Showing results for tags 'router lift'.
Shark RS1000 Next Wave
Grandpadave52 posted a topic in Machinery, Tools, Research, Reviews and Safety
Saw THIS else where. Pretty cool actually although pricey IMO. I could see applications for small production run shops or multiple one-off projects. WARNING: Some language in the video. Also see if you can figure this guy's favorite phrase.- 2 replies
- shark rs1000
- router fence
- (and 5 more)
I received the Woodcraft Monthly sale e-Flier a couple of days ago. If you've been looking for a router lift they have the Jessem 02301 lift at a pretty good price; $149.99 Not the top Jessem model, but still a very nice lift especially for the money.. Woodcraft Sale-Jessem 02310 Router Lift Sale
- 12 replies
- jessem
- router lift
(and 3 more)
From the album: Router table / cabinet drawer mounted
- router lift
- lift
(and 1 more)
Like many I have a router on the one wing of the TS. And yes it gets in the way sometimes but for larger work it works well. Having been given a Bosch 1604 I saw opportunity in the form of a mini router table. Scanning the shop I found a nice place to stow it away, in the form of a drawer. Lost 3 small drawers but they were only 9 inches wide smaller stuff I can displace, albeit remembering where I did so may be an issue. To make the router lift I am using a small Lab Scissor lift. About 4 inch square with more than enough lift for this task. Put in drawer slides to guide the router assembly smoothly up and down. Had to run a 1/4 threaded rod through the front to lock the sled in place after setting the height with the lower adjustment wheel. So far the drawer is made, sits level and has 4 sets of 150lb drawer slides to support it. The sled is made, all the kinks worked out and it now awaits a wheel to attach to the lift and a switch, box and some wiring. While I know 4 inch DC ports and systems are all the rage my shop has 2 1/2 and it works, not going to go through a major refrb at this time. So the port will be for a DC hose but inverted as the side of the drawer has 1/2 clearance so nothing can stick out. Only issue I have not got a working design for is the mechanical locks to keep the drawer from sliding back in while in use. Have two ideas about it that some mock ups will be in order to see how they work. It's coming, but at my typical pace, kinda slow.
- 73 replies
- router table
- router lift
(and 1 more)
It worked great for regular size routers then made a larger size hole for the Porter Cable big dog. And it had a slight vibration with that much horse power.. I think I made this in about 2003. I saw this contraption in a popular mechanics many years ago. All it takes to build is some smooth rods, a few pieces of all thread and some nuts and bolts. But this is my most used router and how it is mounted I will not sell this idea to anyone.. You will have to come up with your own invention. Its not near as expensive to build one of these setups..This one I noticed is leaning a little but that don't cause no problems... I do wear my heavy leather gloves when in use... I have it mounted on my 12" table saw....
- 4 replies
- router
- porter cable
(and 1 more)
I have the Hitachi M12VC, 2 1/4 HP router in my router table. Does anyone know of a reasonably priced router lift that will accept this router?
- 23 replies
- router lift
- hitachi
(and 1 more)
