August 5Aug 5 comment_379689 Our Summer raffle/fund raiser was successful! We reached our goal and are waiting for the winners to contact the boss about receiving their prizes! Pleas check this post for the list of winners and how to obtain your prizes.Our Patriot Turners-Member @Bob Hodge added to our "What's On" post with a beautiful bowl! He turned this from a yew root ball. The colors and grain patterns are fantastic!Check Bob's post for additional images and comments-Bob also asked for some ideas on how to get a flat bottom on the inside of a bowl or platter.Please see his post and offer your ideas.@RustyFN posted his latest bowl from a board. I think this is his best one yet!See Rusty's post and check out the comments from our gang!Long time member @Steve Krumanaker works with local artisans and helps them create products for their businesses. Steve turns and embellishes a variety of items. One of his specialties is jar lids.Check Steve's post for pictures of his amazing work!And, check this link for one of the places you can find his work-https://www.facebook.com/CindysBeeHiveLast week we mentioned that "HandyDan" passed away. Dan was the master of using multiple materials to create his projects. As a remembrance, @DuckSoup bumped one of Dan's tutorials on making inside-out turnings. Check it out-What's Coming Up-Registration link-https://community.woodturner.org/events/event-description?CalendarEventKey=4cc5105b-0987-4e18-beba-019f80948e2c&Home=%2fevents%2fcalendar&_zs=ceDib&_zl=pb555Registration link-https://mawts.com/From Cindy DrozdaRegistration link-https://www.cindydrozda.com/From Tod Raines at the Woodturning Tool Store"I will be using my spindle gouges this Friday on my free live stream as I create a Small Bud Vase. I will likely add some color to project. Join me on Friday afternoon (1:00 PM Central US time) for the live stream."Registration link-https://streamyard.com/watch/3uxAdBS3Mhjv?omnisendContactID=6965451f10a273e815a3a1d1For The Newbies-As mentioned, above, Tod Raines is doing a live feed using spindle gouges. For safe turning, it is important to understand the difference between the various gouges. Even in a common category of gouges, there can be differences. This is a repost from one of Tod's newsletter-The spindle gouge is an indispensable tool for woodturners. It is designed for detailed work on spindle-oriented projects, where the wood fibers run parallel to the lathe axis. While it can also be used for certain side-grain tasks, such as adding details to bowls and platters, its primary strength is spindle work. Although it may look similar to a bowl gouge at first glance, the spindle gouge’s unique geometry and bevel characteristics provide the precision needed to turn elegant beads, coves, and fine details. The Traditional Geometry of a Spindle GougeUnderstanding the geometry of your spindle gouge provides insight into its best uses and is the first step toward cleaner cuts and fewer catches. Unlike the deep, robust flutes of bowl gouges, a traditional spindle gouge typically features a shallower radius flute milled from a solid round bar. This radius flute can be milled to different depths, creating either a shallow or deep flute. Standard Spindle Gouge vs Detail Spindle GougeWhile both tools are designed for woodturning between centers (spindle turning), the difference between a standard spindle gouge and a detail spindle gouge comes down to geometry. The depth of the flute directly impacts how the tool handles detail work and material removal on spindles. For example, a shallow flute offers better support for delicate beads, while a deeper flute excels at clearing waste in tight areas.. The way the steel is machined changes how deep the tool can reach, how tightly it can turn, and how stable it feels on the tool rest. Flute Depth and ShapeStandard Spindle Gouge: Made from round bar stock with a deep flute milled into it, leaving less steel beneath the flute. how deep the tool can reachDetail Spindle Gouge: Made from round bar stock with a shallow flute, leaving more steel beneath the flute for added rigidity. Why You Need BothThe standard spindle gouge is a versatile workhorse for any woodturner. Whether you are shaping stool legs, crafting tool handles, or roughing out spindle profiles, this tool removes wood efficiently while leaving a high-quality finish. Its narrow profile provides the precision needed to access tight areas where larger tools often struggle to fit.The detail spindle gouge features a shallow flute, resulting in a narrower profile when milled from the same diameter round bar stock. This design keeps the side wings less obstructive, significantly reducing the risk of catching an edge. Applying a steeper 30-degree bevel creates a sharp, narrow tip ideal for intricate work and fine details. Furthermore, the increased mass of steel beneath the flute allows the tool to extend further beyond the tool rest with less vibration than a standard spindle gouge. Spindle Gouge: Mechanics of the Cut· Cove Cut: This scooping maneuver is performed by advancing the tip with the flute closed, then swinging the handle laterally while rotating the flute upward to forge a smooth, concave profile.