5 hours ago5 hr comment_382969 Fairly new to the forum, and certainly new to turning. I've been a cabinet maker for more than 30 years but haven't used a lathe since high school shop. (which is longer than I would like to admit)I bought a Delta 46-541S many years ago at an auction and it has been sitting around my shop ever since. I'm starting to slow down with my cabinet making and want to start turning a few things. The lathe came with a set of tools and I know carbide tools are a possibility too. I have one square carbide chisel and can see the benefit of both type tools. At least at my experience level. I know the older Delta lathe isn't optimal and will certainly buy something else in the future if all works out.My question is there any recommendations out there for a sharpening system that's best for all tool types, certainly not carbide, that will serve me well for years to come? (i.e no other adapters or add on parts later for certain tools.) Also what's the best option for a grinding wheel? Maybe I should say less expensive best option. I have both an 8" and 6" grinder already. I would rather buy a system for the 6" grinder unless there's an advantage to having on an 8" grinder. Hopefully these aren't dumb questions and thanks in advance for the help!!Bryan Report
4 hours ago4 hr comment_382970 Hi Bryan and Welcome to the Patriot! I'll try to answer some of your questions and I'm sure our other turners will be along shortly with more information!Probably one of the most popular sharpening systems is the Wolverine sharpening setup-https://woodturnerscatalog.com/products/oneway-wolverine-sharpening-system-4-piece-sethttps://woodturnerscatalog.com/products/oneway-sharpening-essentials-6-piece-set?pr_prod_strat=e5_desc&pr_rec_id=a01e288ef&pr_rec_pid=6921692971031&pr_ref_pid=6921693429783&pr_request_id=09cd4b2c-1038-4551-8b54-807ae9197208-1795189537&pr_seq=uniformThe 8" grinder setup will create a slightly less concave grind on diamond parting tools and the underside of gouges. A slow speed grinder will create less heat when sharpening. "White" wheels are good for sharpening although the CBN wheels are also popular and remove less material from the tools but they are more expensive. Here's a source if you want to go the CBN route-https://woodturnerswonders.com/collections/cbn-wheelsHope this helps. If you have any questions about the site, let me know!Watch for our Wednesday’s Wisdom For Woodturners. We are always looking for projects, ideas and suggestions. Please jump in and tell us what you think!Lew Report
4 hours ago4 hr comment_382971 Welcome to the forum! As a not-so-good turner (I've been a hack for longer than I care to admit, and too long to consider my self a beginner) I settled on the wolverine system Lew described for my turning tools. It makes getting repeatable results a lot easier. I use an 8" slow speed grinder with mine, though I think the system works with a smaller one as well. That said, I do my skew chisel and scraper free hand, using the Wolverine platform (as opposed to the Vari grind which is useful for gouges and such). Report
3 hours ago3 hr comment_382975 Bryan,I purchased the Pro Grind Sharpening System for 8 Inch Benchtop Grinders and since then I’ve had a bit of love / hate relationship with it. I did end up ordering a ONEWAY Wolverine Vari-Grind Attachment to go along with it. The pro grind works good as long you like the preset angles. The vari-grind gives you more options but cost a little more.You might also want to invest in a CBN Grinding wheel, another purchase I don’t regret buying. Edited 3 hours ago3 hr by Gordon Report
3 hours ago3 hr comment_382976 @Gerald @RustyFN @Steve Krumanaker @Headhunter @timbertoes @Gunny @calabrese55 @FlGatorwood @Bob Hodge Report
