Showing results for tags 'linseed oil'.
Found 6 results
  1. If you ever have a doubt, check out this video at about 26:00 mark . At least it wasn't in the shop at 2 AM
  2. Our Ward 57 project was a complete success. Congrats to all of the raffle winners. Sure hope we get to see some pictures of the kids opening their presents! Writing this on Tuesday as Mimi is scheduled to have here right knee replace tomorrow. She had the left one done about a year ago. I'll be on nurse, cook, laundry, dog sitting and general all around house husband for then next couple of weeks. Our Patriot Turners- @jthornton posted a couple of things this past week. First is his segment jig- As often happens, the best laid plans of mice and men... anyway, he discovered the accuracy wasn't spot on. He tells us more in his post- JT went on to show us what he does with the segments he makes. This is an awesome bowl! Check out his post for more images and a little about the build- What’s Coming Up- Registration is at https://streamyard.com/watch/KGRprAZsAGQU More information here- https://woodturner.org/Woodturner/Virtual-Events/Emma_Cook_Resin_Inlay_Platter.aspx For The Newbies- Reverse sanding can be useful but it comes with some possible problems. Mike peace explains in this video- Do you use a scraper when turning? Richard Raffan shows us how to hone it for the best cuts- Expand Your Horizons- I get a lot of turning notification form various social media accounts. One from Sam Angelo popped up covering his home made finish. I was curious about food contact. Sent him a message but haven't heard back. Here's his video- It worried me about the turpentine. Did a little more digging and found something I didn't expect in a post by Kent Weakley. About have way through the article there is information comparing Linseed Oil to Boiled Linseed Oil. I'll let you decide about what/when you use the ingredients- https://turnawoodbowl.com/my-favorite-food-safe-wood-finish-waterproof-almost/ Another social media article popped up about the difficulty between turning large bowls vs. small bowls. Most of the respondents felt small bowls were more difficult. No one told Richard Raffan that! A beautiful maple burl bowl from Tim Yoder- New Turning Items- Couldn't find anything new but I did notice that Niles Bottle Stoppers have added some Yorkshire Grit products. Our generous sponsor Easy Wood Tools ( @Jordan Martindale ) is now the US source for this great sanding finish! Everything Else- Rick Turns list of YouTube woodturning videos from last week- Got to play at the lathe the other day. Everyone was making those Gnomes/Gonks. I got this idea that they should be more than just a shelf setter. Turned this one from maple and walnut. The "fur" is from Hobby Lobby. I found some of the original Niles Bottle stoppers hidden in a box. Wine bottle stopper Safe turning
  3. Steve Krumanaker
    The walking stick is done.
    The walking stick is done and has the first coat of boiled linseed oil on it. I used linseed oil because that's about as good anything for outdoor use and it's very easy to re apply as needed. I really like white oak and walnut together. After a few coats of oil this will get a rubber cane tip on the bottom.
  4. Steve Krumanaker
    -3 degrees this morning......
    and up to 15" of snow predicted for next week. But, I know spring is coming and with spring comes wrens. So, just put the first coat of linseed oil on a couple acorn style wren houses, exterior only. Roughed these out a few years ago but pretty sure they are spalted beech. One walnut roof and one red elm roof. Roof is held in place by the little piece of wood that is just wider than the top hole and then it will wedge tight as the eye bolt is tightened. That makes for pretty easy clean out. I do need a longer eye bolt though.
  5. kmealy
    TGIF: Linseed vs. Tung Oil
    A good comparison of linseed vs. tung oil One other difference is that if you apply subsequent coats of tung oil before what's there has fully cured, it will fog up and nothing will fix it except stripping and starting over. Be aware that many products are called Tung Oil Finish that are either linseed oil or linseed oil-varnish blends. If there is anything that looks like mineral spirits, aliphatic hydrocarbons, etc. in the SDS, it's probably the latter and not really tung oil. Blame the huckster Homer Formby for starting this massive mis-representation. On another forum this week someone asked about finish for a wooden cup. One responder recommended "organic flaxseed oil." I don't think he realized two things: - this is just another name for raw linseed oil, that the article states takes weeks to cure - that after a few weeks of curing, linseed oil has 0 moisture excluding efficiency See chart 16-3
  6. Yesterday Beth and I spent the day yard scaling for about 60 miles. It was the weekend for the Meriwether Lewis weekend in Hohenwald, TN. We stopped at this one location and there were about 50 tents setup. I was walking by a table and something on the table yelled my name. This really nice looking wood Linseed Oil Container. . This should look nice in the shop
