Clinometer
I'm sure many of you all are already aware of this cell phone app. But, this old luddite wasn't. To me, this is an amazing piece of gadgetry.
https://play.google.com/store/apps/details?id=com.plaincode.clinometer&hl=en_US&referrer=utm_source%3Dgoogle%26utm_medium%3Dorganic%26utm_term%3Dinclinometer+app&pcampaignid=APPU_1_1s1HW-G5OqmpjwS047fQAw&rdid=com.plaincode.clinometer
What's really funny is that I downloaded it to my Kindle hoping to use it. But, when I hit install, nothing happened. I was sorely disappointed. Later, I picked up the cell phone to find that it had been installed on it. I never did nuttin to tell it to do that. Phenomenally scary.
Anyhow, since I gotta tilt the SS aluminum table for edge mitering, the clinometer is the bee's knees. Far easier to use than my Wixey.
Edited by Gene Howe
  • Replies 53
  • Views 4.1k
  • I see I am either in need of buying a phone or I am going to have to start carrying my Wixey with me.  I guess being "one bubble off" isn't cool anymore.  Who knew?
  • 1 minute ago, Stick486 said: make it a 6 or 8 footer and call it a staff...   Then I'd have to buy some sheep.
  • 2 hours ago, Gene Howe said: Yep. Do you mean drop it on the concrete floor first and pick up everything but the case? Herb
I was googling clinometer to see if there was a physical unit to buy and that app popped up. A freebie, too.
Ain't technology sumpin?
Edited by Gene Howe
Thanks Gene...I looked...when you downloaded it, it didn't install on my phone:rolleyes: so I will.:P Were you wearing your aluminum foil hat? Maybe that's why it went else where? :lol:
Never thought to check for a Clinometer app. Looked at some for calculating board feet, but most of the reviews weren't so hot. Good post!
Hey y'all know there is a similar device already on an iPhone in the compass app. Just open Compass and slide screen left and there it is . No bubble though , just the angle.
   Not only that you can lay the phone flat and it will tell you the angle on the surface and even float left and right like a bubble.
Edited by Gerald
...but there is a iPhone app called "Handy Level", as well as several other "Handy" apps including an inclinometer.
And, I thought a flashlight and camera app were revolutionary.
My OCD requires me to make sure that: pictures hang straight, that shelves and doors hang level, etc. I don't always want to go get a level to fix the problem.
I, also, have a compass app on my iPhone. Don't ask me why, it is totally useless, since I am usually going in several different directions at once! :D
Wow!  I found this on my phone - so cool.
Just for sport I set it on one of the stair sub treads.  0* left to right, -1* front to back.
Now, anyone know of a similar app that would measure the angle on the miter saw, fence to blade?  I have tried all sorts of things with my Wixey, without finding the means to do it.
Didn't you just answer your own question? ...use the app on your phone for a quick reference. I find the app to be really accurate...
I don't know Bill, I will try that though.  All I know is that I could not figure out a way with the Wixey.
@Cal try this
"Handy Level" can indicate angle in degrees and RADs. The "Compass" app doesn't do that. Handy Level will do basically the same thing as the Wixey cube.
2 minutes ago, schnewj said:
@Cal try this
Let's see if I can help clarify a little...
On a miter saw; lay the phone against the fence and the blade along the adjacent side. Now if you move the blade the angle should read as long as you keep the phone against the blade.
Ooops! Sorry Cal, that didn't work with either the compass or Handy Level. My bad!
There has to be a way...
and proceed to cut the phone up...
I have to run...but...
Look at these and see if any of them will work for you...
http://appcrawlr.com/ios-apps/best-apps-angle-finder
A low tech way to set the angle on the MS is to use the Miterset segment set to cut a piece of 1/4" or 1/2" ply on the TS to the desired angle and, use that to set the MS.
I have several angles cut for my most used MS settings.
Then, for the more affluent among us, there's this doohicky.
The better ones can cost around $130.
I gots one of those...
and doesn't flutter or need recharging or batteries...
works over a larger surface for a more uniform measure...
great for copying/measuring/transfering angles
