Showing results for tags 'tear out'.
Found 4 results
  1. Ron Dudelston
    Router Bit Tear Out
    Folks, I’ve made and sold a ton of cutting boards and cheese slicers over the years but I’ve hit a snag. I’m building stock for the 2026 Christmas sales and I decided to mix up my inventory of cutting boards by buying some acrylic templates and make some with fancy smancy handles. I’m having mixed results because of router bit grab and tearout particularly on the inside of the handles and it has to be the bit selection. I’ve used 2 fluted flush trim bits, spiral up feed flush trim and even compression flush trim bits. I’m ready to buy a new Whiteside 2 fluted 1/2” diameter, 1/2” shank but I thought I would reach and ask for your input.
  2. August is coming to an end. Our local schools start back tomorrow. Our Patriot Turners- We have a new member at the Patriot site. @Gordon joined this week and posted some of his turnings. He does some beautiful work! If you haven't already welcomed him, please take a minute to stop by his post and check it out! @AndrewB continues to rehab his shop and posted some more images of what he is doing. Pick up here from last week- What’s Coming Up- If you missed Cindy Drozda's most recent live tool talk, she uploaded it for replay- For The Newbies- Mike Peace demonstrates turning a clamshell. During the turning process, Mike encountered some grain tear out. He has a pretty neat way of handling the problem. His solution is at about 9 minutes into the video. Captain Eddie posted a short video on the importance of keeping the lathe's Morris tapers clean- John Lucas discusses techniques for sanding the inside of hollow vessels Expand Your Horizons- Lyle Jamieson provides tips on matching grain between the bottom and top of a turned lidded box and why grain orientation is important. When I learned to turn bowls I used a mortice to hold the blank to the chuck. It just seemed that it wasted less material on the bottom of the blank. I could easily convert the mortice into a foot for the bowl. Alan Stratton uses a similar technique to turn a Sapele bowl- How about embellishing your turning with clouds! Tim Yoder shows us how- New Turning Items- Last week we posted a link to the Niles Bottle Stoppers tenderizing kit. Since then, Carl Jacobson produced a video on turning handles for those items- Everything Else- From Ron Brown's Newsletter= The Difference Between Perfect And Good Enough Perfect Definition: “Having all the required or desirable elements, qualities, or characteristics; as good as it is possible to be.” In life, things are seldom perfect. When turning wooden objects, things are rarely perfect. I recommend that you strive to be better this time than last time. Three main areas within your control always make a huge difference in the final product and require surprisingly little extra effort. Shape Learning what shapes are pleasing is a lifelong quest for most of us. When you are making something for someone other than yourself, you have to consider the shape. It must be visually pleasing with the proper proportions. The curves must be fair and the separations must be sharp. A great way to develop an understanding of pleasing shapes is to study ceramics and glass vessels similar to the projects you undertake. There are tons of resources on classic shapes that have been around for centuries. There are good reasons for certain shapes to remain popular over the centuries. If you try to swim upstream for too long, you will soon tire and fail. Sanding This is an area most easily and quickly improved. 1) Half a Grit: if you start with 100 grit sandpaper, don’t go finer than 150 grit next. Then don’t go finer than 220 grit and so on. 2) Take time to visually inspect that all of the 100 grit scratches are removed before you finish with the 150 grit. If you don’t remove all of the scratches at each step, they will show through in the final finish. 3) I recommend using compressed air to blow off all of the sanding dust along with a strong raking light to inspect your work before moving to the next grit. If you are working with very hard wood i.e. ebony, cocobolo, African blackwood, padauk, acrylic, or epoxy, this is especially important. Take extra time to get it right now or you will have to do it over. 4) NOTE: I stop sanding wood at 320 grit. When using finer grits, friction can overheat the lignin in the wood and make it resistant to film finishes adhering to the surface causing the finish to fail much sooner. Finish 1) If you rush the finishing process, you will have ruined all your hard work. 2) Film finishes (lacquer, varnish, shellac, epoxy, friction finish-shellac) are more durable than wax finishes. But they take more time and effort. 3) Wax is a quick finish that will dull over time and need to be renewed either by reapplication or more buffing. Wax finishes are quick to apply and look shiny and sparkly in the short term. Wax is perfect for projects where saving time is important and the durability of the finish is of no significance. Wax or oil is mandatory for utility vessels such as salad bowls or kitchen utensils. 4) Multiple coats of lacquer (10 to 30) applied over several days and when allowed to cure for 30 or more days, can be polished to a brilliant mirror-like finish. This is the finish of choice for art and display-only pieces bringing top dollars such as in a gallery. Try to do better each time than the time before and you will quickly reach Master Status Skill Sets. Consider the end use for what you are making and decide how much time you can devote to making something perfect or just good enough. Safe turning
