Showing results for tags 'turned boxes'.
Beautiful day in south central Pennsylvania... Our Patriot Turners- @Fred W. Hargis Jr Started a new turning and a new challenge for him- Fred had several questions about the best way to mount the piece on the lathe and some procedural turning questions. Our gang wasn't shy about offering their ideas and included some images of what they have done. Check out all of the interactions here- There were a couple of new comments on Fred's post about the lidded box he had turned. You can see the comments and images at- @kreisdorph scored some freshly cut oak. He turned this lovely bowl as a gift for the person who gave him the wood. Always a great thing to repay a gift and this lets the tree live on. What’s Coming Up- Click on the image for the link to registration and more information- For The Newbies- Sometime turners will uses different terms to describe the same thing or vice-versa. Here's Mike Peace's take on the Natural Edge Bowl and the Live Edge Bowl- And here he shows us his techniques for turning a live edge, or is a natural edge, bowl??? And from Lyle Jamieson, a tip on creating a strong glue block connection for bowl turning. Expand Your Horizons- Richard Raffan shows his method of sanding the inside of his turned boxes. Nice tip! Tired of turning bowls? Looking for another form that will be well received as a gift? Try turning a platter- New Turning Items- New style bronze threaded rings from Niles Bottle Stoppers Everything Else- Ron Brown's newsletter included a free sharing of his published list of woodturning "Pearls of Wisdom" and a free download of the Turners Reference Guide. Ron Brown’s Pearls: Turners Reference Guide© brought to you by Ron Brown’s Best, LLC 1. There are exceptions to every rule except this one. 2. Six types of chisels are needed to make up a basic turning set (Spindle Gouges, Roughing Gouges, Bowl Gouges, Skews, Scrapers & Parting Tools). 3. Sharp Lathe Tools are more fun. 4. Speed formula: diameter in inches X speed in RPM should equal 6,000 to 9,000 (10” X 800 RPM= 8,000). 5. Rub the bevel on all cutting tools; not on scraping tools. ABC= Anchor the tool, Rub the Bevel, Pick up the Cut. 6. Have safety gear on hand and use it; full face shield, dust mask. 7. Always rotate the workpiece by hand before turning the lathe on to check for interference. 8. Start at slow RPM to check for balance, and then speed up. 9. Speed can be our friend. 10. If you are afraid, slow down and take a breath. 11. “Life’s too short to turn ugly wood.” John Jordan. 12. Carpe Lignum, Torne Lignum – Seize the wood. Turn the wood. 13. Variable-speed lathes are better. 14. Learn to hone. 15. Have a plan before you start. 16. Be Flexible. 17. Turn green wood often. 18. Greenwood is like lettuce, cut what you can use or it will spoil. 19. Learn to use your tools well and keep them sharp. 20. Sharp tools are safer. 21. Sharp tools produce better results. 22. Invest in a good sharpening system and learn to use it well. 23. Then teach others. 24. Don’t skip grits. Never jump more than 50%, i.e. 100 grit to 150 grit to 220 grit to 320 grit. 25. Your family will love whatever you make. 26. Listen to your spouse; they usually have a better eye for design. 27. Never point out your mistakes to others. 28. Spindle turning often requires more skill and imagination than bowl turning. 29. “Never scrape when you can cut.” Mike Mahoney. 30. If you must scrape, raise a fresh burr. 31. Get and learn to use a ¼” wide parting tool. 32. Learn to make lots of “Fun Stuff” like tops, pens, stoppers, light pulls and small lidded boxes. It will make you a better turner and your family will think you are a genius, especially at Christmas time. 33. Make Christmas gifts for your family every year and start in June. 34. Invest in education like classes, seminars and symposiums. 35. Spend the money for personal one-on-one instruction with a professional turner. 36. If you are not failing every now and then, you are not learning. 37. You learn the most when you teach others. 38. Buy good quality M2 High-Speed Steel tools. Avoid high-carbon tools; they are a waste of time. 39. Learn to turn right and left-handed. 40. You can use a bowl gouge on spindle work, but usually not the other way around. 41. Sandpaper is cheap; throw it away often and use fresh stuff. 42. Sign and date your workpieces along with the kind of wood. 43. Buy the best chuck you can afford, and then buy lots of jaws for it. Then buy another chuck. 44. Make your own tool handles. 45. Try someone else’s tools. They might know something you don’t. 46. Join an AAW chapter then go to the meetings. 47. Read turning magazines. 48. Watch turning videos on YouTube, but don’t believe everything they tell you. 49. Buy educational DVD’s. https://longworthchuck.com/index.php?route=product/product&path=10&product_id=219 Turners_Reference_Guide.pdf Safe turning
