it out. The site is for Trent Bosch tools and there are lots of other items there. Here's the link to his site's home page- https://trentboschtools.com/ @Gerald showed us the setup for his new JaHo jig in the "Good Monday Morning" forum- There is additional information in his post- Our continuing thread on the "What's On Your Lathe" post continues to showcase new and beautiful items. This past week @teesquare, @kreisdorph and @Gerald all posted projects! Catchup on all the activity at- In addition to the ones still on the lathe, We had entries into the "What's OFF Your Lathe And Finished". @Gerald and @kreisdorph both added their finished items. The new entries and comments start here- What’s Coming Up- Click on the image for the link to more information and registration- For The Newbies- Not quite ready to make the deep bowl? here's an intermediate step from Alan Stratton. Reading a post on social media from a turner who upgraded to a larger lathe. He was lamenting that his expensive Cole Jaws were small and would not allow him to use the maximum swing of the new lathe. One person recommended this video from Alan Stratton- Expand Your Horizons- Several of our turners give back to others by participating in events such as Turning Pens For Our Troops and Beads Of Courage Boxes. This month the turners participating in the "4-Ways" turning collaboration are making Wig Stands. Anyone who has suffered the ravages of cancer and chemo would certainly appreciate one of these items. New Turning Items- Many turners tint their epoxy/acrylic work with various products. Up until now, tinting CA glue was limited due to the reaction between the glue and the tinting substance. Starbond has released an assortment of materials to tint their CA glues. Check it out at- https://starbond.com/collections/powders-inlay-supplies?utm_source=1. Starbond Newsletter Subscribers&utm_medium=email&utm_campaign=SB - TOTD Mica Mix (01HR9F16QNEP00ZFQF4704JB87)&_kx=UWBjOrBvGqdgxjbKJKjzdYtukO2Hko9tBjUvyv5yRmCPEYlA8GzGmWiEh-BS_64B.KAnW2a Wasn't sure where to put this but Woodturners Wonders is having a give-a-way contest- If you do that sort of things, here's the link- https://woodturnerswonders.com/pages/giveaway?_kx=gV5SF2As_3IwtBi5TrpHVQM0F3UvGVbQKzhWGippDlk.VJvU8R Everything Else- From Ron Brown's Newsletter When Size Matters What is the second major difference between a 12” swing wood lathe and a 16” swing wood lathe? The first difference is obvious, the 16” lathe can swing a 4-inch larger vessel. The second major difference is in the motor or horsepower. The smaller lathe is most likely equipped with a ¾ or 1 horsepower motor while the larger lathe will typically have 1-1/2 to 2 horsepower motor. Why does horsepower matter anyway? When all you turn are pens, wizard wands, and bottle stoppers, HP doesn’t matter. But when you are roughing out bowl blanks, plates, platters, drilling salt and pepper mills, or virtually any hollow form, the extra HP keeps the lathe from stalling. The larger the diameter, the more HP is needed because you lose the advantage of leverage. Imagine going up a steep hill with a heavy load in high gear. With the smaller HP you are forced to take lighter cuts and can’t be aggressive without stalling the lathe in its tracks; been there done that. You can turn little stuff on a big lathe, but it is much more difficult to turn big stuff on a little lathe. It can be done, of course, it’s just not as fun, safe, or easy. I have discovered recurring patterns after observing many thousands of turners over a few decades: 1) Most new turners start with a mini-lathe if they buy it new. 2) If they inherit the lathe from a relative or purchase it used, they are likely to get a larger machine to start with. 3) Although they planned to sell the smaller unit when they upgraded, they most often kept both lathes. I had 5 at one time. Now I’m down to only two. 4) These days, 2020 and later, most new turners start with carbide-tipped tools rather than the High-Speed Steel traditional tools. They are easy to use, quick to become proficient with, and they don’t require frequent sharpening or an expensive sharpening station. 5) After the new turner decides to pursue turning as a hobby, (1 to 3 years later) most will undertake learning how to use and sharpen HSS tools. They will invest in a fully equipped sharpening station including a slow speed grinder and sharpening jig. A no-fail way to introduce someone to turning wood on a lathe is to help them turn a wooden pen using a carbide-tipped tool. They treasure that pen and use it every day. They can spend the minimum amount of money and easily make lots of pens to give away or sell to their friends and associates. Their sense of accomplishment is validated often and they will have firmly joined the family of wood turners. Just like everything else in life, we all have to start somewhere. Me too. If you recognize the path each of them must walk on their journey, you will be better able to help and advise other turners who are not as experienced as you are. Experts were once beginners too. That is why we are always ready to help whenever we can and invite folks to call with their turning questions. Where are you on the path? Safe turning
