October 11, 201610 yr comment_78369 @PostalTom, it's quite alright. You all see things we don't. Let me clarify, in order to see the definition of an acronym, just hover your cursor over any text with double underlines. The acronym definition will appear. Give it a try at the acronyms in this topic. EDIT: Or better yet here you go. HVAC BF SCMS DF OEF OIF Just to name a few. Report
October 11, 201610 yr comment_78421 Got it. Thanks John. Now that you point that out, I think I actually saw that, but didn't realize what I was looking at. Senior moment, I guess. Those are happening all too frequently. Thanks again. Report
October 13, 201610 yr comment_78684 On 10/11/2016 at 5:39 AM, PostalTom said: Got it. Thanks John. Now that you point that out, I think I actually saw that, but didn't realize what I was looking at. Senior moment, I guess. Those are happening all too frequently. Thanks again. No problem at all Tom, never hesitate to bring up anything around here, it's how we grow! Thanks Report
October 13, 201610 yr comment_78685 On 10/11/2016 at 7:02 AM, Chips N Dust said: John, do we have OG (Old Growth) in the data base? It is now Kelly. Report
October 17, 201610 yr Author comment_79476 HO = Home Owner... OP = Original Poster... OC = On Center.. CT = Counter Top... CDX = grade of utility plywood Report
October 17, 201610 yr comment_79487 2 hours ago, Stick486 said: OP = Original Poster... OC = On Center.. CDX = grade of utility plywood Legit! I'll get those up, thanks Stick! Report
October 19, 201610 yr comment_79859 1 hour ago, Stick486 said: OSB = Oriented Strand Board... Yep! Report
November 1, 201610 yr Author comment_81981 Stickineeze = say much/few words.... Edited November 1, 201610 yr by Stick486 Report
November 1, 201610 yr comment_81987 19 minutes ago, Stick486 said: Stickineeze = say muck/few words.... it may just stick,Stick! Report
November 10, 201610 yr Author comment_83557 ID = Inside Diameter.. OD = Outside Diameter... CL = Center Line... Report
November 10, 201610 yr comment_83559 Just updated a few, scroll up to your past suggestions and you'll see some dashed lines under the suggested acronyms. Thanks for your input @Stick486 Report
November 10, 201610 yr Author comment_83585 1 hour ago, John Morris said: Just updated a few, scroll up to your past suggestions and you'll see some dashed lines under the suggested acronyms. Thanks for your input @Stick486 better definition??? ID = Inside Diameter/Dimension.. OD = Outside Diameter/Dimension... Report
