August 7, 20197 yr comment_198098 Our Patriot Turners- @Ron Altier used the heat method to "recolor" the purple heart in his latest ornament. Check out Ron's description in his post- @RustyFN continues to work on the glue-up for the vase he is going to turn- See how Rusty plans to get his blank ready for turning- @Gerald is finally starting to see the light at the end of the tunnel with his collection plates- See more images and what Gerald has accomplished in his continuing post- What’s Coming Up- Click on the above image for the link to more information and registration. For The Newbies- The latest edition of Woodturning OnLine arrived this week. We are placing this here because there is a short, but good, article on selecting a lathe- The lathe article can be located at this site- http://www.yoyospin.com/lathe/ The Newsletter can be found at- https://www.woodturningonline.com/index.php?edition=082019 As always it contains a lot of great information. Expand Your Horizons- A couple of videos from our friends Mike Peace and Carl Jacobson showing us different methods of embellishing our turnings. First, Mike demonstrates how to create a shop made detailing tool. Carl demonstrates the processes of creating a "Basket Weave illusion"- New Turning Items- The folks at Woodturners Wonders have some conversion pads for those PSA sanding discs- Check their site for prices, sizes and additional products- https://woodturnerswonders.com/products/conversion-backer-pad?_pos=1&_sid=bfc7eb061&_ss=r While this isn't a "tool" in the ordinary sense, I thought we'd place it here. This information came in an email and the site looks interesting. If you are thinking of getting recognized and/or selling your turnings, maybe check it out- https://artofturning.com/ Everything Else- When life gets a little overwhelming, turning usually helps relax me. But then again... This little turning was supposed to be more practice with the new Easy Wood Tools ( @Jim from Easy Wood Tools ) mini hollowers. It wasn't the best piece of walnut as it had stress cracks but what the heck. The outside shaped up nicely and the hollowing was going well. I thought "just one more pass"- and... The entrance hole was compromised by some of the small cracks. Even the CA didn't hold. Probably should have just pitched it and chalked it up to learning. After a couple of days, I snuck back down to the shop and decided to play with it a little more- By accident, it ended up with a cool interior design. The pattern was created by using the Easy Wood Tools mini straight hollower. Moved the tool tip a little farther over the tool rest and allowed it to "vibrated" by lessening the downward pressure on the tool rest. It sorta acted like a chatter tool. Not sure what will become of this, maybe add a lid, with a finial, or a pedestal base, or all of those???? Safe turning Report
August 7, 20197 yr comment_198101 Another good post Lew. I watched Mike Peace make his detail tool. I may make one. I have some dull 6" jointer blades that would make great stock for this. Nice save on your turning. I do like the design in the bottom too. One bad accident and one good. Report
August 7, 20197 yr comment_198102 Thanks Lew. Just one more cut has gotten us all in hot water. Good save. Report
August 7, 20197 yr comment_198103 Another post of good stuff to read through. Heck by winter when I get inside the shop and can use the lathe I might be able to turn a thing or two. If I am lucky maybe 3... Edited August 7, 20197 yr by Woodbutcherbynight Report
August 8, 20197 yr comment_198143 Thanks, Lew. As always in interesting post. I still can't figure out the pattern of the ornament. Especially, the flat face. Really nice save on the bowl. I know that was not the intention, but it works very well this way. Report
August 9, 20197 yr Author comment_198307 @HandyDan Thank You! I have a couple of those, too. Might give them a try. @Gerald Thanks! I'll probably never learn when enough is enough! @Woodbutcherbynight Thank You! Hope you don't have to wait that long! @FlGatorwood Thanks! Yeah, that's another one of Ron's mystical glue-ups! Report
August 10, 20197 yr comment_198348 11 hours ago, lew said: Hope you don't have to wait that long! Summer projects will last till end of Fall I am guessing. Nothing has gone wrong just takes time to finish something completely. In this case it is a rather large project for me. Edited August 10, 20197 yr by Woodbutcherbynight Report
