Bandsaw Issues
11 hours ago, Josh woodworking said:
Hello all, I am trying to help my neighbor find a replacement shaft for his craftsman band saw,
Manufacturer: Craftsman
Product Number: 69058
I have had not found any parts online keep getting the same feedback out of stock and unavailable. Any suggestions where to purchase or how to go about machining? Thank you, Josh
https://www.ebay.com/c/1123929017
  • Replies 42
  • Views 8.8k
  • steven newman
    steven newman
    Well, since it was still the 12th, and not the 13th....decided to test the motor to see IF it even runs....extension cord, so I could unplug it fast, if need be......   Plugged it in, right
  • I ended up here when searching for part 69058, the lower spindle shaft for my older  (113.243310) 12" Craftsman bandsaw.  If you also are here, you've probably found that the shaft is no longer availa
  • steven newman
    steven newman
    Ok, an update on the saw.  Priced a new pulley at TSC today....1/2" bore, 3" diameter, no keyway slot....~$12-$16....did not find a new cord for the motor,,,,but, since the old lathe was junked o
I found the manual, but no luck with the lower shaft so far.
http://www.vintagemachinery.org/pubs/detail.aspx?id=4586
Could check with Emerson Electric Co., they manufactured the saw for Sears.
Edited by Larry Buskirk
  • 2 years later...
I ended up here when searching for part 69058, the lower spindle shaft for my older  (113.243310) 12" Craftsman bandsaw.  If you also are here, you've probably found that the shaft is no longer available anywhere, but the bearings are available. I realized, however, that 5/8" shafts with 3/16" keyways are readily available - Grainger or McMaster being the best sources.  The 6" length will work, and you'll just be missing the lockring grooves.  These are easily added by chucking up the shaft in a drill press and cutting the rings with a hacksaw - good enough!
