Popular Post lew Posted September 12, 2019 Popular Post Report Posted September 12, 2019 (edited) Remember- Our Patriot Turners- @Gerald is trying out some new coloring techniques. His turning/coloring really creates some interesting designs in the wood! Please head on over to Geralds post and let him know how much you like this piece- Gerald also showed us a round hollow form that his coloring really made the grain of the wood stand out! Gerald explains what he did in his post @HandyDan gave us a really nice set of pictures on how he made his baby rattles- Check out his post to see what all went into making these beauties! @Gene Howe gave us a heads up on a video that should be mandatory viewing for every person who operates a lathe. Thanks Gene. What’s Coming Up- If you are near Provo, Utah, Craft Supplies USA is offering several turning workshops- Click on the above image for the link to more information and registration. Also- Again, clicking on the above image will connect you to more information and registration to this event. For The Newbies- When you start to turn bowls, you generally have two options for obtaining wood. Buy the mostly dried blank or find a freshly cut tree. In either case, unless you turn the bowl from start to finish in one sitting, drying the wood between turnings may be necessary. Rick Turns found a cool and inexpensive way to slow the drying process and reduce the chance of checking and cracking- Expand Your Horizons- Everyone knows I'm a "jig junky". Here's a video showing a shop made jig to use for turning Twisted Boxes. New Turning Items- Last week we displayed a basket weave illusion bowl from @Billy B. If you were interested in trying your hand at this awesome technique, Chef Ware Kits has what you need to get started- Find more on the lits and prices at- https://chefwarekits.com/Basket-Weave-Kits-c9880431 The folks at Woodturners Wonders have a new device to hold your dust collection hose. It is flexible and adjustable! Find out more about it at- https://woodturnerswonders.com/collections/lathe-track/products/trac-vac-flexible-dust-collector Everything Else- Donations- I copied and pasted this from @John Morris. It would be great if each of us turners could help out! "We usually have a fundraiser raffle during the summer to help pay for our community, but my health took a dive this summer, and I never had the time nor the mind to organize our annual summer fundraiser, so we are falling short of our budgetary obligations. We will be very tight. If you are able to donate to our community, a dollar on up, it all helps." If you'd like to donate to our community, please see this page at https://thepatriotwoodworker.com/clients/donations/ I finally put the finish on the little walnut "spaceship"- Turned completely with Easy Wood Tools mini hollowers and their micro detailer ( @Jim from Easy Wood Tools ) Safe turning Edited September 12, 2019 by lew Gunny, DuckSoup, p_toad and 2 others 2 1 2 Quote
Gerald Posted September 12, 2019 Report Posted September 12, 2019 Good job on the post Lew and the bowl has a great look. That is some of the darkest walnut I have ever seen. lew, Cal, FlGatorwood and 1 other 4 Quote
Gunny Posted September 12, 2019 Report Posted September 12, 2019 Another post with a lot of good stuff. Excellent job on putting this together each week @lew. 2 hours ago, lew said: Turned completely with Easy Wood Tools mini hollowers and their micro detailer ( @Jim from Easy Wood Tools ) For those wondering about purchasing Easy Woods Tools contact Jim, either here or call. Got some slushy funds this week and decided to order a few chisels and try them out. He was very helpful in picking out the correct chisels for the work I do and where I store them when done. They should be here in a few days but I have a busy schedule with my carport remodel so may not get to use them for awhile. Enjoyed chatting with him but my time was short, I called from work. Cal, lew, p_toad and 1 other 4 Quote
HandyDan Posted September 12, 2019 Report Posted September 12, 2019 Thanks Lew. The twisted box video looks interesting. I'll have to view it soon. Your bowl with a hat does look spectacular with the finish one it just as I suspected. lew, Cal, FlGatorwood and 1 other 4 Quote
Popular Post Gerald Posted September 12, 2019 Popular Post Report Posted September 12, 2019 (edited) 10 minutes ago, Woodbutcherbynight said: where I store them when done. They should be here in a few days but I have a busy schedule with my carport remodel so may not get to use them for awhile. Enjoyed chatting with him but my time was short, I called from work. A tip on carbide. Clean out the screw and socket around cutter after each use and rotate the cutter if it is one of the round ones. If you do not do this you will eventually have a stuck screw and will have to break the carbide to remove it Edited September 12, 2019 by Gerald FlGatorwood, lew, p_toad and 2 others 3 2 Quote
Popular Post Gunny Posted September 12, 2019 Popular Post Report Posted September 12, 2019 7 minutes ago, Gerald said: A tip on carbide. Clean out the screw and socket around cutter after each use and rotate the cutter if it is one of the round ones. If you do not do this you will eventually have a stuck screw and will have to break the carbide to remove it Thanks, this is what we do on the metal lathe at work as well. Course we can put oil on it and let it soak being that it is metal and not wood all around. p_toad, lew, Cal and 2 others 4 1 Quote
lew Posted September 13, 2019 Author Report Posted September 13, 2019 @Gerald Thank You! And, thanks for tips on the carbide tool screw. I read somewhere that turners were gently heating the screw/cutter to loosen them. I'm not sure EWTs recommends that- maybe @Jim from Easy Wood Tools can add some advice here. @Woodbutcherbynight Thanks! And, thanks for the nod to Jim. He is a great guy and I know he helped you select the perfect tools! @HandyDan Thank You! I was surprised at how dark the grain became- especially as the chunk of walnut was originally destined for firewood. Gunny, Cal and FlGatorwood 2 1 Quote
Gunny Posted September 14, 2019 Report Posted September 14, 2019 9 hours ago, lew said: And, thanks for the nod to Jim. He is a great guy and I know he helped you select the perfect tools! Came today, Jim even sent a Tee shirt which my wife grabbed. FlGatorwood, Cal and p_toad 2 1 Quote
FlGatorwood Posted September 15, 2019 Report Posted September 15, 2019 Now, we have seen Pooh Bear's honey pot. That's a great job. Love it. Gunny, Cal and p_toad 2 1 Quote
lew Posted September 15, 2019 Author Report Posted September 15, 2019 @FlGatorwood Thank You! Just finished packing it up. Sending it to a friend for his birthday. Cal, Gunny and FlGatorwood 3 Quote
Jim L Posted September 16, 2019 Report Posted September 16, 2019 @lew thanks... that is a beautiful bowl we shared on our FB page too! You are good. Gunny 1 Quote
lew Posted September 16, 2019 Author Report Posted September 16, 2019 @Jim from Easy Wood Tools Thank You! Gunny and p_toad 2 Quote
Jim L Posted September 18, 2019 Report Posted September 18, 2019 On 9/13/2019 at 10:07 PM, Woodbutcherbynight said: Came today, Jim even sent a Tee shirt which my wife grabbed. That's funny.... Gunny 1 Quote
