Showing results for tags 'wind shake'.
Found 4 results
  1. Cruising through April! Our Patriot Turners- @Gordon posted a question about wood identification. Specifically, he scored some really nice pieces but was uncertain about the species. Check out his post and see what our turners thought. If you have a better guess, I'm sure Gordon would love the input! @calabrese55 posted a great little jig in our Turner's Tips Sub-Forum. This neat little device can really help you dial in the correct size for chuck tenons or mortices. Head on over to the sub-forum and see more images and how it works. @RustyFN got a good start on another "basket weave" vase. These turnings sure do take a steady hand and awesome eyesight! See Rusty's post for additional images and more progress @Fred W. Hargis Jr gave us a look at his segmented ring, coin holder progress and details about how it is coming along. Fred posted images of his progress and details of how he accomplished the turning As his turning is nearing completion, Fred wondered if there is a way to burn an embellishing ring on the surface circumference of the turning. Our members offered suggestions as to what worked for them. If you have a technique that works for you, please give Fred a shout. From The Patriot's CNC Forum, @4DThinker posted his work on creating a turning tool handle. It turned out really nice! More images and the completed handle are shown in his post- What’s Coming Up- Click on the images for links to more information and registration. If you missed the live Spring Vendors Showcase, you can watch the replay. Cindy Drozda's Live Tool Talk- For The Newbies- Not every piece of wood is safe to turn. In this video, Tim Yoder describes a defect called "wind shake" and why you should be aware of the dangers. Sharpening your HSS tools takes practice. In this video, Mike Waldt demonstrates methods of making repeatable sharpening grinds. Richard Raffan explains the importance of knowing the difference between a bowl gouge and a spindle gouge. Personal safety could be compromised and tool damage can occur if used improperly. Expand Your Horizons- Neat idea, from Sam Angelo, on chucking a turned box without the use of a tenon. Turning Time With Easy Wood Tools- The Easy Wood Tools "finisher" is an all around turning tool. It can be used to remove material during spindle turning, create coves/beads and even smooth out the tool marks left by other tools. The finisher is available in every category of the Easy Wood line. Depending on the size of the finisher, the carbide cutter may be different. As with all Easy Wood Tools, the cutter identification is etched into the shaft of the tool so you will always know the correct cutter for that tool. Using the finisher is straight forward. The tool is held horizontal and the cutter contacts the turning at the horizontal center line of the work. The depth of the cut should not exceed 1/3 the diameter of the cutter to avoid vibration thus creating rough surfaces. The finisher demonstrated by Craft Supplies USA- Free demonstrations from The EWT calendar https://www.rockler.com/retail/stores/ok-oklahoma-city-store https://www.rockler.com/retail/stores/ga-sandy-springs-store?utm_source=local&utm_medium=organic&utm_campaign=sandy-springs @Jordan Martindale New Turning Items- A new face shield/respirator reviewed by Mike Peace. The link to the manufacturer- https://microclimate.com/ Sorta reminds me of the helmets used by the NASA crews. Everything Else- Safe turning
  2. If you haven't gotten that Valentines present, maybe you should dig out a pillow and a couple of blankets for the couch! Our Patriot Turners- @RustyFN posted a beautiful walnut bowl in our continuing thread "OFF The Lathe And Just Finished"- Rusty has another image and a little about the finish in his post. Rusty also posted that he is looking to purchase a McNaughton Center Saver. Check out his post here- @StaticLV2 is tinkering with segmented turning. He created a really nice cutting jig for the angles. The results are gorgeous! You can see the jig and his process images starting in this post- We have a new member to our forum! @kreisdorph, from Tennessee, posted some of his awesome work. You really need to check out his post to see more of his turnings- One of our members, Brian Longshore, "Big B", is battling the dreaded "C". He's a Navy vet. Here's the link to his Patriot profile- https://thepatriotwoodworker.com/profile/4825-big-b/ If you do Facebook, you can follow his progress at- https://www.facebook.com/brian.longshore.9. What’s Coming Up- Click on the image for the link to registration- From Cindy Drozda- For The Newbies- From Richard Raffan, a tip on making/using a "tail center disc" Last week we posted a safety tip when using the Jacob's Chuck with the tail stock. Lyle Jamieson has an idea that secures the chuck in the tail stock- Expand Your Horizons- Richard Raffan continues to work on his stash of green elm. The warping really creates interesting designs. New Turning Items- Sorry couldn't find anything interesting. Everything Else- I had gotten some cherry a while back only to discover most of it had "windshake" damage. One of the pieces destined to be a bowl became pretty much fodder for the garbage man. I salvaged one small piece for a little bowl only to have it explode while sanding. So as not to have the efforts be a total loss, I cut what was left to see the profile and how I was doing with wall thickness consistency. I was using only my fingers as a gauge, except for the bottom, where I use a gauge/jig from Sam Angelo to determine the thickness. I'm pretty happy. The wall thickness could have been a little better at the transition from side to bottom. And maybe a little thinner overall. Safe turning
