Showing results for tags 'rip fence'.
I often need to cut or recut several small pieces way too small to hand hold and pass through the table saw. To accomplish this safely and cut several at once I take a length of straight flat board lay down a strip or two of double sided tape as needed and stick as many of the small pieces as possible to the straight board. I leave a couple of inches on the lead end and a couple of inches on the trailing end to make the entry and exit safer. I use this double sided tape it holds like super glue, this stuff www.amazon.com/dp/B07BBL4JXJ To get a release you can simply try to twist twist the pieces to shear the tape grip but if the pieces are small or delicate use some denatured alcohol on the tape it will release nice with just a little twist or prying up with a thin edge. Best to replace the tape for each run. The picture shows the setup calabrese55
- 2 replies
- frank howarth
- automated
(and 2 more)
I've just received a molder set and dado set; I'm planning to use them on my Shopsmith Mark V/500. I'm wanting to build a rip fence (vertical) extension which can also be used as a sacrificial for work right up against the fence. Right now I'm planning to use a 1 x 8 x 2' piece of lumber and dado out a 3/4" wide x 3/8" deep slot lengthwise where I can mount a pair of featherboards to help control the work as it moves past the heads. I have one featherboard from Shopsmith already; I was planning to mount that horizontally before the blade. Last I checked Rockler had some featherboards on sale; I was going to get two from them and then cut my slot so that they come down within 1/2" of the saw table at maximum extension. First question: Does this sound like a good plan? Second question: What kind of wood would the more experienced hands here recommend? I should be able to get poplar for $7.88, oak for $11.28, and then of course there's always whitewood or softwood. I'm new at this and I'll always be able to go back and re-do it in the future if necessary, but what would the old hands suggest to a beginner?
- 5 replies
- feather board
- dado
(and 2 more)
Craftsman 113 needs a rip fence
acr_scout posted a topic in Machinery, Tools, Research, Reviews and Safety
Hello all, I have an inherited Craftsman 113 from my Grandpa, to my dad and now mine. I have restored and it works pretty great for my weekend adventures. This past week I have finally gotten fed up with stock rip fence and I am wondering what your opinions are for the Delta T3 rip fence as a replacement. Thank you. -
Another collection of peculiar workshop related items. The stories and pictures you are about to see are real. Call it an obsession, sickness, hoarding, or missing fence rescue, IDK why I do it...I just do... Before you judge me and my madness illness, you should first speak to those voices in my head. Rest assured once you do, you'll be snatching orphan fences from the hands of the weak and infirmed too. With maybe a couple of exceptions, all have been $1 or less. those on the right probably 10-30 cents/ea. The Craftsman on the far left was a buck (maybe less), NIB at a yard sale. Some of the others again were 50 cents or less and maybe in a bucket or box with other "treasures" for a buck or two. Same pic as above, only with the box closed. If I recall, these two were $3...purchased from a Habitat for Humanity Restore in Illinois. Must have come out of a retailer who had a fire since there was soot all the packages and the packages were stained like water damage. The B&D will be assigned to a new old stock B&D 7-1/4" circular saw I bought at a flea market for $20. It was missing the fence. circular saw obsession will be a future post unless good weather comes first. As twisted as it may seem, there at least another 6 or 8 not pictured here. They've actually been assigned to orphan tools. Two of which were identical and perfect for my 5-1/2" cordless 19.2V Craftsman and my 18V Ryobi. Another was assigned to an old Craftsman Jig saw I rescued and re-furbed. I think I gave my ex-SIL a couple too. Well thanks for looking...they tell me it's time for my meds.
- 48 replies
In the middle of digging the router table out of it's hide-out....something came out as well... Just three pieces of scrap, glued and screwed together.....into a rip/crosscut jig.....or fence. Long ago, I made this little jig, to replace the cheapo fence on a DeWalt Job Site saw...You can barely see a cleat under the near end...it was sized to ride on the fence's rail. Couple of c clamps to attach to the rail. Have since used this as a saw guide for crosscuts with the circular saw. Also can guide a router for doing dados. Might just set it up as a rip fence for the bandsaw.. Something like this? Figures, now that all the rip cuts are done, this jig shows up.... May do a story about how this was made.....as the story in the old WOOD forum is long gone...
