Showing results for tags 'face plate'.
Much needed rain this evening. Our Patriot Turners- @RustyFN showed us a couple of his latest projects. His lidded box with an acrylic finial is really gorgeous! Check out this post for more information and another turning! @nevinc created a couple of lovely plant pots using a variety of species. This one is my favorite- See his post for more images- Our "What's On Your Lathe" had lots of comments and several new projects- Catch up here- What’s Coming Up- Lots of stuff coming up. Click on the images for links to registration and information- For The Newbies- Just starting out, you may not have all the accessories to turn a variety of shapes. If you don't have a chuck, you can often get by with a faceplate. In this video, Mike Peace shows us how to make one from wood. He uses a Beall tap to cut the threads. You might check with a local machine shop to see if they have an old, dull tap to match your lathe threads. Mother nature is amazing. Turning blanks, from the same log, can be very different in color and grain patterns as Alan Stratton shows us, in part #1 of a two part video, Expand Your Horizons- Carl Jacobson turns a lidded box with a very unusual inlay- Richard Raffan does another green wood turning and then dries it in the microwave- New Turning Items- Couple of things from Niles Bottle Stoppers- The folks from Niles are also offering FREE IRD's on their products- Everything Else- Safe turning
- 3 replies
- niles stoppers
- caarl jacobson
- (and 17 more)
There are many ways to reverse a bowl and mount it to finish out the bottom. Here is one method I often employ. After turning the bowl as much as possible mounted in the chuck I then get out my biggest face plate and mount a piece of MDF to it. I use a set of calipers set to the bowl's rim diameter and mark the diameter on the MDF. I use a small Bedan type tool to make a cut for the bowl rim to sit in. I creep up on it to get the snuggest fit possible. As you can see the MDF can be used for many bowls before it needs replaced. I've been using this one for awhile. the groove only needs to be deep enough to keep the bowl in place. I've been lucky enough to sometimes get a press fit and the bowl will stay in place on its own. If not I put four screws around the perimeter and I guess tie the bowl to the face plate using 2" stretch wrap. The bowl is held very tightly and the bottom is easily finished and sanded. Just keep your hands away from the screws. This is the safest method I have ever used and have never lost a bowl. It is also the best method for centering the bowl too. I have a set of flat jaws and use them but also employ the stretch wrap when using them. I screw some sticks of wood on each jaw for the stretch wrap. The flat jaws get the bowl close to center but the face plate method is best. IMO of course. Below is the bowl you see mounted.
- 2 replies
- face plate
- stretch wrap
(and 2 more)
Quite a wide variety of things this week. Our Patriot Turners- @Ron Altier posted a question concerning his lathe's faceplate. He was having difficulty removing the faceplate after use. Our turners offered several suggestions and modifications. Head on over to Ron's post and see if you can add anything to what was discussed. @Gerald added a really great tip to the Woodturner's Forum tip section. He gave us a link to an article using the bandsaw for cutting bowl bland. Lots of good information- @John Morris Asked for information on the "Ring Master" tool for making bowls. Several of our members gave him their opinions. Please check in on this post and help John out with his inquiry- You know, our turners are the absolute best bunch of folks! @HandyDan posted his thanks to @John Morris for gifting him a buffing system. Dan is our pen making expert and this system really helped him improve the finish of his bullet pens. What’s Coming Up- More information and registration for this September event can be obtained at- https://gawoodturner.org/symposium/ For The Newbies- We want to thank @Gene Howe for passing along this reminder. Safety is really important, not just for beginners, either. Expand Your Horizons- I run hot and cold on what type of finish to put on a turning. Sometimes the function of the turning dictates the type of finish. Other times it is up to individual tastes. I really like the "feel" of the wood when you touch the turning while others prefer a more "finished" feel. If you like the high gloss finish, here's a video from M. Saban-Smith on the steps he uses to get a glass-like finish- New Turning Items- We found a couple of new items. From Woodturners Wonders, a small bit holder for use when sharpening. More on this holder is at- https://woodturnerswonders.com/collections/unique-tools/products/small-tool-bit-holder Second, it a new item from Ruth Niles. Ruth calls this one a "Tab Popper". This should be a hit with the ladies to protect their nails. Ruth has more information and images on her site- https://nilesbottlestoppers.com/product/niles-tab-popper/ Everything Else- The latest edition of Woodturning OnLine is available at- https://www.woodturningonline.com/index.php?edition=062019 . I know many of you do club demonstrations. There is a nice article about remote demonstrations in this issue. You can check it out at- https://www.morewoodturningmagazine.com/articles.php?articlesid=127&access=bb51e4e9a315 Rick Turns has the May edition of the YouTube woodturning videos. Please add a comment to Rick's posting. A lot of work goes into cataloging this data- I made a trip up to the Woodcraft store and now have been playing with my new Easy Wood Tools mini hollowing set ( @Jim from Easy Wood Tools ). I had a really dry, hard chunk of cherry. Used the straight hollower to make a bracelet. Shavings came off like it was green wood! Finished with mineral oil and beeswax. I had some maple, from a tree we had removed, setting behind the garden shed. When I cut into it, I discovered it had spalted. Couldn't let that go to waste although it is quite punky in places. Mounted a small chunk and went to work. I drilled a 1/2" hole down thru the center and then shaped the outside. I flooded the surface with CA to help stabilize the punky wood. Using the 0°, 45° and 90° tools to hollow out the center I made a wall thickness tool from an idea I stole from a Mike Peace video. He recommended spring steel wire but all I had was coat hanger wire. As you can see, I need more practice and a better thickness gauge. The bright light near the top is where I sanded thru the surface of the turning. It was extremely soft there. The lights near the bottom show thru REALLY thin walls! Side view from one angle, looks pretty symmetrical. Looking closely, you can see where I sanded thru at the neck. Turned 90° and now the asymmetrical neck can be seen on the right. The soft part sanded down quicker than the harder grain next to it. I just couldn't bring myself to pitching it. Made a jam chuck to finish the bottom- As fragile as the piece was, I needed to get it out of the chuck without banging on the sides. Air pressure to the rescue! When I make a wooden chuck (or glue block), I drill a small centering hole completely thru the wood. Turned out to be a good habit. And there you have it. Gonna play around, using the mini hollowing tools to create a small finial. Not sure about the finish, yet. Safe turning
