Showing results for tags 'wine glass'.
Found 3 results
  1. More nice weather! Garden rototilled and fertilized. On to replanting grass over the dog's bathroom. Our Patriot Turners- @Steve Krumanaker posted a cedar bowl he finished up. Beautiful colors and grain patterns! Check out the comments from our turners at- @forty_caliber is still cranking out bowls from his dryer stash. This one has some gorgeous spalting- In his post, he tells us about the shape- @Gerald mentioned he did a presentation for the Magnolia Woodturners club. He demonstrated some of the tools and methods for embellishing a turning. This video picks up at his part of the presentation- Thanks, everyone for continuing to post in our thread on "What's On Your Lathe"! I think this is about where we left off last week- What’s Coming Up- Click on the images for links to more information and registration- Note: The Bowl turning class will also be on June17, 2023 For The Newbies- Put your spindle skills to work and turn a mixed media wine glass. Very informative video from Craft Supplies USA Mike peace demonstrates turning small square bowls. These can be made from scraps of even several boards glued together. Expand Your Horizons- Carl Jacobson turns, carves and adds color to a vase- I've seen this turning show up on several social media sites. Carl Jacobson explains how it is done- We pretty much know about scroll chucks and jam chucks but do you know about a "cup chuck"? Richard Raffan demonstrates- I'm not sure which I enjoy more- watching Alan Stratton turn objects or looking at the shop made jigs he uses. For a "jig junky" like me, it's a real treat. In this video, Alan adds Celtic Knots to Easter eggs- New Turning Items- Not new but on sale from Niles Bottle Stoppers- https://nilesbottlestoppers.com/product/tenderizer-set/ Everything Else- From Ron Brown's Newsletter- Difficult Things Why Is It Always So Hard The First Time You Try Something New? Do you remember the first time you tried to ride that bicycle? How about roller skates, ice skates, or a skateboard? And I hope trying that hoverboard didn’t send you to the emergency room. What about parallel parking or hooking up that trailer? Then there was your first time using a skew chisel, WOW! I’ll bet you didn’t even know catches that big were even possible. How about the first time you tried to get started hollowing the inside of a bowl? Did the gouge skate clear off the edge like mine did? The reason is that you don’t know what you don’t know. As we summon enough courage to try something new, we imagine how it is supposed to go and how we are supposed to react. It seldom goes as well or as badly as we imagined. We try again, but the second time around, we adjust from what we learned the first time. The third time it gets better and so on. When I demonstrated turning on the Woodworking Show Circuit, I would often hear the phrase “He’s done that before!”, or “I’ll bet that isn’t his first time!” I promise you, it gets better. If you have the courage and persistence to try and try again, you eventually figure it out. The secret is taking the time to understand what went wrong so you can make the small changes necessary for success. I deal with this scenario almost daily. I find it really helps if I limit my changes to only one or two things so I can narrow down the culprit and focus on those areas. As an example, if torn grain is my issue, I might change from a gouge to a scraper or a gouge with a different grind. If that doesn’t work, I might try shear scraping (holding the scraper at a 45-degree angle). You can shear scrape with both the scraper and the gouge. You just have to turn the gouge over. If that fails, I might cut from the inside out or the outside in using lighter cuts over the problem area. I’ll change up one thing before moving on to something else. Imagine trying to juggle the effects of speed, feed, tool geometry, cutting angles, grain orientation, and wood hardness all at once. My advice is to control what you can and understand that some things are out of your control. Make small changes slowly until it works like you want it to. Be careful not to tweak it so much that something that used to work, doesn’t work anymore. That is something I also have to guard against. It happens all too frequently when running complicated machinery like CNCs and Lasers. Rome wasn’t built in a day and you will be money ahead when you learn to make changes little by little. One day soon you will have figured it out and folks will marvel at your expertise. Zig Zigler often said, “Yard by yard it’s hard, but inch by inch it’s a cinch!” Remember that wherever you go, there you are. Safe turning
  2. HandyDan
    Wed Wisdom Inspired
    On Oct 19 the Wednesday's Wisdom had a video on mushrooms and I swear there was a video on a natural edge wine glass but I can't find it. I had some time to play and decided to give the mushrooms a shot. I have a Linden/Basswood tree out back that drops up to 3" diameter limbs at times. This year when cleaning up I decided to bring some in to give them a try on the lathe. Turns out they hold their bark like it was glued on. Found out turning a mushroom and grabbed the biggest limb and turned a wine glass. Tear out was a big problem with the Basswood but sharp tools proved to be the answer again.
