More Repurposing and Junk (PC Desk/Cabinet)
2 minutes ago, Grandpadave52 said:
Any bad day doing something fun like this is still better than the best day at work.:P
Looking good...
Good luck with that...high maybe of mid 20's here if our sacrifice is accepted.:wacko:
I agree Dave, but mid 20's is also our forecast high for tomorrow.
Today we were having winds in the 45-50 MPH range for most of the day. The wind chill made it feel like the upper teens.
It's still gusting in the 40-45 MPH range now.
  • Replies 82
  • Views 12.2k
  • Larry Buskirk
    Larry Buskirk
    Yesterday, and todays progress report.   Yesterday was our bulk pick up day, so of course I went scrounging for goodies. I didn't find much, but I also went to my storage, and saw my neighbo
  • Exactly!!  Took a page from your book and went with a hammered finish for the electrical conduit and box.  Grey plastic wasn't going to be classy enough!
  • Larry Buskirk
    Larry Buskirk
    Todays progress report.   Today I accomplished several things on this build. First off I used the part of an old Oak desk that went below the center drawer to make a ledge at the back side o
Ditto...same here, well except for that Lake effect you're blessed to enjoy.:wacko:
so that's what's going on...
yur sacrificing my weather...
If only...if only...
The needs of the many outweigh the needs of the few or the one.
:JawDrop:
not in this case...
This place more to your liking?
almost...
almost...
It is in Antarctic Stick, as cold and snowy as it gets currently.  :Laughing:
I'm just saying.....
Edited by Woodbutcherbynight
the Antarctic only gets 6~7'' of snowfall a season...
let's do the Japanese Alps if you want snowfall...
It stays all year round, what more could you want?  And cold?  OMG:JawDrop:
been there in the summer..
it don't stay all year...
it turns to rocks everywhere...
and what's not rock, is ice sheet...
You were in wrong spot, that's where the UFO's dump the toilet before take off
now ya tell me..
besides that the leopard seals will try to eat you if you ain't careful...
1 minute ago, Stick486 said:
leopard seals
I see you met the aliens!
Due to the weather being to cold to do much of anything outside today, I worked on getting the keyboard/trackball tray closer to finish. First I added the outside mounting cleats which you'll see in this photo. I may use the chase section between the inner, and outer cleats to use the crystal lamp indicators that will now not be used due to forgoing the PC case lid, and possibly for other uses.
This photo is of a side view of the outside mounting cleats. The rear section will be left open, and used as a chase for power cords, monitor cords etc..
The chase will be covered later as the hutch section gets built.
I also added a keyboard stop to the tray.
It is made from another piece of the 1/4" X 1/2" Oak strip. It  is the same height as the front edge of the keyboard.
The whole keyboard tray gets mounted with four brass screws, two of which you can see in the following photo. The other two come up from the bottom of the original "Ice Box" top and into the short cleats at the front of the assembly. This section will remain removable for servicing etc. The upper hutch will mount into the sides of the outside cleats.
I will be using a hole saw to cut a cable access hole into the lower "Ice Box" lower case section.
That's about it for today.
Until next time. :TwoThumbsUp:
Edited by Larry Buskirk
Nice work.  Save the plug from the hole saw, lots of uses for them later.
Progress is progress...
I'll be here...well except for when I'm somewhere else.
Thanks Curtis, I always save the plugs, you never know when you might need to plug a hole.
Thanks Dave, I'm usually somewhere else myself. :WhoMe:
