Need some advice
2 minutes ago, Fred W. Hargis Jr said:
I'll try to check that out when I'm in Menards later this week.
Looks like they would be suitable for outdoor use but it didn't really specify. I assume you would just screw down with coated screws to prevent rusting and screw between the nibs.
Not sure how easy it would be to remove ice. All to consider, but seemed like it might be a viable solution.
  • Replies 40
  • Views 3.7k
  • Michael Thuman
    Michael Thuman
    The other thing I have always done on the front of the stringers away from the wall. Add a recessed peice where you can put fasteners down between the stringers.  That way if they want to spread away
  • Fred W. Hargis Jr
    Fred W. Hargis Jr
    OK, this project got set aside when the drywall guys showed up (early, thank goodness), and then several other things interrupted any progress I might have made. So with the warm spell we're having I
  • Chips N Dust
    Chips N Dust
    What I have used for non-skid was paint, then while still wet, drop some ground up nut shells onto. When paint is dry, apply a few more coats. I used this on the platform my dog rode on on the back of
