Showing results for tags 'wood plane'.
Found 5 results
  1. Zack
    Wooden plane
    Wanted to show off the Christmas gift my crew at work got me. 26” wooden jointer plane. Complete with iron, chipbreaker and wedge. Needs a little work to get it back in shape but pretty sweet. The iron shows Providence Tool Compay and is bimetal, cast iron to carbon steel. Not sure if it’s original to the plane but it’s about right for the period.
  2. "What's It" Basic Rules Reminder For a full run down on this project and rules please go to: "The Patriot Woodworker and MWTCA "What's It" project" Only Patriot Woodworker Members are eligible to participate and receive the award. The MWTCA only accepts a verified source to support your answer, so one should be submitted with your answer, such as a patent, catalog entry, tool book reference, or a respectable website on the subject. Do not let these requirements prevent you from having fun and submitting educated answers on the subject without verification, we can worry about references later. All answers are welcome, as well as healthy debates regarding "What's It". If a verified and referenced answer is not arrived at by the end of each month's "What's It" project, a random draw will be performed for a "One Year MWTCA Club Membership". Only Patriot Woodworker's who participate in this "What's It" topic will be included in the random draw. Additional What's It Rules Unless you are completely sure what this item is, please avoid "definitive statements" that appear that you are without a doubt claiming that you know what the item is. For example stating, "this item is called a "widget xx" used for "insert purpose here". If you are making a definitive statement you must accompany your statement with evidence or proof from a secondary source. An example of acceptable statements within the realm of having fun and educated guesses would be something like this, "I believe it could be", or "It appears it's made for this or that", etc etc etc... Ok ladies and gentlemen, we now have our "What's it" live and ready! The image(s) below is a MWTCA "What's It" image for you to research, and tell us all here in this topic post, just what the heck is it! Project Details The information provided hereon is all the information that is provided, no further information on this item will be added. The tool with a 12 inch (30cm) ruler to give an idea of its size. The reverse side of the tool, perhaps this side creates a groove. Note the curve in the blade.
  3. steven newman
    Ohio Tool Co. #81 (Updated)
    Got the iron back to sharp Cuts nicely, but was hard to hold onto. Saw a place that does refurbs for a living, and they also had an #81.....with a tall knob. Hmmm, well, I can clean off the work bench (10 minute job right there) and drag out the wood lathe, again. Blank of spalted maple was in need of squaring one end, tried to hand saw that. Three different saws.....end was almost square. Fired up the lathe. Plan ( Plan? I don't need no stinking Plan) to turn two bench plane knobs. There was enough room between them to squeeze a block plane knob in there too. All sanded down, parted off, and ready to trim the ends smooth. Beltsander? Nah, it threw one knob across the shop! Ok, narrow belt-sander. Meh..... ONE bench plane knob turned out decently, the other ....not so decently. Drilled hole through all three. About the same results. One GOOD knob. Went and dug up a steel, slotted screw. Installed the Kanoobie on the front porch of the #81, and started coating it in oil well...not too bad. Looking more like a plane, now I did try this set up before the oil went on, Nice and easy to use now. Shavings flew out, even on Oak. Might just be a keeper
  4. Earl
    Wood plane identification
    I can't seem to find the exact American company who makes this wood plane and I would appreciate any help. The frog is stamped steel. I'll provide some pictures.
  5. Courtland
    Wood Plane
    From the album: Collage of Interesting Images
    Looks like an Emmerich doesn't it?