  7. Middle of February and it was 70° today in South Central PA! Our Patriot Turners- @Thad posted an image of a garden tool he turned. These are really handy for anyone planting both garden veggies and flower bulbs- Check out the comments at Thad's post- Last week, @RustyFN told us about the turned boxes he had made. Check out more about the one he entered into his club's contest and the awards presented- Also, a great big thanks to Rusty for starting a great new thread called "What's On Your Lathe"! Hope we can keep this going!! Our turners are already starting to post their stuff- @HandyDan used some of the Easy Wood Tools carbide cutters to top off a couple of turning tools he made. Dan's post describes the construction and why he chose round bar stock @jthornton continue work on his dizzy bowl. He has posted lots of progress shots along with explanations of what he is doing. This is going to be an awesome bowl! What’s Coming Up- Click on the images for links and more information- For The Newbies- Richard Raffan continues with his video series to help the new turner and us old turners that need some reminders Expand Your Horizons- Looking for something different to turn? Check out the latest from Mike Peace- Having just the right device to hold a turning makes life a lot simpler. Look what Alan Stratton has created- New Turning Items- Several things on hollowing. Two from Trent Bosch Some more from the Woodturning Tool Store on the Woodcut Tools Pro Forme Flexi Just got word today that Easy Wood Tools is about to release a new product! Hopefully @Jordan Martindale will keep us in the loop! Everything Else- Rick Turns list of YouTube woodturning videos from last week- and from Ron Brown- If You Never Try, You Will Never Know Have you been turning for 5, 10, 20 years, or longer? You are just beginning to understand the fascinating craft of woodturning. This might make more sense if I used the analogy of someone who had one year’s experience twenty times. Think of it like this, a baker who only makes one kind of bread over and over might be pretty good at making that one kind of bread but most folks wouldn’t consider him much of a baker. While someone who makes several different kinds of delicious bread, bagels, cakes, pies, and muffins would be considered a thoroughly accomplished baker. I’m not suggesting you give up making what you love, only that you add other types of projects into the mix. That is how you keep our craft alive, interesting, and growing. Or, just consider adding embellishments this time such as pyrography, carving, texturing, or painting. Besides, the skills you learn by turning something different often carry over and make you even better at turning what you love. I’ve met scores of folks who make mostly bowls who ventured out with spinning tops, bottle stoppers, pepper mills, pens, and hollow forms and discovered a completely new passion. I would like to suggest you try a few different kinds of projects this year. You might just be surprised at what you learn. If you are mainly a bowl-turner, try some spindle projects. If you are mainly a spindle turner, try some plates, platters, bowls, and hollow forms. I can tell you from experience that it takes making more than a few to understand your new project. I’ve made somewhere over 10,000 spinning tops and it took a few hundred before I started to “Get It.” Fancy delicate finials were the same way. I’ve made hundreds for Christmas ornaments, turned lidded boxes, and lidded hollow forms. Looking back at the first ones, they now seem clunky and disproportionate but they were fun and educational, well worth my time and effort. Besides, having an arsenal of quick easy projects that you are good at is a great way to demonstrate turning to the public, or to introduce someone new to woodturning as a fascinating hobby or side business for a little extra income. Always be on the lookout to show someone how fun a wood lathe can be. Keep it simple and they will understand. Remember that wherever you go, there you are. Safe turning
