Showing results for tags 'soap and water'.
Found 3 results
  1. kmealy
    Quick Fix Up #2
    The same friend that gave me the nesting table to repair gave me a chair to take to the furniture bank. It needed some help. It had been "sitting in the attic for a while." Seat was a mess and bird poop over many spots. As an aside, I think this is the first piece I've ever worked on that had a wipe-on stain and not just a spray on toner, given the marks on the bottom of the seat base. Procedure: Take off set cushion Clean with naptha, then soap & water The finish had deteriorated around where the hands would be on the arm. This happens with exposure to body oils over time. I tried to clean up, but no luck, so It got sanded off. The upper back was salvageable with a cleaning and light sanding. Apply a coat of shellac to seal over most of the areas. Apply aerosol toner (lacquer with color in it) in dark and extra dark cherry Apply clear lacquer as a top coat Flip the top of the padding over and add several layers of polyfill padding Reupholster the top with new fabric Reattach the seat Before: Atter seat removal and sanding arms New upholstery on seat Finish repairs All done
  2. Bowl blanks can be dried using "chemistry". Submerging the blanks in various liquids can actually facilitate the loss of moisture. Before the pandemic, denatured alcohol was readily and turners would soak their blanks in it. Several sources of information on this- From the AAW- https://www.aawforum.org/community/threads/is-the-alcohol-drying-method-food-safe.9682/ From Mr. David Reed Smith- http://alcoholsoaking.blogspot.com/ and- http://alcoholsoaking.blogspot.com/2005/12/alcohol-soaking-q-and.html From David J. Marks- https://djmarks.com/drying-olive-wood-for-turning/ Alcohol should become more readily as the pandemic wanes. Another soaking method is using soap and water. As near as I can determine, this method was developed by Ron Kent- a Hawaii based turner. Even though he passed away several years ago, his website is still up and his original process is listed there. https://www.ronkent.com/techniques.php Using pretty much the same process, Ernie Conover discusses this in a Woodcraft blog- https://www.woodcraft.com/blog_entries/soap-in-your-bowl The AAW also has a discussion on this method- https://www.aawforum.org/community/threads/soaking-in-dishwashing-liquid.9087/ As well as the folks over at Sawmill Creek- https://sawmillcreek.org/showthread.php?33726-Drying-green-wood-using-dish-soap I have personally adopted this method and find it works extremely well. At this time, none of my bowls have cracked and show very little deformation. This method is also very inexpensive. One final "chemical" drying is to immerse the bowl blanks in a desiccant material. These materials absorb moisture from the wood. This video, from Ernie Conover and The Woodworker's Journal demonstrates the procedure- Although initially expensive, desiccant can be reused by heating the crystals in the oven to "re-activate" them. A discussion from the AAW- https://www.aawforum.org/community/threads/drying-green-wood-turned-bowls-in-silica-desiccant-beads.16924/ Although not as popular as some of the other methods, Some turners have tried to boil the bowl blanks. This PDF, from the Arizona Woodturner's Association and written by Bill Noble has some details- boiling.pdf In the final entry, we will look at sources that have lists of multiple methods of drying.
  3. Wow! May is almost in the books! Our Patriot Turners- @Ron Altier isn't waiting for December to turn ornaments! Here is his latest beauty- Ron really creates some stunning pieces from Spectraply. @Gerald started a post on a shop made texturing tool. These are really useful for embellishing the bottom of vessels and lids of turned boxes. Gerald's post contains a link to the "how-to" tutorial. This post also has some super information on photography lighting. Gerald also posted a topic on drying/stabilizing green wood- The post generated a great discussion and some questions. From Gerald's post, I pulled the website URL he referenced. There is a wealth of information contained at the "Magnolia Woodturners" site. Check out their "How To Do It"page- https://mwt.clubexpress.com/content.aspx?page_id=22&club_id=96005&module_id=341063 What’s Coming Up- Nick Agar will be the featured turner at the Center for Furniture Craftsmanship. Click on the above image for the link to more information and registration. For The Newbies- Well you have decided on turning from green wood. It is a blast to watch those ribbons of wood peel away! Of course, now you realize there is one more "Turning" tool you need to add to your arsenal- a chainsaw! Mike Peace has a short little video for making a cradle to safely hold those logs and keep that chainsaw blade out of the dirt- Expand Your Horizons- Lyle Jamieson show us how created a natural edge hollow form. Notice the hollowing system he uses along with the laser indicator. Everything Else- Just for the enjoyment, something from Tim Yoder- Safe turning
