Showing results for tags 'cole jaws'.
Finally solved an issue trying to prevent chafing / marring a finished bowl mounted in my Cole jaws. Starting with an ordinary kids toy, a pool noodle simply cut a slice off the noodle about 1/2 in thick and place the donuts over the rubber inserts on the Cole jaws. The bowl point of contact normally against the metal Cole jaws now nicely rests on the foam donuts. They pretty much will work with any of the Cole inserts for ID or OD workpiece gripping. Best of all they stay in place so there is no fussing around to get them to stay put or having to take the chuck off the spindle and place on a bench to keep the cushion material in place till you can load the workpiece against it . The pictures tell the whole story. calabrese55
March already! Some of the trees are starting to show signs of waking up and I have garlic greens showing through the mulch! Our Patriot Turners- @Fred W. Hargis Jr posted an inquiry about a new tool rest. He asked particularly about the curved type used for turning bowls. Several of our members offered their opinions. Maybe you could hop on over to Fred's post and provide additional insights. @HandyDan posted a link to a site for turning tool handle inserts. If you make your own handles you might want to check it out. The site is for Trent Bosch tools and there are lots of other items there. Here's the link to his site's home page- https://trentboschtools.com/ @Gerald showed us the setup for his new JaHo jig in the "Good Monday Morning" forum- There is additional information in his post- Our continuing thread on the "What's On Your Lathe" post continues to showcase new and beautiful items. This past week @teesquare, @kreisdorph and @Gerald all posted projects! Catchup on all the activity at- In addition to the ones still on the lathe, We had entries into the "What's OFF Your Lathe And Finished". @Gerald and @kreisdorph both added their finished items. The new entries and comments start here- What’s Coming Up- Click on the image for the link to more information and registration- For The Newbies- Not quite ready to make the deep bowl? here's an intermediate step from Alan Stratton. Reading a post on social media from a turner who upgraded to a larger lathe. He was lamenting that his expensive Cole Jaws were small and would not allow him to use the maximum swing of the new lathe. One person recommended this video from Alan Stratton- Expand Your Horizons- Several of our turners give back to others by participating in events such as Turning Pens For Our Troops and Beads Of Courage Boxes. This month the turners participating in the "4-Ways" turning collaboration are making Wig Stands. Anyone who has suffered the ravages of cancer and chemo would certainly appreciate one of these items. New Turning Items- Many turners tint their epoxy/acrylic work with various products. Up until now, tinting CA glue was limited due to the reaction between the glue and the tinting substance. Starbond has released an assortment of materials to tint their CA glues. Check it out at- https://starbond.com/collections/powders-inlay-supplies?utm_source=1. Starbond Newsletter Subscribers&utm_medium=email&utm_campaign=SB - TOTD Mica Mix (01HR9F16QNEP00ZFQF4704JB87)&_kx=UWBjOrBvGqdgxjbKJKjzdYtukO2Hko9tBjUvyv5yRmCPEYlA8GzGmWiEh-BS_64B.KAnW2a Wasn't sure where to put this but Woodturners Wonders is having a give-a-way contest- If you do that sort of things, here's the link- https://woodturnerswonders.com/pages/giveaway?_kx=gV5SF2As_3IwtBi5TrpHVQM0F3UvGVbQKzhWGippDlk.VJvU8R Everything Else- From Ron Brown's Newsletter When Size Matters What is the second major difference between a 12” swing wood lathe and a 16” swing wood lathe? The first difference is obvious, the 16” lathe can swing a 4-inch larger vessel. The second major difference is in the motor or horsepower. The smaller lathe is most likely equipped with a ¾ or 1 horsepower motor while the larger lathe will typically have 1-1/2 to 2 horsepower motor. Why does horsepower matter anyway? When all you turn are pens, wizard wands, and bottle stoppers, HP doesn’t matter. But when you are roughing out bowl blanks, plates, platters, drilling salt and pepper mills, or virtually any hollow form, the extra HP keeps the lathe from stalling. The larger the diameter, the more HP is needed because you lose the advantage of leverage. Imagine going up a steep hill with a heavy load in high gear. With the smaller HP you are forced to take lighter cuts and can’t be aggressive without stalling the lathe in its tracks; been there done that. You can turn little stuff on a big lathe, but it is much more difficult to turn big stuff on a little lathe. It can be done, of course, it’s just not as fun, safe, or easy. I have discovered recurring patterns after observing many thousands of turners over a few decades: 1) Most new turners start with a mini-lathe if they buy it new. 2) If they inherit the lathe from a relative or purchase it used, they are likely to get a larger machine to start with. 3) Although they planned to sell the smaller unit when they upgraded, they most often kept both lathes. I had 5 at one time. Now I’m down to only two. 4) These days, 2020 and later, most new turners start with carbide-tipped tools rather than the High-Speed Steel traditional tools. They are easy to use, quick to become proficient with, and they don’t require frequent sharpening or an expensive sharpening station. 5) After the new turner decides to pursue turning as a hobby, (1 to 3 years later) most will undertake learning how to use and sharpen HSS tools. They will invest in a fully equipped sharpening station including a slow speed grinder and sharpening jig. A no-fail way to introduce someone to turning wood on a lathe is to help them turn a wooden pen using a carbide-tipped tool. They treasure that pen and use it every day. They can spend the minimum amount of money and easily make lots of pens to give away or sell to their friends and associates. Their sense of accomplishment is validated often and they will have firmly joined the family of wood turners. Just like everything else in life, we all have to start somewhere. Me too. If you recognize the path each of them must walk on their journey, you will be better able to help and advise other turners who are not as experienced as you are. Experts were once beginners too. That is why we are always ready to help whenever we can and invite folks to call with their turning questions. Where are you on the path? Safe turning
