John Morris Posted February 18, 2017 Report Posted February 18, 2017 Folks, I am looking for a tenon cutter along the lines of these, I could purchase one from Mr. Elia, and I just may, I could make one but reality is, I don't feel like it. Though I may. Do you know of any other retailers who sell tenon cutters. I would prefer a 5/8". Or, plans, I may make one too. But, I would prefer to purchase if the price was reasonable. Thanks folks. HARO50 1 Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 (edited) Veritas® Tenon Cutters - Lee Valley Tools - Woodworking Tools ... and if you think your brain hurts after viewing... look for Bosworths.. yur nose will bleed too,,, but they are sweet... use a plug cutter... put it in a tap handle or bit brace... Plug Cutter, 5/8" Edited February 18, 2017 by Stick486 Dadio and kmealy 2 Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 11 minutes ago, Stick486 said: Veritas® Tenon Cutters - Lee Valley Tools - Woodworking Tools ... and if you think your brain hurts after viewing... look for Bosworths.. yur nose will bleed too,,, but they are sweet... use a plug cutter... put it in a tap handle or bit brace... Plug Cutter, 5/8" Thanks Stick, not looking for those though, looking for something like that picture. I'll probably end up making my own, but was hoping something out there was available ready to buy. Thanks man, appreciate the effort! Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 I found these earlier today, but still not what I am looking for, but it was the closest thing Veritas had. http://www.leevalley.com/us/wood/page.aspx?p=52401&cat=1,180,42288,52401 Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 CMT 529.158.31 Plug Cutter, 5/8-Inch Minor Diameter, 1-7/64-Inch Diameter, 1/2-Inch Shank W.L.Fuller is a good place to look too.. FWIW... I think I remember Roy Underhill having plans for one... kmealy 1 Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 2 minutes ago, Stick486 said: CMT 529.158.31 Plug Cutter, 5/8-Inch Minor Diameter, 1-7/64-Inch Diameter, 1/2-Inch Shank W.L.Fuller is a good place to look too.. FWIW... I think I remember Roy Underhill having plans for one... Thanks Stick, looking at images of wood tenon cutters they don't seem that complicated to make, I could do it without plans the more I think on it. See this fellows home made cutter at the top of the image with the "C" clamp, it's just a plane blade and a block of wood with the tenon hole proper size drilled into it. It is tapered but I like the look of tapered tenons in chair rungs, you don't have that pesky little shoulder that is traditionally exposed on the rung, it's accurate for the shoulder to be exposed, but just because they did it 200 years ago, don't make it right, I like the smooth transition of the chair rung to the hole when using tapered tenons. Image source:http://timmanneychairmaker.blogspot.com/2015/06/use-your-reamer-to-make-matching-tenon.html p_toad 1 Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 I'd think a hand tapered reamer would be just the ticket for the tapered hole... John Morris 1 Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 1 minute ago, Stick486 said: I'd think a hand tapered reamer would be just the ticket for the tapered hole... Just like the one he shows in his image. Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 7 minutes ago, John Morris said: Just like the one he shows in his image. More like these... Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 Not a bad idea Stick, it would work, but the matched wood reamer seems more appealing to me. Just trying stay a bit true to chair making tools is all. HARO50 1 Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 5 minutes ago, John Morris said: Not a bad idea Stick, it would work, but the matched wood reamer seems more appealing to me. Just trying stay a bit true to chair making tools is all. lathe time...The Tapered Reamer The other Tapered Reamer using the tapered reamer to make your rounding plane. Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 3 minutes ago, Stick486 said: lathe time...The Tapered Reamer The other Tapered Reamer using the tapered reamer to make your rounding plane. Now we are talking! Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 (edited) all we need is the right terminology... Rounding Planes - Ashem Crafts Rotary Planes Rounding Plane / Dowel Maker attempt #1: Wooden body ... Edited February 18, 2017 by Stick486 John Morris 1 Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 18 minutes ago, John Morris said: Just trying stay a bit true to chair making tools is all. get out your spoon brace bits... Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 (edited) More Rounding planes... Homemade Rounding Plane - HomemadeTools.net Edited February 18, 2017 by Stick486 John Morris 1 Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 19 minutes ago, Stick486 said: get out your spoon brace bits... No! Not ready to be that traditional yet, in time though, in time. Quote
lew Posted February 18, 2017 Report Posted February 18, 2017 https://woodgears.ca/reader/paul/dowel.html http://lumberjocks.com/GnarlyErik/blog/35575 Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 23 minutes ago, lew said: https://woodgears.ca/reader/paul/dowel.html http://lumberjocks.com/GnarlyErik/blog/35575 Thanks Lew! Quote
Stick486 Posted February 18, 2017 Report Posted February 18, 2017 12 hours ago, John Morris said: Just trying stay a bit true to chair making tools is all. round spoke shave them... John Morris 1 Quote
John Morris Posted February 18, 2017 Author Report Posted February 18, 2017 1 hour ago, Stick486 said: round spoke shave them... Wooden tenon cutter is all I want Stick! Just like the picture above or something similar. Quit trying to throw the kitchen sink in there will ya! Quote
