Showing results for tags 'butcher block'.
My son asked me to build for him an additional cabinet for his kitchen and he is wanting a butcher block countertop. We are still working out the design, but we know that the box will not exceed 40x21. I know that I can make a top for him put I was wanting to look into the options of purchasing one. I went to a low end kitchen & bath outlet today and they would sell me a 36" x 86" finger jointed top for $229. They do not sell smaller pieces. I assume it was maple. They had a stack of them and the top one was cupping. Home Depot sells a maple 25" x 60" top for $339. Grizzly Industrial has Beechwood finger jointed work bench tops. 1-3/4 x 48 x 25 sells for $124 + $100 shipping. I would appreciate it if you would share your opinion(s). thanks Danl
Greetings all. Quick question here ( I hope). I am building a butcher block rolling island for my daughter (which many of you helped me with in the design stage). During the thickness planing stage on the butcher block top, I got a couple small tear out spots which are too deep to sand out. I was thinking that I could fill the depressions with some epoxy. I have never had to use epoxy and am looking for any suggestions any of you may have as to any preferences you may have. Don't need more than a tablespoon so no large quantity needed. And will epoxy take mineral oil "finish" ok? Thoughts? And as always, thank you in advance for any assistance. Gary
- 11 replies
- butcher block
- filler
(and 1 more)
The Kitchen Island made of solid maple was delivered to Naples, Florida and installed this past week. I got a picture over the weekend showing it on the top of the Island. Always worry when I am doing a job and have not been to the location and using someone's measurements, but in this case it looks like it was a perfect fit.
- 6 replies
- butcher block
- maple
(and 2 more)
I started a few days ago on the Kitchen Island top out of Maple. I went over to the Wood Stash and got enough maple to bring to the shop and start working on. The top has to be 41"x51"x2". I got all of the boards cuts a little over size and ready for the jointer Ran one side across the jointer and ready to run through the planer. After it was run through the planer I stacked it all and put some clamps on it to just check my size and be sure I was going to be okay to start the glue up. That is going to be one large Island top. So last night I was looking at either gluing it up in three of four glue ups and them putting those together. So those are the three panels and I am thinking I am going to do it in four just to give me more working time and make it easier to pull them tight together. I should get them glued tonight or first thing in the morning. Well it was Thursday Morning before I got the panels glued. I decided to glue them into four sections and I am so glad I did. Once the clamps were on there it was almost too heavy for me to lift off the assembly table. Also to glue up all for sections has taken almost a gallon of Titebond III glue. 1st Panel 2nd Panel 3rd and 4th Panels It will most likely be Saturday morning before I start gluing the panels together. I think I will glue two panels together and then when they are dry, glue the two sections together.
- 5 replies
- hand made
- butcher block
- (and 4 more)
