Showing results for tags 'shoulder plane'.
From the album: Big Ash Mallet
Here is a fun picture showing the hand tools I used to help make this mallet, it took a combination of my table saw to make the slots, the shoulder plane to clean up the slots, the miter saw to cut the blanks at 5 degrees, and my hand tools to shape and make it interesting.- 3 comments
- 1 reply
- shoulder plane
- shaker box
(and 1 more)
I cleaned up the slots with shoulder plane, the slots were heavily kerfed so I used the shoulder plane to knock the kerfs down, not all the way, but just enough to clean it up.-
- lie nielsen
- shoulder plane
(and 2 more)
Painting WAS to be done today...Landlord fell asleep. He will try to get here in the morning...maybe. Sooo, that left me with not much to do....wandered down to the shop. had a few more tenons to cut, and then they'd all be done. Two of the parts had a curved side. Rather hard to clamp up in the vise...unless you keep a bit of scrap from where you cut the curves out. had to trim a bit off, to clear for the saw cut. Waxed up the backsaw Saw about a third of the way down. A chisel to pop the waste off, that old woodie plane to trim it flat. Rotate and repeat. The two curved ones were down, the non-curved one was almost easy. Set them out to show off N Not too bad? Should have stopped here...but..... Decided to try to chop out a mortise or three. Used the tenons to mark out where to chop. As long as I got which tenon went where. Here on the "Flat", wasn't too bad. Takes a few different chisels. Note the mortise in the side of the leg? This is where things when downhill....in order to clamp a leg so it won't hop around.. lay out where the tenon will go. It was while I was fiddling with the long aprons that things started to hop off onto the floor.....then a BIG dizzy Spell hit....Ok, enough is enough. Got out a pipe clamp, the bottle of Elmer's and a couple 1" nails. Glued up two legs and a top apron. Used a bottom apron to hold the legs straight. left a few short aprons in place... laid the rest of the small parts out. Thought about trying to fight my way through the mess.....maybe some other day. I did find out that the panel for the bottom shelf was a bit too short It will just reach to the legs...it was supposed to go a bit past them.....maybe a breadboard edge on the ends? I'd have to notch the breadboard to fit between the legs. Big panel sittin up IS the table's top. This will be the bottom of the top. Got to hide that knot, after all....stay tuned
