Bessey I-beam clamp question
41 minutes ago, Dadio said:
With the new improved  glues, I have just held two pieces of wood tight for a couple of minutes and let set for an hour and when I broke them apart the wood gave loose and the glue held tight.
Herb
Good to know, Herb. Rubber bands are cheaper than clamps!
John
  • Replies 60
  • Views 8.4k
  • John Morris
    Like Lew stated, as is with most if not all joinery, the two joints should slide together with little effort our just a few taps of a mallet. On rare occasions I have been known though to start W
  • Because you don't have any, now?  Agreed. They're over kill for most shops, though.  Still.....
  • go w/ pipe clamps..
3 hours ago, HARO50 said:
Spread the glue to 3 molecules, then go over it with the shopvac. It will take off the top 2 molecules, leaving the exact amount needed!
John
I just KNOW someone is going to try this! :rolleyes:
It'd be easier to send the spreader back for re calibration.:lol:
John
This pertains to small irregular shaped parts that are hard to clamp. Rubber bands work fine on small boxes with mitered corners. By using blue tape to align the miters, just fold together in a square or other closed polygon and tape the corners ,then put the rubber bands on to apply a little pressure.
When I install small wooden handles on jewelry boxes, I find the center of the box ends and drill a small hole ,not all the way thru, Insert a round toothpick cut to length. drill a hole the same in the handle , put some glue on and insert the handle onto the toothpick and hold for a couple of minutes then let set for an hour. the toothpick aligns the handle and keeps it from slipping when pressed into place.
Herb
  • 2 weeks later...
After many years of woodshop experience I have come to be an avid champion of Bessy style clamps------yes very expensive but if interested in easy and satisfying clamping experience, these clamps are it. It all depends on what is important to one---I found that holding back on some recreational experiences quickly frees up the extra cash required.----- also after many glueup problems that most applications require only modest pressure
Recreational experiences?! For me, that would mean no internet or Xbox 360! I wouldn't be able to talk to you guys or save the world when you guys are safely sleeping!!!
ah-ha!!!
you talk to us in our sleep...
that explains a lot...
can't wait till my psycho babble expert hears that I really am hearing voices...
That was supposed to be 2 different thoughts but that reply sure cracked me up!!!
Don't know if anyone mentioned this but M & T are long grain to long grain joints that are structurally sound when glued together.
If you force fit the tenon into the mortise you force most of the glue out and create a very weak M & T joint.  As others said a light mallet tap should get them to slide apart with that in mind the glue will not be forced out but will properly set up on both surfaces and make the strongest joint (with some argument) that is known to man.
A little saying I read by I do not remember who " fit so that your hat will force it together" , that is a tap from your hat.
Your hat? That is a very light tap...can't think of much of anything that would go together with such a light tap. WOW.
The idea of the M&T joint is that it is rigid and the glue then holds it in place . Driving it together could well lead t early failure by crushing the wood or splitting the mortise.
If you wear a hard hat in the shop, you can give it quite a substantial whack! :unsure:
John
Thanks Gerald, now I understand!
LOL John!!!
Beam clamps work when pipe clamps just aren't enough... In this case pipes were used and most destroyed because the threads aren't strong enough...
  • 3 weeks later...
We ordered 12 -36" and 12 -48" just for parallam tops.
Because Jorgensen beams are no longer anyone compared to Bessey I-beam clamps to Jorgensen?
Wow, Billy. That's a thick slab. Are those 1/2" pipes?
Out of curiosity, what's the application for that glued up glue lam?
That's a chunk of money lying there! I'm curious, too! What is the final application?
BurgerFi restaurant...
  • 2 weeks later...
Nobody ever compared the I-beam clamps?
Wish I could! lol Go for it and report back, with donuts!