  3. Chilly, damp, rainy day. Hope everyone had enjoyable Christmas. Our Patriot Turners- @Fred W. Hargis Jr Asked our turners a question about tear out. More specifically, Fred wanted to know what tools and techniques could be used to prevent/repair it. Please see Fred's post and check out what our members had to offer and provide some input. New member @Barbara asked about getting a lathe as a gift for a novice. If you live in the Chicago area, maybe you could offer some leads. @RustyFN Showed us the shavings left from a bowl turn and mused about perhaps purchasing a coring system. Of course our gang had lots of other suggestions and some good natured ribbing- What’s Coming Up- Click on the images for more information and registration If you missed Cindy Drozda's presentation on her recess tool, she has it posted on her YouTube channel- For The Newbies- Lyle Jamieson has a short video on preventing vibrations while turning- An article from Kent Weakley help reduce/eliminate tool marks when turning a bowl- https://turnawoodbowl.com/10-tool-marks-tricks-wood-bowl-understand-fix-remove/?ck_subscriber_id=1577117793 Nice video from Craft Supplies USA on bowl turning- Expand Your Horizons- A couple of ideas to add more excitement to your turnings Ebonizing- https://turnawoodbowl.com/5-magical-ebonizing-wood-tricks-how-to-techniques-recipes/?ck_subscriber_id=1577117793 Make your own spalted wood- https://turnawoodbowl.com/spalting-and-spalted-wood-bowls/?ck_subscriber_id=1577117793 Mike Waldt demonstrates turning a goblet in real time- New Turning Items- Woodturners Wonders has made a change in their available sharpening systems- Click on the above image for more information. Everything Else- Sometime back, we included information on the Christmas Ornament Challenge hosted by Alan Stratton of "As Wood Turns". He has posted a video of the winners. Check out these beautiful and imaginative works of art! Safe turning
  4. Just a reminder, please add tags when you make a post. Tags help others locate similar subject matter when doing a search of our forum. Our Patriot Turners- @HandyDan gave us some great tips on reverse chucking a bowl when finishing off the bowl bottom- Dan explains his method in this post- @smitty10101 Posed a question about end grain tear out when turning a bowl. This started a great discussion on the various causes of tear out and how to minimize it. Check out Smitty's post for all the input- PLEASE CHECK THE "FOR THE NEWBIES" SECTION FOR ADDITIONAL REFERENCES ON END GRAIN TEAROUT Unfortunately, Smitty, could have used Dan's technique for revers chucking. His bowl became airborne and didn't fare too well- Our members offered some suggestions to help prevent this from happening again. @AndrewB turned a maple bowl. This turning blank has some awesome grain and Andrew did a beautiful job! See his accompanying post for more about this turning- @Fred W. Hargis Jr says he is a non-turner. Looking at this project, I think he is underrating his skills. Fred asked our forum for information on creating a lathe tool handle. and then showed us his work- Well done, Fred, well done! What’s Coming Up- Click on the following image for links to more information and registration- If you are in the New Hampshire area, the Art Of Turning has several craft shows coming up https://www.artofturning.com/ Not sure how many of our members use Facebook. If you have an account there, maybe this will be of interest- The link for more information- https://fb.watch/8sHnZ7Gg_I/ For The Newbies- A nice article from Highland Woodworking covering Parting Tools- https://www.highlandwoodworking.com/woodturning/parting-tool-options-for-woodturning.html?utm_source=ActiveCampaign&utm_medium=email&utm_content=Read+the+October+2021+Issue+of+Wood+News+Online&utm_campaign=October+2021+Wood+News&vgo_ee=SSZUGqILrYqLrMaaxASZAzpxdzkQNl9LgdxZ9pnzLRY%3D Now about that end grain tear out, some resources that you may find helpful. Some are videos, some are articles- https://turnawoodbowl.com/14-ways-to-avoid-wood-grain-tear-out-with-wooden-bowls/ https://sawmillcreek.org/showthread.php?285940-How-to-fix-end-grain-tearout-on-bowls Expand Your Horizons- A nice fall turning project from Tim Yoder- Mike Peace posted a short video on DIY finishes. Some interesting perspectives- New Turning Items- Ruth Niles' news letter arrived this week. She has those really nice pizza cutters in stock. They make excellent gifts if you know a pizza lover!! Who am I kidding- everyone loves pizza!!!!!!!!!!! https://nilesbottlestoppers.com/ The folks at Spiracraft have partnered with Nova and Woodcut Tools. See more at- https://spiracraft.com/?inf_contact_key=ca4abf70f183d368d7b987ce27196093 Don't forget, Woodturners Wonders offers group discounts for clubs- https://woodturnerswonders.com/ Everything Else- Recently, the turning community lost one of its well known turners. Braxton Wirthlin passed away from cancer. I copied and pasted this from Ruth Niles's newsletter: Our community suffered a tremendous loss last week when Braxton Wirthlin lost his battle with cancer. He was only 42 and left behind a wife (Melissa) and two small children. Father, husband, son, maker, and incredible friend to so many, Braxton was always willing to help, share, or lend a hand to anyone who needed it. As a gifted woodturner and maker, he inspired so many people and his joy and passion for the craft were evident to all who had the chance to interact with him. The woodturning community is both overcome with this loss, and overflowing with love for this man. Rest in Peace, Braxton. You are and will always be loved and your memory will be cherished forever. Carl Jacobson, in honor of Braxton, created this turning- Rick Turns list of last week's turning videos on YouTube- Safe turning and stay well
