Showing results for tags 'walnut bowl'.
From the album: Steve Krumanaker
Walnut bowl with an ogee profile with a fillet, about 10" diamter and 1/4" thick.- 1 comment
- walnut bowl
- turning
(and 4 more)
I've still got several of the natural edge walnut bowls to finish. Took this one in the house today. It's about 12" diameter and 6" deep. I burned one of my favorite zentangle patterns on the bottom, "phicops in a circle". Steve Steve
- 16 replies
- walnut
- walnut bowl
(and 5 more)
Yea, it stands for what you think it does. When I finish a bowl on the lathe I first finish the bottom and then hold the bowl with a vacuum chuck to finish the rest of it. I've been wanting to try the technique with brush on lacquer and I guess I was thinking about that and not much else. This bowl has one coat of shellac for sealer on it. I started it spinning and applied the shellac, then went in the house for a bit. When I go back out to the shop, the bowl is laying on the floor with several pieces of bark broken off. Luckily I keep a messy shop and there was a bed of shavings or it probably would've been worse. I have several lights over my lathe which are plugged into a switchable plug strip. I normally plug my vacuum pump into a separate outlet but not thinking I plugged it into the one I use for the lights. I ALWAYS turn my lights off when I leave the shop. Amazingly I was able to get the pieces glued back on and it's hard to tell they were even broken. Thank goodness for super glue. Steve
- 4 replies
- natural edge
- natural bowl
(and 5 more)
Said he had some "goodies" for me. All cherry with some really nice crotch pieces. Just when I thought I was done roughing bowls for awhile Always a conundrum when I get cherry, do I make bowls or brisket? He left with a nice walnut natural edge bowl and some beers but I think I got the best deal! Steve
- 42 replies
I really, really hope this one behaves while it's drying.
Steve Krumanaker posted a topic in Wood Turners
I say that just about every time but this one could be special I think. About 19" diameter and five inches deep. Spectacular grain and markings in it as well. There's going to be a bit of sanding and I'll probably let it dry for a couple months but if it turns out I'm going to call it "ET" Steve- 15 replies
- bowl
- walnut bowl
(and 5 more)
There was a lot more sap wood in this bowl than I expected. Still, the bark stayed on well and it warped nicely without cracking. The sapwood also makes a nice contrast I think. The bottom side. Steve
- 17 replies
- walnut
- walnut bowl
(and 6 more)
This is the first finished(almost) bowl from the walnut I harvested a couple months ago. Turned natural edge, it's about 11X14" and about 4" deep. Pretty happy with it except for a couple tool marks I just didn't get sanded out. I'll gift this one to my Sis for Christmas as it's from the tree that was in her yard. It's about 3/8" thick throughout and will get a few more coats of antique oil. I just have to say, I really like the picture posting procedure on this forum. Steve
- 9 replies
- walnut
- walnut bowl
(and 5 more)