  3. Last day of August! Where did the summer go?!?!? Our Patriot Turners- Our turners have been busy this week! @Gerald posted about a novel idea for embellishing a turning. He describes the materials he used and how he obtained the neat colorization in his post- @Gunny posted this in the "What's on tour weekend agenda"- Gunny has these down to an art! @forty_caliber finished up a bowl he started a while back. The grain and color in this one is incredible! He explains the name in his post- @RustyFN posted his beautiful Calabash bowl. He received lots of positive comments and @Gerald was kind enough to post a couple of his bowls for comparison. What’s Coming Up- Hold onto your hats- lots coming up in the near future! A bunch from the AAW. Click on the images for links and information. For The Newbies- Jim Rodgers continues his instruction on how/why catches happen. In this one, Jim discusses the scraper- Expand Your Horizons- Mike Waldt turns and embellishes an ash hollow form- ...and a Yew lidded box Seems we have been really concentrating on making scoops. Another idea but quite different than the previous designs- New Turning Items- SWAT was this past weekend. Cindy Drozda took the opportunity to video many of the vendors and their products. She was live on several occasions. She has posted some of the material on her YouTube Channel. The link to her channel- https://www.youtube.com/user/cindydrozda Craft Supplies USA is having a closeout on a bunch of their products. Some good prices! https://www.woodturnerscatalog.com/Sales/20/Closeout?utm_source=csusa&utm_medium=email&utm_content=closeout&utm_campaign=22-08-closeout Woodturners Wonders Weekly sale: https://woodturnerswonders.com/collections/weekly-sale A couple of weeks ago we mentioned the 3M Xtract sand paper. Taylor Toolworks is currently having a sale on the product- https://taytools.com/collections/3m-xtract?afmc=17p&utm_campaign=17p&utm_source=leaddyno&utm_medium=affiliate Everything Else- Rick Morris must be on vacation this week- He didn't post his usual list of turning videos. Tim Yoder is always a lot of fun to watch- I've been kicking this idea around for a while. Usually, when I make a lidded container, I will use contrasting species for the lid and body. Some things like pepper mills are made from a single piece of the same species. Cutting the blank in half and then creating a tenon can cause a noticeable grain mismatch where the cut/tenon is created. I was watching one of Cindy Drozda's live tool talks and she described a technique that minimizes the material loss and grain mismatch. After cutting the blank, it is glued back together with a sacrificial piece between the halves. This sacrificial piece becomes the tenon. My first attempt at this was a miserable failure. The cuts were not clean enough to create a good glue joint. I'm thinking I need a way to ensure the pieces will look seamless when mated together. My next try was a little better. The first thing was to create a sharp cut with no tear out. I forgot to take a picture in my haste but I used a skew chisel to start the separation cut. Then used my freshly sharpened, shop made, thin parting tool. Also cranked the lathe speed way up to part off the pieces- I did not create a tenon. Instead, I decided to turn tight fitting plug that would be used as the lid tenon. Mortice in one end- Fitting the plug Glue the plug into one of the mortices- the lid on this one. Trim the plug so the two halves fit together- Carefully hollow out the insides making certain not to touch the plug mating surfaces. I did not spend a lot of time sanding the inside. My main goal was to see if the plug idea would work. Some sanding on the outside and testing the grain match- Had to play a little to fancy up the very plain shape- I think this will have a much great effect when used on highly figured wood. This was from a very old piece of air dried walnut. Quite brittle. Safe turning
