Showing results for tags 'reclaimed timber'.
Woodman posted a gallery image in Lumber, Milling and Forestry
From the album: Mid-1800s Heart Pine Beam Split & Resawn
© The Patriot Woodworker
Well the historic wood pen turning project is moving along, slowly, but moving. Part of the deal was to make two special presentation boxes for those responsible for securing monies. The main turner involved doesn't have many wood working tools so the box making fell on me. No one had a plan as to what they wanted the boxes to look like. OK, I've made some boxes but I don't feel my skills are really up to what I think they should be for this type of project. Especially with this precious wood. My original design was to have the box larger, but the size of the beams and the number of defects, cracks and nail holes reduced it to around 4" x 7"x 1.5". The pieces are 1/4" thick. The old pine is very brittle but it still contained a surprising amount of sap. The number of knots would not allow me to use the planer and get this thickness, so I used my thickness sander. I had to clean the belt 3 time during the thicknessing process to remove the built up pitch. All of the dovetails are hand cut using a Japanese pull saw. The above picture show one of the "hinges". I used tiny cut nails salvaged from the original structure placed into pre-drilled holes. Right now they are just finger tight. The lid lift is also a little nail. I think this one has to be in a little deeper. I hate it that the round hole shows on the front. Although you can't tell from this picture, the bottom is thicker than the dado it fits into (bottom = 1/4" dado = 1/8"). About an inch of the perimeter is tapered to the edge allowing the fit. I'm not sure what to do with the inside. Maybe a couple of "U" shaped risers to hold the pen off of the bottom. Covering the interior would make for a nice contrast but it almost seems sacrilege to hide the patina. At this point, I am stumped on my next step. My original plan was to inlay a "Carpenter's Mark" in the outside of the top. I made an oval inlay pattern and cut a sample from some Poplar to see how it would look- I made certain I salvaged all of the carpenter's marks, before I made the pen blanks from the beam. Now, the problem. The pine is so brittle- even more so near the surface, that I fear the router inlay kit will splinter the the wood. To help strengthen the "mark", I covered the back of the piece with painters tape and saturated it with thin CA. I'll need to stop at Hobby Lobby tomorrow after school and pick up another bottle- thank goodness they send me 40% off coupons every week! So that's where I'm at, with this part- still needs more sanding! I was thinking about making the second box with a "pencil box" sliding lid.