- 3 replies
- richard rodgers
- sanding stick
- (and 20 more)
Tomorrow is the 80th anniversary of D-Day. There are so few of the brave men and women who served in World War II left to honor their sacrifices to keep our country free. The Greatest Generation is almost gone. Our Patriot Turners- @StaticLV2 posed a question to our members concerning turning if you are a "Lefty". Specifically, dealing with hollowing out the bowl's inside. If you van help him, please see his post and provide some input- @Masonsailor has been building doors for a while. Paul got a chance to sneak over to his lathe to turn several of these door related items. Check out his post for the details! @Fred W. Hargis Jr posted his turned box for use to drool over. First partially finished and then completely finished- More information and descriptions at- And @Gerald finished up his work on an urn for his daughter-in-law's father. It is a beautifully done piece and a fitting resting place for a loved one. Gerald's post includes some process images and description of what he has done- A week or so ago, @RustyFN showed us some turned lidded boxes he made from boxwood. Rusty's friend does chip carving and he embellished the two boxes with amazing work- Check out Rusty's post to see the complete series of pictures from start to finish- Once again, our turners have come through with an amazing collection of work for our "ON/OFF" the lathe posts! Thank You!!! From "ON"- @Gerald and @calabrese55 worked on hollow vessels- Lots of great comments. Pick up where we left off last week at- And from "OFF"- @StaticLV2 and @kreisdorph created some amazing work segments and bowls- Here's the link to catchup with all the action- What’s Coming Up- https://www.neowta.com/press/kirk-deheer-demonstration-and-classes/ For The Newbies- Popular Woodworking made available several turning articles. https://www.popularwoodworking.com/projects/turn-your-first-bowl/?oly_enc_id=7454G3912223B7R https://www.popularwoodworking.com/tools/carbide-tools-unlocking-woodturning-potential/?oly_enc_id=7454G3912223B7R https://www.popularwoodworking.com/tools/the-woodturning-scraper/?oly_enc_id=7454G3912223B7R Expand Your Horizons- Craft Supplies USA has a nice tutorial for turning a utility box- It is just after the first of the month and the "4 Ways" collaboration videos were posted. This project was a little different as each turner made their own favorite project. Mike Peace- Richard Raffan- Sam Angelo- And Tomislav Tomasic- New Turning Items- Not new but I use this bandsaw blade for resawing inserts for my rolling pins. Thought maybe some of the other turners here may do similar cutting- https://www.highlandwoodworking.com/wood-slicer-resaw-bandsaw-blades.aspx?utm_source=Advertiser+Promotion&utm_content=FW+Dedicated+Offers&utm_medium=Advertiser+Promotion Also, last week we posted a new jig from Ron Brown's Best. @HandyDan noticed that one of Ron Brown's jigs was a hollowing stabilizer. Dan said he was unfamiliar with the tool. This is a simple design and has limited depth capabilities compared to the ones used by Tim Yoder or Lyle Jamieson Everything Else- Safe turning
- 5 replies
- highland woodworking
- 4 ways
- (and 20 more)
Spent the day rototilling our little garden and planted onions. Garlic has sprung up and looks like most of what I planted survived the winter. Harvest won't be until mid summer. Our Patriot Turners- @Gerald is turning some really neat refrigerator magnets! He has been practicing with his new JaHo jig to adding very interesting embellishments to some of these items. Please hop on over to his post and see what our turners thought of his work- Gerald also posted about these magnets in the "Monday Morning" forum We've had some additions to several of our continuing posts. From "What Lathe Are You Using"- @RustyFN, @HARO50 and @Steve Krumanaker From "Off The Lathe"- @kreisdorph- From "What's On Your Lathe"- @calabrese55- And, from "What's Your Favorite Wood..." @RustyFN, @keithlong and @Cal @keithlong is looking for a specific crafting item. He is making keychains and needs to find a part. Please check out his post and see if you can suggest a source for the part he needs- Keith also added to @Fred W. Hargis Jr's post about Easy Wood Tools rougher cutters. Looks like he found a pretty good price on cutters- What’s Coming Up- Click on the images for links to more information and registration- For The Newbies- Turners are always seeking new ways to amp up the visual effects of their turnings. In this video, Sam Angelo uses various tools to create interest on the turning's surface. He also adds some color to highlight the embellishments. Expand Your Horizons- Several of our members make "Beads of Courage" boxes for kids with cancer. Mike Peace recently did a short video spotlighting the Gwinnett Woodworkers as they prepare segmented blanks for their Beads of Courage Box initiative. A really worthwhile cause. Alan Stratton shared a video where he turned a bird's beak natural edge bowl. What I found interesting was his method of holding the turning when reversed chucking. New Turning Items- Not new but on sale from Woodturners Wonders- https://woodturnerswonders.com/collections/lathes?_kx=gV5SF2As_3IwtBi5TrpHVQGZ2p91Dzyb6Hq8u86HRP26F2J3AVp8xSSqd_hTF8cT.VJvU8R Everything Else- From Ron Brown's Newsletter, struck home with me as this was the way I was raised: I Can’t Because I Don’t . . . When someone says I can’t because I don’t have something I will need to do it, the money, the accessory, or just about anything else, I wonder how anything ever gets done. I grew up in a working-class poor family. We always had food, although a lot of the time it was because we had our own chickens, rabbits, and pigs. We were taught not to waste. I learned very early that you can almost always find a way if you want to make something happen. When we wanted to go fishing, we first dug the worms, caught the grasshoppers, or made our own doughballs. Bamboo fishing poles with a cork float and one old hook worked fine. We had hours of fun and usually came home with a basket of fish. Catch and release, what is that? You already have a lathe and a few tools, add wood from the firewood pile and you are in business! You can make anything if you want to. Use what you have on hand, until you get something better. Figure out how to use what you already have in new and creative ways. Lots of things will do double duty nicely. No matter how much stuff you have, you will always want something better. (I usually have the solution just so you know). My point is when you think you can’t because you need something else, the adventure has usually just begun, if you get creative and figure out how to accomplish the task by using something else in an unconventional way. Don’t spend your precious shop time being frustrated because of what you don’t have. Do something while you save up for the miracle tool, jig, or fixture that will make all the difference. I’ll be here when you are ready. How do I know this works? I learned how to write because I have never been able to pay someone else to write for me. I know how to publish mass emails because a publicist charges way more than I can afford. I know how to edit photos, drawings, and videos for the same reason; I can’t afford to pay someone else to do it for me. I know how to program all of my CNCs, my lasers, and my 3D printers myself because I’ve had to learn to do it if it is going to get done. I know how to upload my edited videos to YouTube, Facebook, and Instagram along with shorts and reels because I made myself learn to do it. My point is don’t be so eager to accept defeat. Use your God given talents to figure it out. You will surprise yourself when you make a second and third effort. One of the greatest forces in the world is persistence. I've been playing with shapes and proportions. None are finished, a couple need hollowed. This is some of that wind shake cherry. Safe turning
- 6 replies
- beads of courage
- paint
(and 30 more)
- beads of courage
- paint
- embellishments
- sam angelo
- burls turning
- lyle jamieson
- turned boxes
- scott hampton
- ewt cutters
- parts
- key ring
- question
- favorite wood
- vase
- bowls
- whats on
- whats off
- what lathe
- jaho
- magnets
- refrigerator
- woodturners
- wisdom
- wednesday
- mike peace
- gwinnett woodworkers
- alan stratton
- birds beak
- woodturners wonders
- ron brown newsletter
- shapes
- proportions
