Showing results for tags 'chair post'.
From the album: Shaker Furniture
Soon after I had the blank in the lathe, my son walked in and I put him to work on roughing out the blank, he did a pretty nice job for his first time and Easy Wood Tools really helped in his learning curve.-
- easy wood tools
- cherry
- (and 5 more)
I sanded the post to 220, I did not get too carried away with the sanding on the rear posts, since it's going into the steamer, the grain will raise anyway. After I took the post to 220 I marked a couple lines where the rear and side rung holes must be drilled, and where the back slats will have to be mortised in by hand.- 2 comments
This is my story stick for my layouts. I used the line I drew at the lathe, then intersected that line with the lines on my story stick to layout the rung holes.-
- chair post
- layout
(and 5 more)
