Showing results for tags 'red elm'.
Found 2 results
  1. Steve Krumanaker
    -3 degrees this morning......
    and up to 15" of snow predicted for next week. But, I know spring is coming and with spring comes wrens. So, just put the first coat of linseed oil on a couple acorn style wren houses, exterior only. Roughed these out a few years ago but pretty sure they are spalted beech. One walnut roof and one red elm roof. Roof is held in place by the little piece of wood that is just wider than the top hole and then it will wedge tight as the eye bolt is tightened. That makes for pretty easy clean out. I do need a longer eye bolt though.
  2. Steve Krumanaker
    Red elm, a couple little bowls.
    A few months ago my son told me he was going to start making "river" tables. When he told me I was surprised because I didn't really know what is a river table. Secondly, he is in his 40's and had never expressed any interest in wood working that I knew of. More recently, he and his lovely bride have expanded into making charcuterie boards. Once again I wasn't sure what that even was. Well, I have to say, he's doing some very nice things. Stick with me, this is wood turning related. He has given me several cut offs and most of the time they are too small to do much with so I use them for ornaments and such. Recently, he gave me some red elm pieces and they were big enough to turn a couple of little bowls, bigger bowl is about 7" diameter and the smaller is slightly less, maybe 6". I have to say, I had no idea how pretty is the grain in red elm. It looks very open grain but it doesn't feel or sand that way. These pieces were kiln dried and about 2" thick before turning. Since the wood was already dried the bowls are single turned to finish. Red elm is a little dusty but cuts nicely and these have very little sanding on them. They have minwax antique oil for a finish.
