Showing results for tags 'shop built'.
Found 2 results
  1. Ron Altier
    Redesigned vac
    Lew wrote about redesigning his lathe vac system. I was already tossing it around in my mind and wrote about a header, etc. Then it hit me, why go thru all that. I used thick cardboard and sheets of plastic. The thicker plastic came from the Dollar 3 for a dollar and are about 11" by 14". It cuts easily and can be taped to make larger sheets. I made alterations as I went. I installed my shop vac 2 and half inch hose in the lower left and formed the bendable plastic to fit. This prototype has worked really good so far. I also have in mind a divider made of the same plastic that can be moved to shorten or lengthen the coverage area for more effective pick up. I like it so well, I may just go ahead and use it as is. If not, a permanent set up will be much easier using what I have for plans. I used hot melt glue and clear packing tape to make it and things went fast. I altered as I went.
  2. I'm hoping this will hold the 380 some odd pounds of lathe. I just don't trust the flimsy metal but I guess it could be fairly sturdy ones the main body of the lathe is setting on it at least I hope it is. I'm not going to be lifting it by myself. I did notice that the main legs of the lathe itself were TOOO short for me to use so I cut down a couple of 2x4s to sit underneath the legs of the lathe and I will lock those into place. From there I will bolt the 2x4s into the concrete. I also plan on securing it to the wall some how maybe with a couple of 2x4s and drilling through the legs and bolting it in I'll have to figure something out for that. I do not want it walking around. How ever this may be quite a bit easier to work around. I also put a good coat of paste wax onto the lathe bed as well while I was out there. Either way this may work out better in the long run than using the 2x4s. Then I can get rid of the mess on the wall for once.