· Bead Cut: Creating convex forms involves a rolling motion, necessitating a synchronized handle swing and flute rotation from an open to a closed orientation.· V-Groove Cut: Essential for defining sharp indentations or initiating a bead. Execute this by plunging the tip straight into the wood with a closed flute on both sides of the center line, producing the crisp visual boundaries required for high-end spindle work.· Paring Cut: These fine finishing passes are made directly across the end grain to square off blanks or establish clean shoulders. A razor-sharp edge is mandatory here to slice fibers cleanly, ensuring a professional surface free of tear-out.· Boring Cut: By plunging the gouge into the end grain, it functions similarly to a traditional spoon bit. This technique is particularly effective for establishing starter holes or deep recesses in projects like vases, boxes, or lamp stands. A Note of the Spindle Roughing GougeThe spindle roughing gouge is a distinct category of tool dedicated to transforming square spindle blanks into cylinders. While it can be utilized for sweeping coves or large beads, its use is strictly limited to projects where the grain runs parallel to the lathe bed; it should never be applied to face-grain or bowl-oriented work.Final ThoughtsMastering the spindle gouge begins with understanding its geometry and how that geometry affects control, stability, and cutting action. It is primarily a detail tool for spindle work, featuring a steep nose angle and shallow flute for precision slicing. Ultimately, complete mastery may require both the standard spindle gouge as the workhorse for general shaping and material removal, and the detail spindle gouge. The detail gouge, with its exceptional rigidity and acute point, is essential for reaching into microscopic gaps, turning delicate finials, and executing tight, crisp lines where the wider standard gouge would fail.A Note on Manufacturer DifferencesIt is worth noting that manufacturers often maintain a fluid distinction between these categories. Every maker implements their own specific vision of what constitutes a standard or detail spindle gouge. Consequently, you should carefully examine the machining of each individual tool and apply it as you see fit. Ultimately, recognizing how a tool is manufactured provides the essential insight needed to maximize its performance within your own workshop and on your woodturning projects.Richard Raffan uses the spindle gouge to create beads-Tommy Tomasic has some tips to help you become a better turnerA very informative but rather long video from Tim Yoder on the processes involved in turning a tree into a bowl.Expand Your Horizons-First of the month and the 4-ways collaborators are making a cake stand.Stuart Batty has the next installment of negative rake scraping-You may have heard that Sam Angelo's YouTube channel was hacked and completely wiped. Sam was not able to retrieve any of the thousands of videos he had created. Sam is back with a new channel. Check it out and maybe subscribe.Turning Time With Easy Wood Tools-Some turners using Easy Wood Tools this week-Shared by Jet Toolshttps://www.instagram.com/p/DblRA0nAubQ/?utm_source=ig_web_copy_link&igsh=NTc4MTIwNjQ2YQ==JPWoodwork uses EWT tools and does a really neat paint finishEasy Wood Tools Demonstrator locations for next week-https://www.woodcraft.com/pages/store/orlandohttps://www.marksmachinery.net/https://www.woodcraft.com/pages/store/parkersburghttps://www.nevadacountyfair.com/https://www.woodcraft.com/pages/store/raleigh@Jordan Martindale New Turning Items-Sales this week-From Trent Bosch-More here-https://trentboschtools.com/Rikon sales from Highland WoodworkingMore Here-https://www.highlandwoodworking.com/collections/rikon-tool-saleEverything Else-Safe turning Report
August 6Aug 6 comment_379696 I agree with rusty, that's a shame that Sam lost everything in that attack and it's good to see his back up and running. Report
August 9Aug 9 Author comment_379816 @RustyFN Thanks!@Fred W. Hargis Jr Thank you!@Gordon Thanks!@Gerald Thank you! Report
