Acronym Expansion (On Going)
4 hours ago, Fred W. Hargis Jr said:
Growing up, it seemed like all our neighbors worked for FoMoCo. My friends (their kids) always insisted it meant First On Race Day. This was in the 60's, so we really didn't know who was first on race day for several weeks after the race. Al hadn't invented the internet yet.
I've heard it as "First Out Race Day" ;)
I'm an AMC/Chrysler retiree, so I've heard plenty of them. :lol:
  • Replies 173
  • Views 16.6k
Factory Ordered Road Disaster
Flipped Out Random Destruction
On ‎10‎/‎6‎/‎2018 at 9:21 AM, John Morris said:
My Ford is on my driveway, with a dead steering wheel. It can only go forward and backward. Up the driveway and down the driveway.
John,
Can you Magilla Gorilla the steering at all?
If not check the linkage on top of the steering column.
IIRC the linkage works both the ignition switch, and the steering column lock plate.
2 minutes ago, Larry Buskirk said:
John,
No it won't budge Larry, it's stuck soft like, not a hard stuck like the steering wheel is locked, but a soft stuck, I can turn the wheel either way about an inch, that's it. The tires don't move at all.
@John Morris
Good thing you weren't driving it when it locked up.
Herb
Edited by Dadio
  • 2 weeks later...
BU... Bevel Up..
BD... Bevel Down
  • 2 weeks later...
@John Morris
ERC = EASTERN Red Cedar
WRC = WESTERN Red Cedar
But if everyone uses the word instead of whatever then there is no mistaking what the poster might be trying to say saying. A few seconds more to type a post the correct way. I often try sign language but some of you are beyond that!
Thank You!
When I start to read a post filled with seemingly unrelated capital letters, I move on to the next. I don't have the time or inclination to lookup or hover over an entry to try and figure out what the poster is trying to say.
57 minutes ago, Smallpatch said:
But if
it's continuing education... surly you haven't a problem w/ CE...
This is a list of standard lumber abbreviations that are commonly encountered in the buying and selling of lumber in the United States. (and there are other lists)
AAR  Association of American Railroads
AD  air dried
ADF  after deducting freight
AF  alpine fir
a.l.  all lengths
ALS  American Lumber Standard
AST  antistain treated; at ship tackle (western softwoods)
AV or avg  average
a.w. all widths
AW&L  all widths and lengths
B1S  see EB1S, CB1S, and E&CB1S
B2S  see EB2S, CB2S, and F&CB2S
B&B  B and Better
B&BTR  B and Better
B&S  beams and stringers
BD  board
BD FT  board feet
BDL  bundle
BEV  bevel or beveled
BH  boxed heart
B/L, BL  bill of lading
BM, b.m.  board measure
BSND  bright sapwood no defect
BTR  better
CB  center beaded
CB1  Scenter bead on one side
CB2  Scenter bead on two sides
CC  cubical content
cft or cu. ft.  cubic foot or feet
CF  cost and freight
CIF  cost, insurance, and freight
CIFE  cost, insurance, freight, and exchange
CG2E  center groove on two edges
C/L  carload
CLG  ceiling
CLR  clear
CM  center matched
Com  common
CONST  construction
CS  calking seam
CSG  casing
CV  center V
CV1S  center V on one side
CV2S  center V on two sides
DB Clg  double beaded ceiling (E&CB1S)
DB Partdouble beaded partition (E&CB2S)
DET  double end trimmed
DF  Douglas-fir
DF-L  Douglas fir, larch
DIM  dimension
DKG  decking
D/S, DS, D/Sdg  drop siding
D1S, D2Ssee S1S and S2S
D&M  dressed and matched
D&CM  dressed and center matched
D&SM  dressed and standard matched
D2S&CM  dressed two sides and center matched
D2S&SM  dressed two sides and standard matched
D4S  dressed four sides
E edge
EB1S  edge bead one side
