Delta 50-760 Dust Collector, 1&1/2 Hp With 2 Nd Stage
1. I'm in a one man hobbyist wood shop.
2. I'm cheap, tight, beyond frugal.
3. I'm lazy. Perpetually in energy saving mode.
4. I only know how to use the +, -, and ÷ functions on my calculator.
My 2(?) HP HF DC with a cheap trash can chunk collector, all vented to the outside, satisfies my 3 major requirements: It requires minimal space, there are no bags to empty and, it sucks good.
  • Replies 115
  • Views 13.3k
  • 1. I'm in a one man hobbyist wood shop. 2. I'm cheap, tight, beyond frugal. 3. I'm lazy. Perpetually in energy saving mode. 4. I only know how to use the +, -, and ÷ functions on my cal
  • John Morris
    2 hours ago, CharlieL said: Sounds like a thankless job. It is a thankless job, there is no reward in being a forum host here, except for your own happiness in helping others.
  • 2 hours ago, John Morris said: It is a thankless job, there is no reward in being a forum host here, except for your own happiness in helping others. I tried. I'm done.
Gene,
What no quadratic equations! :huh:
4 minutes ago, Larry Buskirk said:
Gene,
Naw, I'll let those who lost it, try to to find that elusive "X". If it wants to be unknown, who am I to judge.
No, we are working with wood, not making time machines or inventing the warp drive.:JawDrop:
  • 2 weeks later...
Not only did I spend time puting together a good efficient DC for my situation, I've designed and built with sheet metal what I think are more efficient dust hoods then what is out there for some of the machines that I own. Delta Contractor's table saw, JET 6" jointer, and a Delta thickens planer.
Edited by CharlieL
Charlie are you using metal, plastic or wood or some combination of those. I have done most of the ones I have made in wood but also used some plastic inside to make the friction lower and create a slanted surface.
 All the dust hoods that I made are made with sheet metal. I have one I made with wood and metal just to see how it would look, I think that it turned out pretty well, but I still continue to build them strictly out of sheet metal.
Edited by CharlieL
I had thought about this during my twin TS build but opted for the look and convenience of staying with wood which I had on hand.  I did not use DC or have any hook ups for the TS.  Instead I went with drawers that can be emptied when full.  NOT a perfect solution, but it works.
Why do I even bother mentioning it? Just call me stupid, I should know by now that it only leads to disappointment for me.
Edited by CharlieL
Because someone else might look at the blog and say, hey this guy suggested this and used it this way.  But this other guy had different problem and used it this way.
The sheet metal idea is solid, it works, others have used it as well.  The whole point of discussion is a sharing of ideas, tips and suggestions.
You mentioned dust hoods, how about some pictures and explanations of what worked and what gave you trouble.  Not everyone is comfortable working with sheet metal.
I used sheet metal because I think it's appropriate and can be grounded. Plus stupid me was hoping that others would want to support a fellow woodworker and buy some hoods from me. The first hood I made someone else copied it, but made it from wood. He claims that it may not be his design, but he still takes credit from people for it. Because of that I am leary of showing alot.
Edited by CharlieL
It looks like someone deleted a post of mine that was right here. So much for freedom of speech.
Edited by CharlieL
Charlie, I'm not sure whether you have a burr under your saddle or not but it comes across that way, at least to me. These forums allow us to share ideas, and someone copying or duplicating said ideas is considered (again, by me) to be an honorable thing. I've never expected to be rewarded financially from this, the rewards comes from helping others. As for a post disappearing...no idea, I've been following this thread and don't see one missing, but then maybe it disappeared before I got to it. John does address the freedom of speech sentiment in his introduction to the forum....basically if it's offensive it's not allowed. But I've not seen useful information go poof.
I've learned a bunch from this and other forums. Made some great friends, too. The overwhelming majority of woodworkers are generous, helpful folks.
Nothing has been deleted, I have not deleted anything. As a policy we do not delete anything. What we do do though is hide offensive posts for Admins to review. And we leave those hidden posts up indefinitely for future use if required. I do not see any posts on this page that another admin has hidden.
I'm pretty sure the post was never put out, and if thats the case I have a pretty good idea as to who it was. As far asa sharing goes, I would be more inclined to be honored if the guy gave me credit for the idea. The other thing I don't care for in some of these forums is once you post something after a short amount of time there is no going back. There is alot that I wish I had not shared. Perhaps starting my own website where I can control my posts better. It should be up to me to decide what and when I want to share, not anyone else. And if you don't want to support me, fine, but don't expect me to feel motivated about much here.
Edited by CharlieL
as you wish.....but with a negative attitude your own website may just have only one participant. Regardless, I wish you the best. That's about as much as I'll provide in support.
Edited by Fred W. Hargis Jr
So be it.
Oh well, my next project I'm thinking about adding a light inside a old benchtop Eastwood media blasting cabinet. I'm checking out to see what the retailers have to offer now for size, efficiency, and cost. Then I'll go from there. I need to clean or replace the protective window film inside also. Dust collection to keep the air clear I think I have pretty much figured out. Should be a fun positive experience like most projects are, until the unappreciative get envolved.
It's impossible, first off, we don't sit here and babysit posts all day long. And we can't see posts before they are submitted, physically and technologically impossible. We see the posts just like everyone else here, not till you click on "Save".
Charlie, the little green men don't exist in this community, you'll have to look elsewhere.
