Showing results for tags 'mcnaughton coring'.
Lots happened this past week! Our Patriot Turners- @Gerald posted more images of his "Frig Magnets". His Jaho jig really creates some spectacular designs! Here's where the new entry starts- @John Hechel made a couple of posts in our sub-forum for Ringmaster Turning. He showed us some of his glue ups and some absolutely gorgeous bowl! Check out his posts here- @RustyFN posted an update on his new McNaughton Bowl Coring System. He created some measuring devices to help setup the system for different sized cores. Thanks, Rusty for the update! I love all your posts on our "On/Off Your Lathe". It is so enjoyable to see the development and finishing of the projects. From "ON"- From @kreisdorph and @Gerald Catch up from last week starting here- From OFF- @kreisdorph and @User74 The latest entries start here- What’s Coming Up- If you missed Cindy Drozda's Tool Talk last week, she posted the video on her YouTube channel- Click on the following images for links to registration and more information- For The Newbies- The bowl gouge can be confusing for the new turner, especially when it comes to the type of "grind" on the tip. Professional turners seem to have individual preferences and provide that grind style on the tools they recommend/sell. Lyle Jamieson discusses his preference in this video. Jim Rodgers creates another custom pen. Check out some of the jigs he uses to create the pieces. Expand Your Horizons- Alan Stratton turns a bowl as a keepsake for a tree that needed to be removed. Most of us do this when we are gifted wood. What I found interesting was Alan's use of UV epoxy instead of the typical epoxy/acrylic. Here's the entire video- the UV information is at about 4:30. The "4 Ways Collaboration" continues. This month they turn multi-sided plates Mike- Tomislav- Sam- Richard- New Turning Items- From Ron Brown- Glue Press for Bowl From Board or Segmented Rings https://longworthchuck.com/index.php?route=product/product&product_id=536 Everything Else- My experiment with the turned blank from last week was a miserable failure. That turning became this- The prototype for a passive amplifier. There was a barely noticeable increase in volume but it looks neat. Biggest mistakes- don't use a spade bit for long holes, cutting an angle and rotating is not produce as nice as cutting 2 angles. As in Alan Stratton's video, I did turn a little bowl from our Crab Apple tree that is dying by inches. Planted it in 1969. Safe turning
- 7 replies
- glue press
- ron brown
(and 30 more)
- glue press
- ron brown
- sam angelo
- tomislav tomasic
- richard raffan
- wednesday
- wisdom
- woodturning
- magnets
- jaho
- ringmaster
- bowls
- mcnaughton coring
- hollowing
- segments
- cindy drozda
- tool talk
- finials
- scott hampton
- off center
- faux ceramic
- q&a sharing
- todd raines
- lyle jamieson
- gouge grinds
- jim rodgers
- pens
- alan stratton
- keepsake tree
- 4 ways
- multisided bowl
- mike peace
