Shelf lengths for inside cabinet
3 hours ago, JIMMIEM said:
Well, it has a maximum range of 165 feet.
Well that is faster than a 3/4" steel nut on a srtring.
Herb
  • Replies 52
  • Views 24.2k
  • Couldn't agree more.....just check out Stick's food recipe encyclopedia. Those are some serious recipes. When Stick invited me to join this forum he said that you folks would be a good resource t
  • To determine the length of shelves, a two piece story stick is your friend.
Herb
Plus you reel in the laser line at the touch of a button.  I'm going out on a limb here but I'll bet it well take a lot longer to reel in the string.....unless you tie it to Lassie and have somebody call her (I believe Lassie was a female) for supper.
On 9/28/2018 at 9:06 AM, smitty10101 said:
For internal measurements I use a regular carpenters folding rule with the slide out on one end.
Of course you must add the two measurements together for the final length.
Guess I'm just old fashion ----or too lazy to make a story stick (or both)!
I'm a klutz. Tried the folding rule and slide out thingie. It's too easy for me to bump the slide out thingie, either as I take it out of the cabinet or using it to set the fence or stop block.
I just want the actual physical length. Couldn't care less about the numbers.
Wouldn't help me likely...I'd probably sneeze or something and drop it in the well.:blink:
Well, at least Timmy would have entertainment until Lassie got there to rescue them both.:lol:
Forgot to mention, the tool has a strap that you can put around your wrist....they must have read your mind.
Very scary place to go:P
 Set a yard stick on the work bench and measure the length of the stick rule.;)
@DuckSoup, thanks but, no thanks. But, I do appreciate your reply.
Using my story stick I go from the cabinet, box, etc. directly to the saw. No intervening steps involved. AND, NO NUMBERS :excl::lol:
 A story stick never lies.
Very true. Honest as the day is long.
Honest as George W.
Herb
2 hours ago, Dadio said:
Honest as George W.
Herb
Washington?
5 minutes ago, Gene Howe said:
Washington?
I assumed that's who he meant...he was an early woodworker. Worked primarily with cherry IIRC.;) I wasn't sure about any others named George W.:rolleyes:
Edited by Grandpadave52
Or was it Honest Abe?
I've heard he had wooden teeth, also. No word as to whether or not they were cherry.:lol:
Actually, his dentures were made with sheep's teeth! Apparently those are the closest to human teeth.
John
John
Baaahhh!
9 minutes ago, Grandpadave52 said:
Baaahhh!
Ewe beat me to it, he said sheepishly. :lol:
