Showing results for tags 'spice rack'.
Hi, John if you think this needs to be relocated, please do so. The wife of my best friend, sent me (well actually me Missus) a picture of a spice rack that rolls into the space between the fridge and wall. Was wondering if I could make one for her. I told her I thought it would be too top heavy, and would get very dusty there. Then I was wondering (and I’m gonna TRY to describe my idea), If I built a box, say 3 feet by 3 feet by 6 inches, and the 6 inches was to fit in the space between the fridge and wall, could I use a pair of drawer slides for it to slide out from the fridge and then back in? The slides would be mounted on the wall side of the box, top and bottom. I was wondering if it might sway too much, when fully pulled out. I was gonna put a back on the box, and doors on the front to keep the dust out. Pull it out from the space, open the doors, grab your spices, close everything up and slide it back in. Any thoughts on better hardware, or design, I’m more than happy to consider/use
- 18 replies
- spice rack
- box
(and 4 more)
Well, just a short feature. Nails and glue to hold the thing together long enough to slap a coat or two of finish on. Found four white knobs in the spare parts drawer. Had to cut the bolts down a bit. Walnut stain and BLO as a finish. After a wipe down, brought it upstairs (whew!!) and loaded it up... this was before I loaded it up. Still awaiting the Boss' approval..... Have a nice stack of thin boards still in the shop.......might be some other little project to do? At least it beats trying to get a bandsaw fixed back up..... Might try to glue up the old rack, Might pass the time with that..
- 1 reply
- spice rack
- walnut stain
(and 1 more)
