Shop Electricity Issue
Well for a few weeks now I've been having a issue with my electrical wiring in my shop. When I used my table saw I could use it . But if I turned on the dust collector with it the breaker with flip off. If I used more than one thing at a time same effect. So I needed to have someone to come and put in a 220 outlet anyways so that I could use my new band saw. The guy I hired found that some of my old wiring was going bad and shorting out. So we ran a line from the house into my shop and installed a breaker box in my shop . Replaced most of the wiring because the guy who lived here before didn't have them grounded and some were really old and bad. So now hopefully I can get some woodworking done without tripping the breaker. Only thing is I probably don't want to see the bill from the electrician .
  • Replies 47
  • Views 5.2k
  • Fred W. Hargis Jr
    Fred W. Hargis Jr
    Ya' know, some folks think that about Satellite TV signals as well.
  • The ones behind us sag a lot between the supports. I'm guessing that at their lowest, they're at about 30' off the terrain. I've walked under them and the hair on my arms feels like they're stiffening
  • Larry Buskirk
    Larry Buskirk
    I had that, and cable shut off about 5-6 years ago. I still get at least 3-4 offers per month to come back.  I love the look on the sales people face at Best Buy, etc. when they give us thei
Glad you got the problems straightened out. A breaker box in the shop should allow the addition of new circuits, when needed.
Glad you got it worked out. Electrical problems are not fun and can lead to some serious issues.
Wow Mark. It sounds like you have avoided a fire or a serious shock. It may be expensive but was clearly the right thing to do.
That's great. Nothing more annoying and dangerous than unreliable electrical wiring.
Glad you got it done.
Getting someone that knows what they are doing is worth the price. It might seem expensive now, but what could have happened could have cost a lot more.
Glad you got it cleared up.
I had to re-wire my shop when I bought my place. The person that ran the circuits used black as the hot sometimes and white as the hot others. The best thing was pull it all out and start over.
Now you can really enjoy those new tools.
no how you feel,still trying to find electrician to redo our house,myself i can do wiring but would need to call 911,for them to get me down out of attic,haha,but i hea done the wiring in my shop is great to have a Dad who was a Electrician and showed me how to do it.
What kind of wiring did you have before? Aluminum? Alum wiring is a terror.
I'm blessed that my father was an electrical contractor. Electricity and wiring is second nature to me. Sometimes it's a curse and sometimes it's a blessing.
I had really old copper wiring that was not grounded and was falling apart. But we got it fixed.
I had a house in MASS that was still wired with Peg and Post. There was a really bad ground fault in it somewhere that made a large hanging loop of wire heat up to glowing in the attic. Over the years the heat had caused it to hang lower and lower and of course as the loads increased over the years the heat increased too.
Imagine my surprise when I was in the attic one evening and I saw a reddish stripe looping in the dimly lit space.
  • 5 years later...
Talk about electrical problems.... I'm an electrician and WOW did I have
a problem... While I was wiring my wood work shop I bumped my arm
along side of my pallet racking and I got a shock. I stopped working and
got my meter out. I had 63 volts between the receptacle and my pallet
racking. The wire that went from my receptacle to the breaker box was
not even hooked up...? After two weeks of tracing down what the problem
was I found out my pallet racking was producing the 63 volts. Some how
the pallet racking's working like a large antenna and pulling in the voltage.
It's been 5 years now and I still have free electric from the racking. Who
knows where it's coming from. The racking is on the second floor of the
shop and it's touching but the old wood floor. It's got a lot of other electricians
scratching there heads. Never seen anything like it...
Yikes!
I believe your somehow getting the electricity through a nail in the floor that is in contact with wiring from below, and the pallet racking. Possibly a ground loop condition.
That was my thought exactly... That's why and how it took me two weeks to find
where the electric was coming from. At the end I had unhooked the power source
that was 1000 ft away coming from another building. I took the feed wires all the way
out of the breaker box so it was not even touching anything. I then drove a ground
bar in the ground under the barn under the pallet racks and ran a wire up to the
pallet racking and got my 62 volt reading from that wire off the pallet racking.
No electric was hooked up to the barn. ???
@Kevin Beitz,
That would have been my next suggestion.
Do you have nearby high tension power lines?
Is the electricity AC, or DC?
Was this barn used to house animals in the past?
Could be an electro-chemical reaction between the acids/salts in urine, and other items.
63 volts is half of line voltage. Had similar issue and found a pinched wire at the metal box connection. Seems someone cranked down on it alot!!  Now this box was across the room from where I had been working on a new outlet.  Had same 63 volt reading. Fixed issue no more problems.
Might never have gone noticed but I had hooked up the ground wire at new duplex. Former a single outlet. Someone was lazy and never hooked up.
I'd keep looking. Maybe a wire is hidden you don't know about that supplies power to shop. Or underground and goes elsewhere.
Not knowing your situation, I’m just speculating. I would start by turning off my main breaker/disconnect and then seeing if I still had the 63 volts. The known facts would say it would have to go away if there was no electricity entering the building. If there is no electricity entering building and 63 volts is still there, contact MIT and get them to discover new energy source. Make sure you get 50%. If 63 volts goes away, turn main/disconnect back on, and start turning off sub panels/individual breakers until the single circuit source can be identified. Then the real fun stuff starts, as you try to trace out the circuit and see how it is getting there. Pallet rack is ?? Is this just a wooden support that empty pallets are stacked on? Be interesting to see how much capacity this power has. Can it keep a light bulb lit? Are you in a rural area? Power lines overhead? Ungrounded metal piping in building? This is very interesting, I hope you don’t mind keeping us posted on developments.
I looked it up, your town is a little less than a 6 hour ride from my town. If I gotta take that trip in the interests of science, than so be it. LOL I don’t believe in ghosts, goblins, or free electricity. There’s gotta be an answer.
There is no main breaker/disconnect... All electric was remover from the building...
The electrical supply started from my home down under the highway to my shop.
Out of the shop under ground to my barn wood shop. I took the wire all the way out of the main breaker box and also shut off the main at the house. Like I said I have been an electrician for 50 years. I worked with industrial 3 phase electric. Playing with electric is also one of my hobbies. This is one of the last toys that I built.