EB2S, SB2S  edge bead on two sides
ED  equivalent defects
EE  eased edges
EG  edge (vertical or rift) grain
EM  end matched
EV1S, SV1S  edge V one side
EV2S, SV2S  edge V two sides
E&CB1S  edge and center bead one side
E&CB2S, B2S, BC&2S  edge and center bead two sides
ECM  ends center-matched
E&CV1S, DV1S, V&CV1S  edge and center V one side
E&CV2S, DV2S, V&CV2S  edge and center V two sides
ES  Engelmann spruce
FA  facial area
Fac  factory
FAS  free alongside (vessel)
FAS  Firsts and Seconds
FAS1F  Firsts and Seconds one face
FBM, Ft. BM  eet board measure
FG  flat or slash grain
FJ  finger joint (end-jointed lumber)
FLG, Flg  flooring
FOB  free on board (named point)
FOHC  free of heart center
FOK  free of knots
FRT, Frt  freight
FT, ft  foot or feet
FT. SM  feet surface measure
FURN  furniture stock
G or GR  green
G girth
GM  grade marked
G/R, GR  grooved roofing
HB, H. B.  hollow back
hdwd.  hardwood
HEM  hemlock
H-F  hem-fir
Hrt  heart
H&M  hit and miss
H or M  hit or miss
IC  incense cedar
IN, in.  inch or inches
Ind  industrial
IWPI  daho white pine
J&P  joists and planks
JTD  jointed
KD  kiln dried
L  western larch
LBR, Lbr  lumber
LCLless than carload
LGR  longer
LGTH  length
Lft, Lf, lin. ft.  lineal foot or feet
LIN, Lin  lineal
LL  longleaf
LNG, Lng  lining
LP  lodgepole pine
LR  log run
M  thousand
MBM, MBF, M.BM  thousand (feet) board measure
MC, M.C.  moisture content
MCO  mill culls out
MERCH, Merch  merchantable
MG  medium grain or mixed grain
MH  mountain hemlock
MLDG, Mldg  moulding
Mft  thousand feet
M-S  mixed species
MSR  machine stress rated
m.w.  mixed widths
N  nosed
NBM  net board measure
No.  number
N1E or N2  Enosed one or two edges
Ord  order
P  planed
PAD  partially air dry
PART, Part  partition
PAT, Pat  pattern
Pcs.  pieces
PE  plain end
PET  precision end trimmed
PP  ponderosa pine
P&T  posts and timbers
P1S, P2S  see S1S and S2S
Qtd.  quartered
RDM  random
REG, Reg  regular
Rfg.  roofing
RGH, Rgh  rough
R/L, RL  random lengths
R/W, RW  random widths
RES  resawn
SB1S  single bead one side
SDG, Sdg  siding
S-DRY  surfaced dry (19 percent moisture content or less)
SE  square edge
SEL, Sel  select or select grade
SE&S  square edge and sound
Sftwd.  softwood
SG  slash or flat grain
S-GRN  surfaced green (in excess of 19 percent moisture content)
SGSSND  Sapwood, gum spots and streaks, no defect
SIT. SPR  Sitka spruce
S/L, SL, S/Lap  shiplap
SM  surface measure
Specs  specifications
SP  sugar pine
SQsquare
SQRSsquares
SR  stress rated
STD, Std  standard
Std. Igths.  standard lengths
STD. M  standard matched
SS  Sitka spruce
SSND  sap stain no defect (stained)
STK  stock
STPG  stepping
STR, STRUCT  structural
SYP  southern pine
S&E  side and edge (surfaced on)
S1E  surfaced one edge
S2E  surfaced two edges
S1S  surfaced one side
S2S  surfaced two sides
S4S  surfaced four sides
S1S&CM  surfaced one side and center matched
S2S&CM  surfaced two sides and center matched
S4S&CS  surfaced four sides and calking seam
S1S1E  surfaced one side, one edge
S1S2E  surfaced one side, two edges
S2S1E  surfaced two sides, one edge
S2S&SL  surfaced two sides and shiplapped
S2S&SM  surfaced two sides and standard matched
TBR  timber
T&G  tongued and grooved
UTIL  utility
VG  vertical (edge) grain
V1S  see EV1S, CV1S, and E&CV1S
V2S  see EV2S, CV2S, and E&CV2S
WC  western cedar
WCH  West Coast hemlock
WCW  West Coast woods
WDR, wdr  wider
WF  white fir
WHAD  worm holes a defect
WHND  worm holes no defect
WT  weight
WTH  width
WRC  western redcedar
WW  white woods (Engelmann spruce, true firs, hemlocks, pines)
YP  yellow pine
just in case I missed some...