- 4 replies
- tinting
- starbond
(and 27 more)
- tinting
- starbond
- wig stand
- mike peace
- tomislav tomasic
- richard raffan
- sam angelo
- 4 ways
- cole jaws
- tray
- alan stratton
- carving stand
- todd raines
- minature
- natural edge
- vase
- hollow
- bowls
- jaho jig
- inserts
- trent bosch
- tool rest
- question
- wednesday
- wisdom
- woodturners
- woodturners wonders
- give-a-way
- ron brown
Hope everyone had an enjoyable July 4th. Our Patriot Turners- @knockonit posted a question to turners about turning Indian Rosewood. He has received a few responses so far- If you have experience with this species, please hop on over to his post and give him your suggestions. @RustyFN gave us a look at his hollowing rig he is using in conjunction with his shop made steady rest. Really looking forward to seeing this in action. Check out the addition to Rusty's previous post- @Masonsailor turned a few more of those baseball displays for his Mrs. Paul's post has more images- What’s Coming Up- As a reminder, Cindy Drozda's 4 part, online turning class starts this Saturday July 9. More information at her website- http://www.cindydrozda.com/html/Demo.html Cindy is also hosting a "Tool Talk" on Thursday July 7. These are live streaming interactive discussions. If you do Facebook, checkout this link- https://www.facebook.com/1124046309/posts/pfbid0ZHVS9EBVaYc2vTFwaKiAraUEvgrHRGyGNHStARhvxYNwhZ3TbHzZ65qxMZi4tG2Rl/?d=n&mibextid=HcvaIG Cindy usually streams this live on YouTube as well. This is the link to her channel- https://www.youtube.com/user/cindydrozda/featured or here- https://youtu.be/-UpYnwfIEgA For The Newbies- Mike Peace continues to post short, informative turning tips and instructional videos. This one compares a chuck worm screw to a screw chuck. If you have a set of Cole jaws for your chuck, you may find this video useful- Expand Your Horizons- Offset turning can be exciting. Here Alan Stratton turns a one piece wooden scoop- Mike Waldt demonstrates turning a hollow form- An interesting process that uses more than just turning to create an awesome looking bowl- New Turning Items- Woodturners Wonders has a preorder sale on the complete Kodiak sharpening system- https://woodturnerswonders.com/products/kodiak-max-woodturners-complete-sharpening-system-pre-order-expected-7-15?utm_content=Facebook_UA&utm_source=facebook&variant=42576925851815&fbclid=IwAR3y-Ljoo49jKC2oyp_e_ftGdoCgg2HiKZKdcnxBM68SEMflaWDbN4lqRbY While you are at the site, checkout their line of sanding supplies/equipment. Ken Rizza discusses some the products in this video- Everything Else- Rick Turns list of YouTube woodturning videos from last week- Finally got done with the refinishing of some old kitchen ware turnings. These were made back in 2007 and had been used hard in Mimi's kitchen. The pepper grinder set a little too close to the stove and the heat discolored the wood. All of the surfaces had accumulated cooking oils/grease from daily use. Sanding and fresh applications of gloss ploy, The platter is the one that got way too thin at the center mounting mortice. Did all the sanding/finishing and then filled the mortice with Alumilite mixed with black opaque coloring. Safe turning
Posting this a day early as family commitments will keep me tied up for a while. Our Patriot Turners- Not sure how I missed this post from @Gerald but hope he can forgive me for the oversight. Gerald is still using up some of that pecan wood he got a couple of years ago- In this post he explains a little about his plans for the piece- @forty_caliber was commissioned to turn a bowl from a specific species. He got a good start on it and gave us a glimpse- Forty gave us an insight into how it turned, in this post- @bradleyheathhays posed a question to our forum- actually several question. He is looking for information on various chucks, a coring system, sanding supplies and wood storage. Our members offered several ideas/suggestions. Please see his post and offer any input that would be helpful- What’s Coming Up- More information at- https://awgbvirtual.co.uk/ For The Newbies- A fun little project for using scraps or small branches Some projects can benefit for specialized holder. A short video demonstrating the use of a mandrel- A little more advanced project for the kitchen from Alan Stratton- Expand Your Horizons- A couple of videos with demonstrations by well known turners- Mike Waldt- Robert Sorby- Those of you that do casting, a sweet little box from Carl Jacobson. At the end of the video Mr. Jacobson gives his opinion on a brand of sandpaper. Want a 2 color bowl but you don't do segments? Check this out! New Turning Items- In the above video, Mr. Jacobson offered his opinion on the sandpaper he used. This video shows the testing process on a wide selection of sandpaper/manufacturers- The write-up for the video- https://kmtools.com/blogs/news/the-great-sandpaper-showdown-top-3-sandpapers-for-woodworking-in-2021 Ruth Niles' November newsletter is out. She has a couple of kits More information here- https://nilesbottlestoppers.com/product/unique-blank-kit/# Everything Else- Rick Turns list of YouTube woodturning videos from last week- Been asked to turn some bowls from a walnut tree that had to be taken down. The tree had special meaning to the owners. The pieces supplied had been left outside and were splitting pretty bad but I was able to get some small blanks. Two bowls are rough turned and soaking in soap/water. The third is hopefully destined to become a natural edge bowl. Walnut doesn't hold on to its bark really well and the bark is quite thick. I was hoping this could go from start to finish but that's not going to happen. Shaped the outside and applied CA the cambium area around the piece Hoping to keep the bark in place, I used my Dremel tool and created a circular opening through the bark, into the sap wood. Then loaded the "moat" with CA to soak into the wood. I'll keep this in a plastic bag until I get back to it. It may just be a miserable failure. Time will tell. Safe turning and stay well
