Acronym Expansion (On Going)
Man, regional differences in nomenclature can be striking. Morris and I are not that far apart but D2S..etc is totally foreign to me. Around here it's S2S, "Surfaced 2 Sides." Or, S2S 1SE..."Surfaced 2 Sides 1 Straight Edge"....etc.
John, I'm wondering if your use of the D2S... etc is common in your profession or, do you see it at your local lumber yard?
Those kinds of differences are one good reason to have an acronym dictionary.
  • Replies 173
  • Views 16.6k
YMMV...your mileage may vary. Usually seen after an explanation of a procedure.
Gene, we don't use those designations in my region either, we use S2S etc. I just pulled those up because they were in the link that Lew provided. I figured those were mid-west or east coast designations, that are also valuable to have here.
Must be East coast...Midwest is S2S, S4S, etc.
same here...
same here in the PNW
DW = Drywall....
AWI = American Woodworking Institute...
Working on the expansion now Stick. Should have a quite a few plugged in tonight.
MDO = Medium Density Overlay...
MDF = Medium Density Fiberboard...
DC = dust collector
CMS = mitre saw
DP = drill press
TS = table saw
Are these there already?
On 9/13/2016 at 0:50 PM, Stick486 said:
PIP = Picture In Post
PIP is project in progress
HVAC = Heating Ventilation Air Conditioning...
Acronyms updated, if you see double dashed lines under the acronym, then it's been accepted into the data base. Give the site a half hour to cache and catch up with the updates.
  • 2 weeks later...
VOI = Voice Of Inexperience...
Edited by Stick486
AHJ = Authority Having Jurisdiction...
On 9/12/2016 at 3:25 PM, Chips N Dust said:
Roll On the Floor Laughing My A#! Off
How about SNAFU? That is a technical term.
Done, thanks Chips.
On 9/12/2016 at 9:48 AM, Gene Howe said:
SCMS... sliding compound miter saw
M&T...mortise and tenon
BB...Baltic Birch, usually referring to plywood
Done, thanks Gene
On 9/12/2016 at 9:04 AM, lew said:
One of the things I hated most when moving my professional focus from electronics to computers was having to learn a new, extensive (and sometimes silly) list of acronyms. Sometimes I think woodworkers take this even farther. Example-
"Tried the BS to make DT but needed the ROS to trim the WP material. Needed to cleanup the WB of spilled BLO"
Why do we need to write in "code" and we're not sending text messages or Tweets!
Here's how ridiculous it has become (and this is just one list)- http://www.hobbithouseinc.com/personal/woodpics/_acronyms.htm
Until reviewing that list Lew, I have heard you guys say BORG often around here, and I thought it was an actual retailer called BORG in your neck of the woods, come to find out it's an actual acronym!
On ‎9‎/‎14‎/‎2016 at 6:36 AM, John Morris said:
for the most part they are purely technical for our users who are just starting out, or the passerby who may not be familiar with our industry.
On ‎9‎/‎14‎/‎2016 at 6:28 AM, John Morris said:
the acronyms have to be hand entered into our database of acronyms along with the definition, and unfortunately that area is not accessible to our highly valued members.
John, I realize I am coming late to the discussion, and not to be argumentative, but what good is a dictionary of acronyms to "users just starting out, or the passerby who may not be familiar with our industry", if they cannot access the dictionary?   This is good for the administrators, but for those of us "out in the cold", so to speak, we still have to ask someone to define an unfamiliar acronym.
