Showing results for tags 'crotch wood'.
House cleaning continuesssss... Our Patriot Turners- Member @Gordon asked our turners how they would prep a crotch log for turning. Lots of input from our gang on what he could do. Check out Gordon's post and read what has been suggested. Provide your idea, too! @RustyFN added a couple of beautiful pieces to our "What's Off" post. Rusty has friends who own a saw mill. They were kind enough to gift Rusty some gorgeous chunks of wood! Rusty provides more information in his post. @Fred W. Hargis Jr sent a question to Tim Yoder's "Your Turn". That's where Tim answers turning questions. Well, Tim answered Fred' question with a great video! Here's Fred's post and the Video from Tim Yoder- What’s Coming Up- If you missed Cindy Drozda's "Tool Talk" last Friday, She made it available on YouTube- For The Newbies- A week or so ago, @Fred W. Hargis Jr mentioned that he was still having difficulty when presenting the edge of a gouge to the work piece. I found this newly published video from Richard Raffan. This video has really clear, up close images showing the tool contact to the spinning workpiece along with explanations what is happening. Expand Your Horizons- Mike Peace added a second video to his "Tower Tops". In this video he answers questions and demonstrates some of the details for turning the top and the tower. Turning Time With Easy Wood Tools- Beading is a great way to add interest to a turning, whether it's a single bead or the entire surface. The process typically requires a dedicated tool for each bead size. Easy Wood Tools developed specialized carbide cutter that will fit on their Easy Start Easy Rougher; Mini Size Easy Rougher and Mid-Size Easy Rougher. The cutter radius are 1/8, 3/16, 1/4 and 3/8 inches. With this development, one handled tool can take the place of 4 different beading tools available from other manufacturers. These two videos show the cutters in action and explain how to use them. You can take advantage of this sale to pick up Easy Wood Tools products- @Jordan Martindale New Turning Items- The Woodturners Tool Showcase might just have some new items available. Registration is free at- https://streamyard.com/watch/UwJbzWJMHmsV Everything Else- Safe turning
Beautiful day in south central Pennsylvania... Our Patriot Turners- @Fred W. Hargis Jr Started a new turning and a new challenge for him- Fred had several questions about the best way to mount the piece on the lathe and some procedural turning questions. Our gang wasn't shy about offering their ideas and included some images of what they have done. Check out all of the interactions here- There were a couple of new comments on Fred's post about the lidded box he had turned. You can see the comments and images at- @kreisdorph scored some freshly cut oak. He turned this lovely bowl as a gift for the person who gave him the wood. Always a great thing to repay a gift and this lets the tree live on. What’s Coming Up- Click on the image for the link to registration and more information- For The Newbies- Sometime turners will uses different terms to describe the same thing or vice-versa. Here's Mike Peace's take on the Natural Edge Bowl and the Live Edge Bowl- And here he shows us his techniques for turning a live edge, or is a natural edge, bowl??? And from Lyle Jamieson, a tip on creating a strong glue block connection for bowl turning. Expand Your Horizons- Richard Raffan shows his method of sanding the inside of his turned boxes. Nice tip! Tired of turning bowls? Looking for another form that will be well received as a gift? Try turning a platter- New Turning Items- New style bronze threaded rings from Niles Bottle Stoppers Everything Else- Ron Brown's newsletter included a free sharing of his published list of woodturning "Pearls of Wisdom" and a free download of the Turners Reference Guide. Ron Brown’s Pearls: Turners Reference Guide© brought to you by Ron Brown’s Best, LLC 1. There are exceptions to every rule except this one. 2. Six types of chisels are needed to make up a basic turning set (Spindle Gouges, Roughing Gouges, Bowl Gouges, Skews, Scrapers & Parting Tools). 3. Sharp Lathe Tools are more fun. 4. Speed formula: diameter in inches X speed in RPM should equal 6,000 to 9,000 (10” X 800 RPM= 8,000). 5. Rub the bevel on all cutting tools; not on scraping tools. ABC= Anchor the tool, Rub the Bevel, Pick up the Cut. 6. Have safety gear on hand and use it; full face shield, dust mask. 7. Always rotate the workpiece by hand before turning the lathe on to check for interference. 8. Start at slow RPM to check for balance, and then speed up. 9. Speed can be our friend. 10. If you are afraid, slow down and take a breath. 11. “Life’s too short to turn ugly wood.” John Jordan. 12. Carpe Lignum, Torne Lignum – Seize the wood. Turn the wood. 13. Variable-speed lathes are better. 14. Learn to hone. 15. Have a plan before you start. 16. Be Flexible. 17. Turn green wood often. 18. Greenwood is like lettuce, cut what you can use or it will spoil. 19. Learn to use your tools well and keep them sharp. 20. Sharp tools are safer. 21. Sharp tools produce better results. 