  8. Frantic week here, unfortunately absolutely no time at the lathe. Our Patriot Turners- @RustyFN rough turned a bunch of bowls- In his post he tells us about the type of wood and shows us some of the blanks- Rusty also finished a beautiful mahogany bowl Check out the nice comments by our turners- Last week, @forty_caliber picked up some really nice bowl blanks. He created some awesome pieces from them Check out more from his continued post- What’s Coming Up- Lots happening in the near future. Click on the images for links to more information and registration. For The Newbies- This is copied and pasted from Ron Brown's latest newsletter. Good advice for new turners when selecting tools. Should You Use A Butter Knife For Everything? Why not? Because there are times when a butter knife just won’t cut it. Sometimes you need a butcher knife to cut up chicken, steak, or a pork roast. You might need to peel a potato or an apple or cut up ingredients for a chunky salad. It is the same thing with lathe tools. Sometimes you need to slice, other times you need to scrape, and sometimes you just need to make a lot of material go away. When I first began to learn about turning, my turning buddies thought the key to turning like the professionals was having their tool with their grind. So, I bought a new tool with every new demonstration I watched. Turns out, it isn’t the tool! I began to analyze High-Speed Steel lathe tools and it didn’t take long to realize that there are only 6 basic categories for HSS tools; 7 if you include tools for hollowing. There are many different sizes within each category and many different grinds within each category. I even developed a helpful chart so you can better visualize each one. I’ve made it available as an Instant Free Download here: We call it “Turner’s Reference Guide.” You will have to be registered, also free, and logged into your account. I recommend you print this out and post it in your shop. My recommendation is to acquire a limited number of HSS tools in each category and add different sizes and grinds as you need them. Simply having 100 HSS turning tools doesn’t make you a better turner. This I found out the hard way. Here's the link to register for Mr. Brown's newsletter. Once registered, you can download the reference guide mentioned above. "It's Free"!! https://www.ronbrownsbest.com/index.php?route=account/register Want to expand your creativity? A video from the AAW on turning a mushroom- Turned beads are a great way to add interest to almost any turning. In this video, Mike Peace demonstrates some of the tools for turning beads- Turning a bowl from a log can be done several ways and it's always good to see the method used by other turners. Here Kent Weakley demonstrates his style- And, Richard Raffan's method- Expand Your Horizons- Need to turn a thin spindle? Jim Echter shows how it's done. Awesome skew work!! Always fun to watch Mike Waldt create a new item. This is part 1 of an elderberry vase. Yet another scoop version from Alan Stratton- I happened upon this on a social media site. We are always looking for food safe methods of finishing turnings. This may, or may not, be an effective but it sure is interesting. This is a copy and paste from Debbie Coull's Instagram post ( https://www.instagram.com/p/Cj3BgYgjbrC/?igshid=MDJmNzVkMjY%3D ) so all can read it. "Sealing a food safe vessel with hot milk. No idea of the exact process as I struggled to get anything online for doing this with wood. Lots about how to do it with earthenware. So, since this is an ancient technique, I figured, keep it simple. Sycamore cereal bowl (hopefully), turned and sanded to 320. Exterior sealed with wax, interior left naked (I know the wax exterior will wash off after it's been in use and washed). Milk was heated till I burned the tip of my finger, then poured in till it lipped the rim. Now leaving it to cool. The process requires the casein protein in the milk penetrating and sealing the wood grain. I know there will be several folk comment about the milk going rancid, but I'm trusting the process. If it didn't work, then it wouldn't have been practiced for centuries." New Turning Items- Woodturners Wonders has expanded their product line to include CA adhesives. You can check out their complete selection at- https://woodturnerswonders.com/collections/adhesives Everything Else- Rick Turns list of YouTube woodturning videos from last week- Safe turning
  9. It works. But this guy has taken the idea of controlled hollowing to another level and he's not using any electronics He uses a pattern that he makes from the turning and follows that with this cool set up