Common Lumber Abbreviations:
BFBoard feet (1 BF = 1"x 12"x 12")
BEVBeveled
BNBull-nosed
BTRBetter
LFLineal feet (per foot)
ComCommon
CLRClear
CVCenter V
DIMDimension
EEdge
FJFinger Jointed
FTFoot (or Feet)
G1SGood One Side
G2SGood Two Sides
GRGreen
INInch
KDKiln Dried
No.Number
NHNo Hole
PETPrecision End Trimmed
RGHRough
RDMRandom
RLRandom lengths
RWRandom widths
RLWRandom lengths and widths
S1SSurfaced one side
S2SSurfaced two sides
S4SSurfaced four sides
S1S2ESurfaced one side & two edges
SESquare Edge
S-GRMore than 19% water by weight (More likely to warp if not installed quickly)
S-DRLess than 19% water by weight (Less likely to warp)
STDStandard
SQSquare
SLShiplap
T&GTounge & Grooved
VGVertical Grain
Species:
CDR   Cedar
DF   Douglas Fir
DF-LDouglas Fir, Larch
GDFGreen Douglas Fir
HEM   Hemlock, Fir
LP   Lodgepole Pine
RW   Redwood
SPF   Spruce-Pine-Fir
SYP   Southern Yellow Pine
WC   Western Cedar
WRC   Western Red Cedar
WF   White Fir
YP   Yellow Pine
Grades:
#1BTR#1 & Better
#2BTR#2 & Better
#3BTR#3 & Better
B&BB & Better
CON COMConstruction Common Redwood
CON HEARTConstruction Heart Redwood
STD BTRStandard & Better
Common Terms:
Checks: Gaps or separations along the length of a wood member, crossing the annual rings. Caused by rapid shrinkage or uneven seasoning of the wood.
Shake: Shakes are gaps parallel to the annual rings. Unlike checks, shakes occur before the felling of the timber. Caused by uneven stresses along the trunk.
Pitch: Pockets of tree sap. As the lumber cures, the pitch pockets empty or harden leaving an imperfection in the wood.
Knots: Knots occur at the intersection of trunks and branches. Wood grading limits the presence and location of knots in the lumber.
How about BS............. That is what I think of it all.
Herb
Herb
You think about a Bandsaw?;)
7 hours ago, lew said:
Thank You!
you want TPW to give up it's individuality and be more ''like'' FB/Twitter...
now this...
now this...
Not at all. I'm just not impressed by posters using too many acronyms in a veiled attempt to astound me with their supposed knowledge.
As far as the "Like" emoticon goes, I never implied that the Patriot should get rid of it- quite the opposite-
"Seriously, Cliff, I see truth in what you say. To me, the emoticons do provide some feedback to the author by acknowledging that I have at least read their post. Sometimes, I really don't have anything to add, that hasn't already been said, or am not knowledgeable enough to comment, so the "Like" option make sense to me."
my apologies...
BION=Believe It Or Not
Sorry I don't agree or like these Acronyms, too much like government orders or military orders.
Axcept for one Go HF !!!!!
Herb
Ditto!
