Showing results for tags 'sharpening tools'.
I found this young mans video entertaining, while building his Tea Cabinet. At first when I saw his shop full of Japanese hand tools, and he starts out by processing his lumber by power, I questioned why did he have all the hand tooling if he's only going to process by power, but he quickly transitions to hand tools and displays his skill with the craft. I do love the simplicity and minimalist design of the cabinet. On a side note, I recognize that Hitachi F1000A combo jointer surface planer he has, I had one just like it, and I do love his little table saw.
- 9 replies
- tea cabinet
- cabinet
(and 6 more)
So I've recently Purchased TWO different sharpening systems. I bought a bench grinder that was low RPM. As well as the PSI Chisel Mate Plus from PSI Woodworking. I received it this afternoon it was a bit on the late side. How ever I've opened it up and set it up on the lathe tested it out on a couple of gouges and chisels. Seems to work quite well RECOMMENDED USE WITH VARIABLE SPEED LATHES. Its quite simple to install it goes right on to the spindle head of your wood lathe its already set for a 1 inch 8 tpi spindle head. Works with the Delta lathe wonderfully. This system actually did a better job than the bench grinder for me at sharpening. The tool holder fit nicely into the tool rest for my lathe and it was quite easy to adjust for the shape of the chisel or gouge to easily sharpen it. It was very easy to follow the grind on the tool. If I would have known or realized what this was to begin with I probably wouldn't have bought the bench grinder either way I can use that for other tools that need sharpening. IE mower blades and knives. How ever I think I will be using this particular tool from now on to sharpen chisels and gouges. I would definately recomend this product. It is sold on Amazon and the PSI Woodworking website but I did buy mine on Amazon. List cost $42.95 plus what ever your state charges for taxes. (Shipping not included in price) https://www.amazon.com/gp/product/B07D2PNYLL/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