22. Invest in a good sharpening system and learn to use it well. 23. Then teach others. 24. Don’t skip grits. Never jump more than 50%, i.e. 100 grit to 150 grit to 220 grit to 320 grit. 25. Your family will love whatever you make. 26. Listen to your spouse; they usually have a better eye for design. 27. Never point out your mistakes to others. 28. Spindle turning often requires more skill and imagination than bowl turning. 29. “Never scrape when you can cut.” Mike Mahoney. 30. If you must scrape, raise a fresh burr. 31. Get and learn to use a ¼” wide parting tool. 32. Learn to make lots of “Fun Stuff” like tops, pens, stoppers, light pulls and small lidded boxes. It will make you a better turner and your family will think you are a genius, especially at Christmas time. 33. Make Christmas gifts for your family every year and start in June. 34. Invest in education like classes, seminars and symposiums. 35. Spend the money for personal one-on-one instruction with a professional turner. 36. If you are not failing every now and then, you are not learning. 37. You learn the most when you teach others. 38. Buy good quality M2 High-Speed Steel tools. Avoid high-carbon tools; they are a waste of time. 39. Learn to turn right and left-handed. 40. You can use a bowl gouge on spindle work, but usually not the other way around. 41. Sandpaper is cheap; throw it away often and use fresh stuff. 42. Sign and date your workpieces along with the kind of wood. 43. Buy the best chuck you can afford, and then buy lots of jaws for it. Then buy another chuck. 44. Make your own tool handles. 45. Try someone else’s tools. They might know something you don’t. 46. Join an AAW chapter then go to the meetings. 47. Read turning magazines. 48. Watch turning videos on YouTube, but don’t believe everything they tell you. 49. Buy educational DVD’s. https://longworthchuck.com/index.php?route=product/product&path=10&product_id=219 Turners_Reference_Guide.pdf Safe turning
- 3 replies
- richard rodgers
- sanding stick
- (and 20 more)
I had another piece of this stuff so I thought I may try to play with it. What I don't know is whether that's possible...especially after I trimmed it down a little, maybe i screwed the pooch with my trimming. Anyway, the first 2 photos show the front/back if you will of what i started with. Thinking I needed a flat surface on one side, I slabbed some off to give me just that. Then I cut a little off one end to "square" it up a little. So that's what I have left. I was thinking about a small platter or shallow bowl showing the crotch of the branch coming off of it. The piece I have left is about 6 1/2" tall (long grain) and about 8 1/2" across at the branch stub. Without any direction at this point I might try to put a worm screw into the flat part centered across the 8 1/2" dimension and try to round it out some and put a mortise in the other side to accept chuck jaws. But maybe i should just put this on my brush pile to burn. Advice?
Whew! Is it ever hot out side. Back porch thermometer, in the shade, reads 98°! Good thing I painted 150 feet of chain link fence yesterday when it was only 95°!! On another topic, keep watching TPW for BIG news!!! Our Patriot Turners- @Gerald posted a root ball turning he completed. Lovely colors and design! Lots of great comments on this one- @User74 added to our "Off Yor Lathe" continuing post with a lovely bowl turning- You can see more images and comments at- There have been a couple more comments added to @Fred W. Hargis Jr post for a turned box. Also, Fred's post on turning a crotch log has generated more interest. Questions and answers abound! What’s Coming Up- Click on the images for more information and registration- For The Newbies- Mike Peace recently did a club IRD on box turning. This is the complete demo so it is a little long but has lots of good information. Thinking about purchasing that first scroll chuck. I copied this from Woodturners Wonders email. It offers some good advice about choosing a chuck. No I do not have any affiliation with them! Choosing the Right Woodturning Chuck: A Guide for Enthusiasts When diving into the world of woodturning, selecting the right chuck for your lathe is crucial for both the quality of your projects and your overall experience. At WoodTurners Wonders, we understand that every turner has unique needs and preferences, which is why we proudly offer Vicmarc, Axminster and Easy Wood Tools woodturning chucks. Here are some key factors to consider when choosing a chuck, along with the advantages of these renowned brands. Key Factors to Consider When Purchasing a Chuck Compatibility with Your Lathe: Ensure the chuck fits your lathe’s spindle size and thread. Different lathes have varying spindle sizes, so double-check your lathe specifications before purchasing. Size and Weight: The size and weight of the chuck should match your lathe’s capacity. A heavy chuck on a small lathe can strain the motor and affect performance, while a lightweight chuck on a large lathe might not provide sufficient grip for larger projects. Grip and Holding Power: The chuck must securely hold your workpiece. Consider the types of projects you undertake—bowls, spindles, or