  3. This month is quickly coming to an end! Our Patriot Turners- @Gerald posted a beautiful bowl he finished. This one has some gorgeous embellishments on the bottom and the rim. Gerald received lots of positive comments on this one! Please keep Gerald and his family in your prayers. He had a knee replacement done recently. @calabrese55 is working on a staved bowl. He built a really nice steady rest to do part of the turning. This was posted in our "What's On Your Lathe" continuing thread- Check his comments about the wheels he used and see more images! We've had an additional post in the "What's Off Lathe And Just Finished" What’s Coming Up- This is the video of the recent Tool Talk from Cindy Drozda, in case you missed it live. She demonstrates Hook and Cygnet mini hollowers. Cindy and Todd Raines will be hosting free Q&A session. Click on the image for the link. From the Keystone Woodturners via their Facebook page. Click the image for the link to more information. For The Newbies- Some things about making turning more safe. Over the years, I've heard and read about something called "shake" or "wind shake". However, I had never had a piece of wood that displayed the characteristic split. Recently, the tree man called and said they were taking down a cherry tree and was saving me a couple of pieces. As I was making blanks from the logs, one of them plainly showed the results of wind shake. The beginning of this video, from Tim Yoder, address the potential dangers of turning wood affected by this and other types of defects. This short video illustrates why it is a good idea to grasp the Jacob's Chuck when using it for drilling, on the lathe. I usually hold it when advancing the quill. Now I'll hold it for movement in both directions. Expand Your Horizons- Some weeks back we posted a video, from Carl Jacobson/Niles Bottle Stoppers, demonstrating the use of the Joyner Offset Jig. Mike Peace decided too build a similar device to do offset embellishments. Alan Stratton is still making goblets. These are done in three pieces. New Turning Items- Woodturners Wonders continues with their weekly sales. https://woodturnerswonders.com/collections/weekly-sale?_kx=gV5SF2As_3IwtBi5TrpHVQM0F3UvGVbQKzhWGippDlk%3D.VJvU8R Everything Else- Safe turning
  4. Summer's about over and the days are getting shorter. Less yard work means more lathe time! Our Patriot Turners- @nevinc has really put his lathe to work this week. He showed us a bunch of bowls, with different design! He describes what he has done in this post- Nevin also worked on a box elder bowl with a unique shape- He provides us with more information in his post- @forty_caliber also has been busy with more of his pecan stash! he posted a couple of bowls for us to drool over- There's more images and descriptions at- Forty then had a chance to finish up the bowl on which he used epoxy and diopside inlay- More images and specifics can be found in this post- @Gerald added a video of a neat little toy on which he has been experimenting. He calls them "Tippy Tops". Check this post to see what they do! Another addition to our continuing thread- "Off The Lathe And Just Finished" What’s Coming Up- Click on the images for more information and registration- For The Newbies- A few video short from Tim Yoder and Ron Brown Both Tim and Ron have been producing these short videos to help the newer turner understand some of the nuances of turning. You can check out their series at https://www.youtube.com/@woodturningwithtimyoder/featured and https://www.youtube.com/channel/UCMD5dw_8FCyaHPjztP5sklw I think everyone knows how I hate to sand, mainly because I never get the results I see from other turners. Cindy Drozda recently did a live Tool Talk showing her sanding techniques. I learned a lot. Expand Your Horizons- @Gerald's post on Tippy Tops coincided with this video from Alan Stratton. Alan revisited these in hopes of having better success. Check out Alan's process from turning spheres freehand. Kent Weakley turns a wooden bowl but not without some difficulty. He explains what happened and how to correct it. Mike Peace shared a video of an IRD he recently conducted. The video is rather long but the demonstration of the threading jig/device is interesting. Not all tree logs are suitable for turning bowls or larger pieces. Richard Raffan explains the phenomena of "wind shake" or "cup shakes". New Turning Items- Not new but some better prices- https://lylejamieson.com/ Free shipping continued until September 25. https://woodturnerswonders.com/ Everything Else- Woodworker's Journal published their Woodturning Monthly newsletter. https://www.woodworkersjournal.com/woodturning-monthly/?utm_medium=email Safe turning
