Showing results for tags 'ash mallet'.
Found 10 results
  1. John Morris
    Chamfering the Edges
    From the album: Big Ash Mallet
    All the edges of the mallet were chamfered with my block plane and the handle of the mallet of was shaped using my draw knife and a card scraper.
  2. John Morris
    Just a Fun Image
    Here is a fun picture showing the hand tools I used to help make this mallet, it took a combination of my table saw to make the slots, the shoulder plane to clean up the slots, the miter saw to cut the blanks at 5 degrees, and my hand tools to shape and make it interesting.
  3. John Morris
    Ash Mallet is Done!
    The finished mallet at the right, and my two roughs waiting in the wings on the left. I put a very heavy coat of Watco Danish Oil on and wiped off.
  4. John Morris
    The Arc
    The arc.
  5. John Morris
    Drawing a Curve on the Mallet Head
    I used my bow arc to make the arc on the top of the mallet. Was an arc needed? No, but the mallet looks better with some shape to it.
  6. John Morris
    Cleaned up Glue
    Cleaned up the glue a tad
  7. John Morris
    Wedging the Mallet Handle to the Head
    Lots of glue in around the handle, and on the wedges, I wanted the entire slot filled with either wood or glue, securing it for life. I tapped the outer wedges in just a tad, and I drove home the two center wedges pretty hard. Keep in mind, if you make a mallet, the wedges must be tapped in perpendicular to the grain to avoid splitting the wood.
  8. John Morris
    Checking the Slot Width Fit
    A dry fit looking at the top of the mallet, the slot is tapered, so the bottom is tight and snug, the top is flared out leaving room for the wedges to secure the mallet. When I do these again I'll cut the slots so there is not much of a flare out at the top, it's really not needed. I think a 2 degree slot flare would suffice next time instead of the 4 degree.
  9. John Morris
    Test Fit
    The handles are just dry fit into the slots. To get a great fit I had to sneak up on the handle widths, as not all handle slots in each mallet were the same as the next, because I cut these on the table saw without any jigs, just eyeballing lines is all. So each mallet was a tad different. I had to plane each handle to fit each slot right. I'll have a better assembly process next time, I plan on making many of these and pass them out as gifts and possibly sell them as well.