intricate designs—and choose a chuck with jaws that suit those needs. Ease of Use: Look for chucks that are user-friendly. Quick and easy jaw changes, smooth operation, and robust construction can significantly enhance your turning experience. Jaw Compatibility: Some chucks offer interchangeable jaws, allowing you to adapt the chuck for different projects. Check if the chuck you’re considering has a range of compatible jaws. Vicmarc Woodturning Chucks Vicmarc chucks are known for their precision engineering and durability, making them a favorite among professional turners and hobbyists alike. Here are some standout features: Superior Build Quality: Vicmarc chucks are crafted from high-grade materials, ensuring longevity and reliable performance. Precision Engineering: The precision of Vicmarc chucks means less vibration and better stability, leading to smoother and more accurate turning. Wide Range of Jaws: Vicmarc offers a variety of jaws, making their chucks versatile and adaptable for different projects. User-Friendly Design: Many Vicmarc chucks feature a quick-change jaw system, simplifying the process of switching jaws for different tasks. Axminster Woodturning Chucks Axminster chucks are celebrated for their innovative designs and exceptional value, making them a great choice for both beginners and seasoned turners. Key benefits include: Innovative Features: Axminster chucks often incorporate unique features like woodworm screws and dovetail jaws, enhancing their functionality and versatility. Excellent Value: Despite their high quality, Axminster chucks are competitively priced, offering great value for money. Robust Construction: Built to last, Axminster chucks can withstand heavy use and demanding projects. Stainless Steel Construction: The Axminster chucks we offer are made of stainless steel, which resists rust and corrosion. This is particularly beneficial when turning wet wood, ensuring your chuck remains in top condition over time. Comprehensive Support: Axminster provides excellent customer support and a wealth of resources for turners, from instructional videos to detailed manuals. Easy Wood Tools Chucks Easy Wood Tools chucks are designed with ease of use and innovation in mind, making them a popular choice for turners of all skill levels. Here are some key advantages: Innovative Design: Easy Wood Tools chucks feature a unique quick-change jaw system that allows you to switch jaws in seconds without any tools, streamlining your workflow and saving time. User-Friendly Operation: These chucks are designed to be intuitive and easy to use, making them ideal for both beginners and experienced turners. Durable Construction: Made from high-quality materials, Easy Wood Tools chucks are built to withstand regular use and provide consistent performance. Versatility: With a range of compatible jaws and accessories, Easy Wood Tools chucks offer flexibility for a variety of turning projects. Making the Right Choice Ultimately, the best chuck for your lathe depends on your specific needs and preferences. Vicmarc, Axminster and Easy Wood Tools offer exceptional products, each with their own unique advantages. Consider the types of projects you’ll be working on, your lathe’s specifications, and your budget to make an informed decision. At WoodTurners Wonders, we are committed to helping you find the perfect tools for your craft. Whether you choose a Vicmarc, Axminster or Easy Wood chuck, you can be confident in the quality and performance of your purchase. Visit our store or website to explore our full range of woodturning chucks and accessories. Happy turning! Expand Your Horizons- Last week's post included a tip from Lyle Jamieson about making a secure glue block connection. In this video Jim Rodgers demonstrates another method of connecting to a glue block- Another scoop from Alan Stratton. This one uses offset turning and a couple of neat jigs. Also, check out Alan's method for turning spheres- WITHOUT a jig! New Turning Items- Posted the video about these last week but here's the official Niles Bottle Stopper announcement- **NEW PRODUCT ALERT** We’re excited to introduce our new Low Profile Lightweight Threaded Rings, available as a set of all three or individually in three sizes: 1.5”, 2.5”, and 3.5”. Made in the USA from bronze, these rings feature: - 1.5″ ring: Inside measurement 1″, overall height 3/8″ - 2.5″ ring: Inside measurement 2″, overall height 3/8″ - 3.5″ ring: Inside measurement 3″, overall height 1/4″ This hardware creates a secure closure for lidded boxes, urns, canisters, and other similar projects. They consist of a male and female thread, which helps create a tight seal. These rings are lighter weight and lower in profile than our original Threaded Rings. The original rings are also still available and might be better suited for urns. Installing the new rings is a little different than the original style. The new rings require a tenon on one half. Pricing and more information is here- https://nilesbottlestoppers.com/product/low-profile-lightweight-threaded-rings/ Everything Else- Just for fun Safe turning
- 4 replies
- tim yoder
- niles bottle stoppers
- (and 23 more)
