Showing results for tags 'glue up'.
Found 3 results
  1. The latest chapter. (BTW, I had spinal surgery yesterday and "avoid strenuous activity for 6-8 weeks. All my Xmas projects are done, so you might see more of my posts here). Why do people think dowels, dominos, or biscuits are necessary for edge-to-edge glue ups. I can understand some assistance in alignment when needed but there are other ways. Dowels, in particular are fussy with alignment and don't add strength. Dowel joints are not very strong. I read a FWW article years ago about why. Boiled down to two reasons: minimal glue surface, most of which is end grain and differential expansion of wood. I have reglued dozens of chairs where once I removed the corner blocks, the pieces just pull apart. Why is a miter saw on the top list of things for a newbie? Unless you are doing construction or on site work, you can do most anything with a table saw. And it has limited types of cuts it will make. Unless you do a lot with sheet goods or live edge planks, ditto for a track saw. Why do people put so much glue on that there are puddles of it running out once clamped.
  2. I have 5 pcs of 1-3/16” hard maple laying on my TS and max. mismatch measures 0.025” in the center when I added clamps to the board ends. The longer boards are 60” long. Do I need to use biscuits between each board for glue up? The two ¾” cherry strips are already glued to the center board. Danl
  3. steven newman
    finish is on 2
    From the album: Pine Chester Drawers
    View at the top. This was a glue up of two 1 x 10s. More coves.
