Showing results for tags 'dowel jig'.
I posted a couple weeks ago about a shop contacting me to make drop spindles which are used in spinning wool. There are two basic components, the "whorl" which is pretty easy and quick to do. The shaft, which is a little problematic. The shaft needs to be about 12" long and around 5/16" diameter. Kind of difficult and tedious to turn and with a small margin I need to turn them as quickly as possible. Looking for options I bought a dowel jig that uses a drill motor to create a dowel. It works but I got more tearout than I liked, especially on woods like oak or ash. I then did some searching and watched some videos about using a table saw to make dowels. You read that right, you can make a dowel or spindle using your table saw. It works, and it works pretty darn good. Pretty nice finish which will require just a little sanding and it's pretty consistent as far as diameter Produce_5.mp4
- 10 replies
- woodturning
- spindle
(and 8 more)
