One small flaw
just last week, i carefully glued up some wood to make a recipe box for my wife.  had the length measured, with some excess, so i could cut the sides and have the grain chase around the corners.  then time to cut the sides in sequence.  first three went great...uh oh, last piece looks a little short.  re-measure....crap.  set the fence wrong, every piece was too long.  had to start over from scratch.
this was the result of attempt #2.
even this piece has a few mistakes, but it's going to have to do.
  • Replies 71
  • Views 7.2k
  • just last week, i carefully glued up some wood to make a recipe box for my wife.  had the length measured, with some excess, so i could cut the sides and have the grain chase around the corners.  then
  • steven newman
    steven newman
    Used to have a 2-1/2 car garage as a shop...with a woodburner for heat......never made a mistake, just made more heat   Reason I tend to work so slow nowadays.....avoids the mistakes from ha
  • Age diminishes my speed but, not the quantity of mistakes. However, the mistake quality may have improved. But, that may just be my aging eyes...or, my attitude.
Looks great from my house, DAB. Love that wood. What is it?
Wormy Maple, AKA Ambrosia Maple, from the Ambrosia Beetle that infests the trees and causes the stained wood.  if you look closely, you can see the little round holes where they had bored thru.
That is absolutely gorgeous DAB...should get you a few extra points.
What finish are planning to apply?
Good Job,Dab, Love that Maple.
Herb
Dab, that's excellent work. I made a j-box using wormy maple. I used BLO and shellac t finish it.
hat
that has 3 coats of minwax gloss poly.  it's done.
SPLINES! (I know what they are now! Thanks Stick)
oh, yeah, those.  those are made out of walnut.  7/64" thick (because my TS blade cuts a kerf that is 7/64" wide, and i didn't feel like changing blades, so i used my Incra fence adjustment to cut 7/64" thick Spline stock.).
I do like Incra products, when I can afford it. (Or even when I can’t, but buy it anyways LOLOL, but that’s another story for the Missus to tell LOLOL)
If in doubt...
ask...
 Some of my flaws/goofs...........only me and God know about
That is a beautiful little box there Dab.  Should go great with that kitchen cabinetry.
If it ain't broke, don't fix it til it is...
Nick, drop the "don't" and, there are a lotta guys that can relate. :throbbinghead:
I have (and still am) learning to listen to that little inner voice that tells me I have made this mistake before and therefore STOP!! Any other listeners?
hat
YES!
8 hours ago, Woodbutcherbynight said:
YES!
+1000
Yup, BTDT...
You hear them too? I was worried I was the only one hearing those voices in my head.:BugEyeSmiley:
